74LVC2G04
Dual inverter
Rev. 10 — 22 May 2017
1
Product data sheet
General description
The 74LVC2G04 provides the dual inverting buffer.
Inputs can be driven from either 3.3 V or 5 V devices. These features allow the use of
these devices in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the
device when it is powered down.
2
Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant inputs for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
– JESD8-7 (1.65 V to 1.95 V)
– JESD8-5 (2.3 V to 2.7 V)
– JESD8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
– HBM JESD22-A114F exceeds 2000 V
– MM JESD22-A115-A exceeds 200 V
±24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
Multiple package options
Specified from −40 °C to +85 °C and −40 °C to +125 °C.
74LVC2G04
Nexperia
Dual inverter
3
Ordering information
Table 1. Ordering information
Type number
Package
Temperature
range
Name
Description
Version
74LVC2G04GW
-40 °C to +125 °C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74LVC2G04GV
-40 °C to +125 °C
SC-74
plastic surface-mounted package (TSOP6); 6 leads
SOT457
74LVC2G04GM
-40 °C to +125 °C
XSON6
plastic extremely thin small outline package; no leads;
6 terminals; body 1 × 1.45 × 0.5 mm
SOT886
74LVC2G04GF
-40 °C to +125 °C
XSON6
6 terminals; body 1 × 1 × 0.5 mm
SOT891
74LVC2G04GN
-40 °C to +125 °C
XSON6
6 terminals; body 0.9 × 1.0 × 0.35 mm
SOT1115
74LVC2G04GS
-40 °C to +125 °C
XSON6
6 terminals; body 1.0 × 1.0 × 0.35 mm
SOT1202
74LVC2G04GX
-40 °C to +125 °C
X2SON6
plastic thermal extremely thin small outline package;
no leads; 6 terminals; body 1 × 0.8 × 0.35 mm
SOT1255
4
Marking
Table 2. Marking
Type number
Marking code
74LVC2G04GW
V4
74LVC2G04GV
V04
74LVC2G04GM
V4
74LVC2G04GF
V4
74LVC2G04GN
V4
74LVC2G04GS
V4
74LVC2G04GX
V4
[1]
5
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
Functional diagram
1
1A
1Y
6
3
2A
2Y
4
mnb079
Figure 1. Logic symbol
74LVC2G04
Product data sheet
1
3
1
6
1
4
mnb080
Figure 2. IEC logic symbol
All information provided in this document is subject to legal disclaimers.
A
Y
mna110
Figure 3. Logic diagram (one gate)
© Nexperia B.V. 2017. All rights reserved.
2 / 19
74LVC2G04
Nexperia
Dual inverter
6
Pinning information
6.1 Pinning
74LVC2G04
74LVC2G04
1A
1
6
1Y
GND
2
5
VCC
2A
3
4
1A
1
6
1Y
GND
2
5
VCC
2A
3
4
2Y
2Y
001aab650
Transparent top view
001aab649
Figure 4. Pin configuration SOT363 and SOT457
Figure 5. Pin configuration SOT886
74LVC2G04
74LVC2G04
1A
1
1A
1
6
1Y
GND
2
5
VCC
2A
3
4
2Y
GND
1Y
6
2
3
2A
001aaf872
Figure 6. Pin configuration SOT891, SOT1115 and
SOT1202
VCC
5
4
2Y
aaa-019823
Figure 7. Pin configuration SOT1255 (X2SON6)
6.2 Pin description
Table 3. Pin description
Symbol
Pin
Description
1A
1
data input
GND
2
ground (0 V)
2A
3
data input
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
74LVC2G04
Product data sheet
3 / 19
74LVC2G04
Nexperia
Dual inverter
7
Functional description
Table 4. Function table
[1]
Input
Output
nA
nY
L
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level.
8
Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO
output voltage
IO
output current
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
[1]
[2]
[3]
Conditions
VI < 0 V
[1]
VO > VCC or VO < 0 V
Min
Max
Unit
-0.5
+6.5
V
-50
-0.5
+6.5
V
±50
mA
mA
Active mode
[1] [2]
-0.5
Power-down mode
[1] [2]
-0.5
+6.5
V
±50
mA
100
mA
-100
mA
250
mW
-65
+150
°C
VO = 0 V to VCC
Tamb = -40 °C to +125 °C
[3]
VCC + 0.5 V
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
For SC-88 and SC-74 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
For X2SON6 and XSON6 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
74LVC2G04
Product data sheet
4 / 19
74LVC2G04
Nexperia
Dual inverter
9
Recommended operating conditions
Table 6. Recommended operating conditions
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
-40
+125
°C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
10 Static characteristics
Table 7. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
VIH
VIL
VOH
VOL
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level
output voltage
VCC = 1.65 V to 1.95 V
Product data sheet
-40 °C to +125 °C Unit
Max
Min
Max
0.65VCC
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
VCC = 2.7 V to 3.6 V
2.0
2.0
V
VCC = 4.5 V to 5.5 V
0.7VCC
0.7VCC
V
0.35VCC
0.35VCC
V
0.7
0.7
V
0.8
0.8
V
0.3VCC
0.3VCC
V
VCC - 0.1
VCC - 0.1
V
IO = -4 mA; VCC = 1.65 V
1.2
0.95
V
IO = -8 mA; VCC = 2.3 V
1.9
1.7
V
IO = -12 mA; VCC = 2.7 V
2.2
1.9
V
IO = -24 mA; VCC = 3.0 V
2.3
2.0
V
IO = -32 mA; VCC = 4.5 V
3.8
3.4
V
0.10
0.10
V
IO = 4 mA; VCC = 1.65 V
0.45
0.70
V
IO = 8 mA; VCC = 2.3 V
0.30
0.45
V
IO = 12 mA; VCC = 2.7 V
0.40
0.60
V
VI = VIH or VIL
IO = -100 μA;
VCC = 1.65 V to 5.5 V
LOW-level output VI = VIH or VIL
voltage
IO = 100 μA;
74LVC2G04
Typ
[1]
5 / 19
74LVC2G04
Nexperia
Dual inverter
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
Typ
[1]
Max
Min
Max
IO = 24 mA; VCC = 3.0 V
0.55
0.80
V
IO = 32 mA; VCC = 4.5 V
0.55
0.80
V
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
±0.1
±1
±1
μA
IOFF
power-off
leakage current
VCC = 0 V; VI or VO = 5.5 V
±0.1
±2
±2
μA
ICC
supply current
VI = 5.5 V or GND; IO = 0 A;
0.1
4
4
μA
ΔICC
additional supply per pin; VCC = 2.3 V to 5.5 V;
current
VI = VCC - 0.6 V; IO = 0 A
5
500
500
μA
CI
input
capacitance
2.5
pF
[1]
VCC = 3.3 V; VI = GND to VCC
All typical values are measured at VCC = 3.3 V and Tamb = 25 °C.
11 Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9.
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
tpd
propagation delay
nA to nY; see Figure 8
[1]
[2]
[3]
power dissipation
capacitance
Max
Min
Max
[2]
1.0
3.5
8.0
1.0
9.5
ns
1.0
2.2
4.4
1.0
5.4
ns
VCC = 2.7 V
1.0
2.7
5.2
1.0
7.0
ns
VCC = 3.0 V to 3.6 V
0.5
2.7
4.1
0.5
5.5
ns
1.0
1.9
3.2
1.0
3.8
ns
13.5
pF
CPD
Typ
[1]
VI = GND to VCC; VCC = 3.3 V
[3]
Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
tpd is the same as tPLH and tPHL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL × VCC × fo) = sum of outputs.
74LVC2G04
Product data sheet
6 / 19
74LVC2G04
Nexperia
Dual inverter
11.1 Waveforms and test circuit
VI
VM
nA input
VM
GND
t PHL
t PLH
VOH
VM
nY output
VOL
VM
mna344
Measurement points are given in Table 9.
VOL and VOH are typical output voltage levels that occur with the output load.
Figure 8. The input nA to output nY propagation delays
Table 9. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
1.65 V to 1.95 V
0.5VCC
0.5VCC
2.3 V to 2.7 V
0.5VCC
0.5VCC
2.7 V
1.5 V
1.5 V
3.0 V to 3.6 V
1.5 V
1.5 V
4.5 V to 5.5 V
0.5VCC
0.5VCC
74LVC2G04
Product data sheet
7 / 19
74LVC2G04
Nexperia
Dual inverter
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
mna616
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Figure 9. Test circuit for measuring switching times
Table 10. Test data
Supply voltage
Input
VCC
VI
tr = tf
CL
RL
tPLH, tPHL
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
74LVC2G04
Product data sheet
VEXT
Load
8 / 19
74LVC2G04
Nexperia
Dual inverter
12 Package outline
Plastic surface-mounted package; 6 leads
SOT363
D
B
E
y
A
X
HE
6
5
v M A
4
Q
pin 1
index
A
1
2
e1
A1
3
bp
c
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.1
0.8
0.1
0.30
0.20
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.25
0.15
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT363
JEITA
SC-88
EUROPEAN
PROJECTION
ISSUE DATE
04-11-08
06-03-16
Figure 10. Package outline SOT363 (SC-88)
74LVC2G04
Product data sheet
9 / 19
74LVC2G04
Nexperia
Dual inverter
Plastic surface-mounted package (TSOP6); 6 leads
D
SOT457
B
E
y
A
HE
6
5
X
v M A
4
Q
pin 1
index
A
A1
1
2
c
3
Lp
e
bp
w M B
detail X
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.1
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT457
JEITA
SC-74
EUROPEAN
PROJECTION
ISSUE DATE
05-11-07
06-03-16
Figure 11. Package outline SOT457 (SC-74)
74LVC2G04
Product data sheet
10 / 19
74LVC2G04
Nexperia
Dual inverter
SOT886
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm
b
1
2
3
4x
(2)
L
L1
e
6
5
e1
4
e1
6x
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
0.5
A1
b
D
E
0.04 0.25 1.50 1.05
0.20 1.45 1.00
0.17 1.40 0.95
e
e1
0.6
0.5
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
Outline
version
SOT886
sot886_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
04-07-22
12-01-05
MO-252
Figure 12. Package outline SOT886 (XSON6)
74LVC2G04
Product data sheet
11 / 19
74LVC2G04
Nexperia
Dual inverter
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm
1
SOT891
b
3
2
4×
(1)
L
L1
e
6
5
e1
4
e1
6×
A
(1)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.20
0.12
1.05
0.95
1.05
0.95
0.55
0.35
0.35
0.27
0.40
0.32
Note
1. Can be visible in some manufacturing processes.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-04-06
07-05-15
SOT891
Figure 13. Package outline SOT891 (XSON6)
74LVC2G04
Product data sheet
12 / 19
74LVC2G04
Nexperia
Dual inverter
XSON6: extremely thin small outline package; no leads;
6 terminals; body 0.9 x 1.0 x 0.35 mm
1
SOT1115
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
max 0.35 0.04 0.20 0.95 1.05
nom
0.15 0.90 1.00 0.55
min
0.12 0.85 0.95
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
sot1115_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1115
Figure 14. Package outline SOT1115 (XSON6)
74LVC2G04
Product data sheet
13 / 19
74LVC2G04
Nexperia
Dual inverter
6 terminals; body 1.0 x 1.0 x 0.35 mm
1
SOT1202
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.05 1.05
0.35 0.40
nom
0.15 1.00 1.00 0.55 0.35 0.30 0.35
min
0.12 0.95 0.95
0.27 0.32
Note
Outline
version
sot1202_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1202
Figure 15. Package outline SOT1202 (XSON6)
74LVC2G04
Product data sheet
14 / 19
74LVC2G04
Nexperia
Dual inverter
X2SON6: plastic thermal enhanced extremely thin small outline package; no leads;
6 terminals; body 1.0 x 0.8 x 0.35 mm
SOT1255
X
A
D
B
A
pin 1
ID area
E
A1
detail X
C
e1
b
(4x)
4
3
y1 C
A B
v
y
L
(4x)
2
5
Dh
(2x)
1
6
e2
1 mm
scale
Unit
mm
A
A1
D
Dh
E
e1
e2
b
L
v
y
y1
max 0.35 0.04 1.05 0.30 0.85
0.30 0.25
nom 0.32 0.02 1.00 0.25 0.80 0.60 0.40 0.25 0.20 0.10 0.05 0.05
0.22 0.17
min 0.30 0.00 0.95 0.22 0.75
sot1255_po
Outline
version
References
IEC
JEDEC
JEITA
European
projection
Issue date
15-07-20
15-07-22
SOT1255
Figure 16. Package outline SOT1255 (X2SON6)
74LVC2G04
Product data sheet
15 / 19
74LVC2G04
Nexperia
Dual inverter
13 Abbreviations
Table 11. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14 Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC2G04 v.10
20170522
Product data sheet
74LVC2G04 v.9
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
• Pin 6 description updated. Section 6.2
74LVC2G04 v.9
20161212
Modifications:
• Table 7: The maximum limits for leakage current and supply current have changed.
74LVC2G04 v.8
20150917
Modifications:
• Added type number 74LVC2G04GX (SOT1255/X2SON6).
74LVC2G04 v.7
20140910
Modifications:
• Package outline drawing of SOT886 (Figure 12) modified.
74LVC2G04 v.6
20111206
Product data sheet
74LVC2G04 v.5
74LVC2G04 v.5
20100805
Product data sheet
74LVC2G04 v.4
74LVC2G04 v.4
20070725
Product data sheet
74LVC2G04 v.3
74LVC2G04 v.3
20070216
Product data sheet
74LVC2G04 v.2
74LVC2G04 v.2
20040915
Product specification
74LVC2G04 v.1
74LVC2G04 v.1
20030722
74LVC2G04
Product data sheet
Product data sheet
Product data sheet
Product data sheet
74LVC2G04 v.8
74LVC2G04 v.7
74LVC2G04 v.6
16 / 19
74LVC2G04
Nexperia
Dual inverter
15 Legal information
15.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74LVC2G04
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
17 / 19
74LVC2G04
Nexperia
Dual inverter
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74LVC2G04
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
18 / 19
74LVC2G04
Nexperia
Dual inverter
Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
11.1
12
13
14
15
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 2
Marking .................................................................2
Functional diagram ............................................. 2
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 3
Functional description ........................................4
Limiting values .................................................... 4
Recommended operating conditions ................ 5
Static characteristics .......................................... 5
Dynamic characteristics .....................................6
Waveforms and test circuit ................................ 7
Package outline ...................................................9
Abbreviations .................................................... 16
Revision history ................................................ 16
Legal information .............................................. 17
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 22 May 2017
Document identifier: 74LVC2G04
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVC2G04GS,132 74LVC2G04GN,132 74LVC2G04GF,132 74LVC2G04GM,115 74LVC2G04GM,132
74LVC2G04GV,125 74LVC2G04GW,125 74LVC2G04GXZ
