74LVC2GU04
Dual unbuffered inverter
Rev. 11 — 9 October 2018
Product data sheet
1. General description
The 74LVC2GU04 provides two unbuffered inverters. Each inverter is a single stage with
unbuffered output.
The inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device
in a mixed 3.3 V and 5 V environment.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant input/output for interfacing with 5 V logic
High noise immunity
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
±24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Input accepts voltages up to 5 V
Multiple package options
Specified from -40 °C to +85 °C and -40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74LVC2GU04GW
-40 °C to +125 °C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74LVC2GU04GV
-40 °C to +125 °C
TSOP6
plastic surface-mounted package (TSOP6);
6 leads
SOT457
74LVC2GU04GM
-40 °C to +125 °C
XSON6
plastic extremely thin small outline package;
no leads; 6 terminals; body 1 × 1.45 × 0.5 mm
SOT886
74LVC2GU04GF
-40 °C to +125 °C
XSON6
no leads; 6 terminals; body 1 × 1 × 0.5 mm
SOT891
74LVC2GU04GN
-40 °C to +125 °C
XSON6
extremely thin small outline package; no leads; SOT1115
6 terminals; body 0.9 × 1.0 × 0.35 mm
74LVC2GU04GS
-40 °C to +125 °C
XSON6
extremely thin small outline package; no leads; SOT1202
6 terminals; body 1.0 × 1.0 × 0.35 mm
74LVC2GU04
Nexperia
4. Marking
Table 2. Marking codes
Type number
Marking [1]
74LVC2GU04GW
YD
74LVC2GU04GV
VU4
74LVC2GU04GM
YD
74LVC2GU04GF
YD
74LVC2GU04GN
YD
74LVC2GU04GS
YD
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
1
1A
6
1Y
1
6
A
3
2A
4
2Y
1
3
mnb106
Fig. 1.
VCC
VCC
1
100 Ω
Y
4
mna636
mnb107
Logic symbol
Fig. 2.
IEC logic symbol
Fig. 3.
Logic diagram (one gate)
6. Pinning information
6.1. Pinning
74LVC2GU04
74LVC2GU04
1A
1A
1
6
1Y
GND
2
5
VCC
2A
3
4
2Y
Pin configuration
SOT363 (SC-88)
and SOT457 (TSOP6)
74LVC2GU04
Product data sheet
6
74LVC2GU04
1Y
GND
2
5
VCC
2A
3
4
2Y
Transparent top view
Fig. 5.
Pin configuration
SOT886 (XSON6)
All information provided in this document is subject to legal disclaimers.
1A
1
6
1Y
GND
2
5
VCC
2A
3
4
2Y
001aag421
001aab681
001aab680
Fig. 4.
1
Fig. 6.
Pin configuration
SOT891, SOT1115
and SOT1202 (XSON6)
Nexperia B.V. 2018. All rights reserved
2 / 16
74LVC2GU04
Nexperia
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
1A
1
data input
GND
2
ground (0 V)
2A
3
data input
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level.
Input
Output
nA
nY
L
H
H
L
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO < 0 V
VO
output voltage
Active mode
IO
output current
VO = 0 V to VCC
ICC
Min
Max
Unit
-0.5
+6.5
V
-50
[1]
-0.5
+6.5
[1][2]
-0.5
VI < 0 V
-50
mA
V
mA
VCC + 0.5 V
±50
mA
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
[3]
Tamb = -40 °C to +125 °C
[3]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
For SC-88 and TSOP6 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
74LVC2GU04
Product data sheet
3 / 16
74LVC2GU04
Nexperia
9. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
-40
+125
°C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
10. Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Tamb = -40 °C to +85 °C
Tamb =
-40 °C to +125 °C
Min
Typ [1]
Max
Min
Max
Unit
VIH
HIGH-level input
voltage
VCC = 1.65 V to 5.5 V
0.75VCC
0.8VCC
V
VIL
LOW-level input
voltage
0.25VCC
0.2VCC
V
VOH
HIGH-level output
voltage
VI = VIH or VIL
VCC - 0.1
VCC - 0.1
V
IO = -4 mA; VCC = 1.65 V
1.2
0.95
V
IO = -8 mA; VCC = 2.3 V
1.9
1.7
V
IO = -12 mA; VCC = 2.7 V
2.2
1.9
V
IO = -24 mA; VCC = 3.0 V
2.3
2.0
V
IO = -32 mA; VCC = 4.5 V
3.8
3.4
V
IO = 100 μA;
0.1
0.1
V
IO = 4 mA; VCC = 1.65 V
0.45
0.7
V
IO = 8 mA; VCC = 2.3 V
0.3
0.45
V
IO = 12 mA; VCC = 2.7 V
0.4
0.6
V
IO = 24 mA; VCC = 3.0 V
0.55
0.8
V
IO = 32 mA; VCC = 4.5 V
0.55
0.8
V
VOL
LOW-level output
voltage
IO = -100 μA;
VI = VIH or VIL
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
±0.1
±1
±1
μA
ICC
supply current
VI = 5.5 V or GND; IO = 0 A;
0.1
4
4
μA
CI
input capacitance
VCC = 3.3 V; VI = GND to VCC
5
pF
[1]
All typical values are measured at VCC = 3.3 V and at Tamb = 25 °C.
74LVC2GU04
Product data sheet
4 / 16
74LVC2GU04
Nexperia
11. Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 8.
Symbol Parameter
tpd
propagation delay
CPD
[1]
[2]
[3]
Conditions
power dissipation
capacitance
Tamb =
Unit
-40 °C to +125 °C
Min
Typ [1]
Max
Min
Max
VCC = 1.65 V to 1.95 V
0.5
2.3
5.0
0.5
6.3
ns
VCC = 2.3 V to 2.7 V
0.3
1.8
4.0
0.3
5.0
ns
VCC = 2.7 V
0.3
2.6
4.5
0.3
5.6
ns
VCC = 3.0 V to 3.6 V
0.3
2.3
3.7
0.3
4.5
ns
VCC = 4.5 V to 5.5 V
0.3
1.7
3.0
0.3
3.8
ns
7.8
nA to nY; see Fig. 7
[2]
VI = GND to VCC; VCC = 3.3 V [3]
pF
Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
tpd is the same as tPLH and tPHL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL × VCC × fo) = sum of outputs.
11.1. Waveforms and test circuit
VI
VM
nA input
VM
GND
t PHL
t PLH
VOH
VM
nY output
VOL
VM
mna344
Measurement points are given in Table 9.
VOL and VOH are typical output voltage drop that occur with the output load.
Fig. 7.
The input (nA) to output (nY) propagation delay times
Table 9. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
1.65 V to 1.95 V
0.5 × VCC
0.5 × VCC
2.3 V to 2.7 V
0.5 × VCC
0.5 × VCC
2.7 V
1.5 V
1.5 V
3.0 V to 3.6 V
1.5 V
1.5 V
4.5 V to 5.5 V
0.5 × VCC
0.5 × VCC
74LVC2GU04
Product data sheet
5 / 16
74LVC2GU04
Nexperia
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
mna616
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 8.
Test circuit for measuring switching times
Table 10. Test data
Supply voltage
Input
VCC
VI
tr = tf
CL
RL
tPLH, tPHL
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
VEXT
Load
mnb108
160
gfs
(mA/V)
Rbias = 560 kΩ
120
VCC
80
0.47 µF
input
100 µF
output
VI
40
A IO
mna638
Tamb = 25 °C.
Fig. 9.
2
3
4
5
6
VCC (V)
fi = 1 kHz.
VO is constant.
Typical forward transconductance as a function Fig. 10. Test set-up for measuring forward
of supply voltage
transconductance
74LVC2GU04
Product data sheet
6 / 16
74LVC2GU04
Nexperia
12. Application information
Some applications are:
Linear amplifier (see Fig. 11)
In crystal oscillator design (see Fig. 12)
Remark: All values given are typical unless otherwise specified.
R2
VCC
1 µF
R1
R1
U04
ZL
R2
U04
out
mna052
C1
Vo(p-p) = VCC - 1.5 V centered at 0.5VCC.
mna053
GOL = open loop gain.
Au = voltage amplification.
R1 ≥ 3 kΩ, R2 ≤ 1 MΩ.
ZL > 10 kΩ; GOL = 20 (typical).
Typical unity gain bandwidth product is 5 MHz.
Fig. 11. Linear amplifier configuration
74LVC2GU04
Product data sheet
C2
C1 = 47 pF (typical).
C2 = 22 pF (typical).
R1 = 1 MΩ to 10 MΩ (typical).
R2 optimum value depends on the frequency
and required stability against changes in VCC
or average minimum ICC (ICC is typically 2 mA
at VCC = 3.3 V and f = 10 MHz).
Fig. 12. Crystal oscillator configuration
7 / 16
74LVC2GU04
Nexperia
13. Package outline
Plastic surface-mounted package; 6 leads
SOT363
D
B
E
y
A
X
HE
6
5
v M A
4
Q
pin 1
index
A
1
2
e1
A1
3
bp
c
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.1
0.8
0.1
0.30
0.20
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.25
0.15
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT363
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-08
06-03-16
SC-88
Fig. 13. Package outline SOT363 (SC-88)
74LVC2GU04
Product data sheet
8 / 16
74LVC2GU04
Nexperia
Plastic surface-mounted package (TSOP6); 6 leads
D
SOT457
B
E
y
A
X
HE
6
5
v M A
4
Q
pin 1
index
A
A1
1
2
c
3
Lp
e
bp
w M B
detail X
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.1
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT457
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-11-07
06-03-16
SC-74
Fig. 14. Package outline SOT457 (TSOP6)
74LVC2GU04
Product data sheet
9 / 16
74LVC2GU04
Nexperia
SOT886
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm
b
1
2
3
4x
(2)
L
L1
e
6
5
e1
4
e1
6x
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
0.5
A1
b
D
E
0.04 0.25 1.50 1.05
0.20 1.45 1.00
0.17 1.40 0.95
e
e1
0.6
0.5
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
Outline
version
SOT886
sot886_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
04-07-22
12-01-05
MO-252
Fig. 15. Package outline SOT886 (XSON6)
74LVC2GU04
Product data sheet
10 / 16
74LVC2GU04
Nexperia
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm
1
SOT891
b
3
2
4×
(1)
L
L1
e
6
5
4
e1
e1
6×
A
(1)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.20
0.12
1.05
0.95
1.05
0.95
0.55
0.35
0.35
0.27
0.40
0.32
Note
1. Can be visible in some manufacturing processes.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-04-06
07-05-15
SOT891
Fig. 16. Package outline SOT891 (XSON6)
74LVC2GU04
Product data sheet
11 / 16
74LVC2GU04
Nexperia
XSON6: extremely thin small outline package; no leads;
6 terminals; body 0.9 x 1.0 x 0.35 mm
1
SOT1115
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
max 0.35 0.04 0.20 0.95 1.05
nom
0.15 0.90 1.00 0.55
min
0.12 0.85 0.95
e1
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
sot1115_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1115
Fig. 17. Package outline SOT1115 (XSON6)
74LVC2GU04
Product data sheet
12 / 16
74LVC2GU04
Nexperia
6 terminals; body 1.0 x 1.0 x 0.35 mm
1
SOT1202
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.05 1.05
0.35 0.40
nom
0.15 1.00 1.00 0.55 0.35 0.30 0.35
min
0.12 0.95 0.95
0.27 0.32
Note
Outline
version
sot1202_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1202
Fig. 18. Package outline SOT1202 (XSON6)
74LVC2GU04
Product data sheet
13 / 16
74LVC2GU04
Nexperia
14. Abbreviations
Table 11. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
15. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74LVC2GU04 v.11
20181009
Product data sheet
Modifications:
74LVC2GU04 v.10
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
74LVC2GU04 v.10
20170210
Modifications:
74LVC2GU04 v.9
20161215
Modifications:
74LVC2GU04 v.8
20120703
Modifications:
74LVC2GU04 v.7
20111128
Modifications:
74LVC2GU04 v.6
20101027
74LVC2GU04 v.5
Product data sheet
74LVC2GU04 v.9
74LVC2GU04 v.8
Watermarks removed.
Product data sheet
Table 7: The maximum limits for leakage current and supply current have changed.
Product data sheet
74LVC2GU04 v.7
Package outline drawing of SOT886 (Fig. 15) modified.
74LVC2GU04 v.6
Product data sheet
74LVC2GU04 v.5
20091027
Product data sheet
74LVC2GU04 v.4
74LVC2GU04 v.4
20070521
Product data sheet
74LVC2GU04 v.3
74LVC2GU04 v.3
20040921
Product specification
74LVC2GU04 v.2
74LVC2GU04 v.2
20040524
74LVC2GU04 v.1
74LVC2GU04 v.1
20030829
74LVC2GU04
Product data sheet
Product data sheet
Legal pages updated.
14 / 16
74LVC2GU04
Nexperia
16. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74LVC2GU04
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
15 / 16
74LVC2GU04
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 3
7. Functional description................................................. 3
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................4
10. Static characteristics..................................................4
11. Dynamic characteristics.............................................5
11.1. Waveforms and test circuit........................................ 5
12. Application information............................................. 7
13. Package outline.......................................................... 8
14. Abbreviations............................................................ 14
15. Revision history........................................................14
16. Legal information......................................................15
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 9 October 2018
74LVC2GU04
Product data sheet
16 / 16
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVC2GU04GN,132 74LVC2GU04GS,132 74LVC2GU04GM,115 74LVC2GU04GM,132 74LVC2GU04GV,125
74LVC2GU04GW,125 74LVC2GU04GF,132
