74AHC3GU04DC-Q100H
74AHC3GU04DC-Q100H
    NEXPERIA(安世)
    VSSOP8_2X2.3MM
    反相器 IC 3 通道 VSSOP8
74AHC3GU04DC-Q100H 数据手册
74AHC3GU04-Q100 Triple unbuffered inverter Rev. 2 — 27 February 2019 Product data sheet 1. General description The 74AHC3GU04-Q100 is a high-speed Si-gate CMOS device. This device provides three inverter gates with unbuffered outputs. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 1) • Specified from -40 °C to +85 °C and from -40 °C to +125 °C Symmetrical output impedance High noise immunity Low power dissipation Balanced propagation delays ESD protection: • MIL-STD-883, method 3015 exceeds 2000 V • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 Ω) 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version -40 °C to +125 °C TSSOP8 plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm SOT505-2 74AHC3GU04DC-Q100 -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; body width 2.3 mm SOT765-1 74AHC3GU04DP-Q100 4. Marking Table 2. Marking codes Type number Marking code [1] 74AHC3GU04DP-Q100 AU4 74AHC3GU04DC-Q100 AU4 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 74AHC3GU04-Q100 Nexperia Triple unbuffered inverter 5. Functional diagram 1 1A 1Y 1 1 7 3 1 5 6 1 2 7 3 2A 2Y 5 6 3A 3Y 2 A mna720 Fig. 1. Logic symbol Y mna721 Fig. 2. mna045 IEC logic symbol Fig. 3. Logic diagram (one gate) 6. Pinning information 6.1. Pinning 74AHC3GU04-Q100 1A 1 8 VCC 3Y 2 7 1Y 2A 3 6 3A GND 4 5 2Y aaa-009627 Fig. 4. Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8) 6.2. Pin description Table 3. Pin description Symbol Pin Description 1A, 2A, 3A 1, 3, 6 data input GND 4 ground (0 V) 1Y, 2Y, 3Y 7, 5, 2 data output VCC 8 supply voltage 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level Input Output A Y L H H L 74AHC3GU04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 February 2019 © Nexperia B.V. 2019. All rights reserved 2 / 13 74AHC3GU04-Q100 Nexperia Triple unbuffered inverter 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC supply voltage -0.5 +7.0 V VI input voltage -0.5 +7.0 V IIK input clamping current VI < -0.5 V [1] -20 - mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current -0.5 V < VO < VCC + 0.5 V - ±25 mA ICC supply current - 75 mA IGND ground current -75 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW Min Typ Max Unit 2.0 5.0 5.5 V [1] [2] Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K. For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 3.3 V ± 0.3 V - - 100 ns/V VCC = 5.0 V ± 0.5 V - - 20 ns/V 74AHC3GU04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 February 2019 © Nexperia B.V. 2019. All rights reserved 3 / 13 74AHC3GU04-Q100 Nexperia Triple unbuffered inverter 10. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.7 - - 1.7 - 1.7 - V VCC = 3.0 V 2.4 - - 2.4 - 2.4 - V VCC = 5.5 V 4.4 - - 4.4 - 4.4 - V VCC = 2.0 V - - 0.3 - 0.3 - 0.3 V VCC = 3.0 V - - 0.6 - 0.6 - 0.6 V VCC = 5.5 V - - 1.1 - 1.1 - 1.1 V IO = -50 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -50 μA; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = -50 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = -8.0 mA; VCC = 4.5 V 3.94 - - 3.8 - 3.70 - V IO = 50 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 μA; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V VI = VIH or VIL VI = VIH or VIL II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 0.1 - 1.0 - 2.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.0 - 10 - 40 μA CI input capacitance - 3.0 10 - 10 - 10 pF 74AHC3GU04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 February 2019 © Nexperia B.V. 2019. All rights reserved 4 / 13 74AHC3GU04-Q100 Nexperia Triple unbuffered inverter 10.1. Typical transfer characteristics mna397 2.0 VO (V) 1.6 mna398 1.0 VO ICC (mA) 0.8 1.2 0.6 0.8 0.4 3.0 10 VO VO (V) 8 ICC (mA) 6 1.5 0.4 ID (drain current) 0 4 ID (drain current) 0.2 0 0 0 0.4 0.8 1.2 1.6 VI (V) 2 0 0 2.0 a. VCC = 2.0 V; IO = 0 A 1 2 VI (V) 3 b. VCC = 3.0 V; IO = 0 A mna399 6 50 VO (V) ICC (mA) 40 VO 30 3 20 ID (drain current) 10 0 0 0 2 4 VI (V) 6 c. VCC = 5.5 V; IO = 0 A Fig. 5. Typical transfer characteristic 74AHC3GU04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 February 2019 © Nexperia B.V. 2019. All rights reserved 5 / 13 74AHC3GU04-Q100 Nexperia Triple unbuffered inverter mna400 40 gfs (mA/V) 30 Rbias = 560 kΩ 20 VCC 0.47 µF 10 input output 100 µF VI (f = 1 kHz) 0 Fig. 6. A IO GND 0 2 4 VCC (V) mna050 6 Typical forward transconductance gfs as a function of the supply voltage at Tamb = 25 °C gfs = ΔIO/ΔVI at VO is constant Fig. 7. Test set-up for measuring forward transconductance 11. Dynamic characteristics Table 8. Dynamic characteristics GND = 0 V; For test circuit see Fig. 9. Symbol Parameter tpd CPD [1] [2] [3] [4] propagation delay power dissipation capacitance Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 3.0 V to 3.6 V; CL = 15 pF [2] - 3.0 7.1 1.0 8.5 1.0 10.0 ns VCC = 3.0 V to 3.6 V; CL = 50 pF [2] - 4.3 10.6 1.0 12.0 1.0 13.5 ns VCC = 4.5 V to 5.5 V; CL = 15 pF [3] - 2.5 5.5 1.0 6.0 1.0 7.0 ns VCC = 4.5 V to 5.5 V; CL = 50 pF [3] - 3.5 7.0 1.0 8.0 1.0 9.0 ns - 4 - - - - - pF nA to nY; see Fig. 8 [1] per buffer; VI = GND to VCC [4] tpd is the same as tPLH and tPHL. Typical values are measured at VCC = 3.3 V. Typical values are measured at VCC = 5.0 V. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. 74AHC3GU04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 February 2019 © Nexperia B.V. 2019. All rights reserved 6 / 13 74AHC3GU04-Q100 Nexperia Triple unbuffered inverter 11.1. Waveforms and test circuit VI VM nA input VM GND t PHL t PLH VOH VM nY output VM VOL mna344 Measurement points are given in Table 9. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 8. The input (nA) to output (nY) propagation delays. Table 9. Measurement points Input Output VM VM 0.5VCC 0.5VCC VI negative pulse tW 90 % VM VM 10 % 0V tf tr VI positive pulse 0V tr tf 90 % VM VM 10 % tW VCC G VI DUT VCC VO RL RT S1 open CL 001aad983 Test data is given in Table 10. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig. 9. Test circuit for measuring switching times Table 10. Test data Input Load VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ VCC ≤ 3 ns 15 pF, 50 pF 1 kΩ open GND VCC 74AHC3GU04_Q100 Product data sheet S1 position All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 February 2019 © Nexperia B.V. 2019. All rights reserved 7 / 13 74AHC3GU04-Q100 Nexperia Triple unbuffered inverter 12. Application information Some applications are: • • Linear amplifier (see Fig. 10) In crystal oscillator design (see Fig. 11) Remark: All values given are typical unless otherwise specified. R2 VCC 1 µF R1 R1 U04 ZL R2 U04 mna052 out Maximum Vo(p-p) = VCC - 1.5 V centered at 0.5 × VCC. C2 mna053 C1 = 47 pF (typ.) C2 = 22 pF (typ.) R1 = 1 MΩ to 10 MΩ (typ.) R2 optimum value depends on the frequency and required stability against changes in VCC or average minimum ICC (ICC is typically 2 mA at VCC = 3 V and f = 1 MHz). Gol = open loop gain Gv = voltage gain R1 ≥ 3 kΩ, R2 ≤ 1 MΩ ZL > 10 kΩ; Gol = 20 (typ.) Typical unity gain bandwidth product is 5 MHz. Fig. 10. Used as a linear amplifier C1 Fig. 11. Crystal oscillator configuration Table 11. External components for resonator (f < 1 MHz) All values given are typical and must be used as an initial set-up. Frequency R1 R2 C1 C2 10 kHz to 15.9 kHz 22 MΩ 220 kΩ 56 pF 20 pF 16 kHz to 24.9 kHz 22 MΩ 220 kΩ 56 pF 10 pF 25 kHz to 54.9 kHz 22 MΩ 100 kΩ 56 pF 10 pF 55 kHz to 129.9 kHz 22 MΩ 100 kΩ 47 pF 5 pF 130 kHz to 199.9 kHz 22 MΩ 47 kΩ 47 pF 5 pF 200 kHz to 349.9 kHz 22 MΩ 47 kΩ 47 pF 5 pF 350 kHz to 600 kHz 22 MΩ 47 kΩ 47 pF 5 pF Table 12. Optimum value for R2 Frequency R2 3 kHz 6 kHz 10 kHz 14 kHz >14 kHz 74AHC3GU04_Q100 Product data sheet Optimum for 2.0 kΩ minimum required ICC 8.0 kΩ minimum influence due to change in VCC 1.0 kΩ minimum required ICC 4.7 kΩ minimum influence by VCC 0.5 kΩ minimum required ICC 2.0 kΩ minimum influence by VCC 0.5 kΩ minimum required ICC 1.0 kΩ minimum influence by VCC - replace R2 by C3 with a typical value of 35 pF All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 February 2019 © Nexperia B.V. 2019. All rights reserved 8 / 13 74AHC3GU04-Q100 Nexperia Triple unbuffered inverter 13. Package outline TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm D E A SOT505-2 X c HE y v M A Z 5 8 A A2 pin 1 index (A3) A1 θ Lp L 1 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e HE L Lp v w y Z(1) θ mm 1.1 0.15 0.00 0.95 0.75 0.25 0.38 0.22 0.18 0.08 3.1 2.9 3.1 2.9 0.65 4.1 3.9 0.5 0.47 0.33 0.2 0.13 0.1 0.70 0.35 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT505-2 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 02-01-16 --- Fig. 12. Package outline SOT505-2 (TSSOP8) 74AHC3GU04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 February 2019 © Nexperia B.V. 2019. All rights reserved 9 / 13 74AHC3GU04-Q100 Nexperia Triple unbuffered inverter VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm A max. max nom min 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v w y 0.2 0.08 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Fig. 13. Package outline SOT765-1 (VSSOP8) 74AHC3GU04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 February 2019 © Nexperia B.V. 2019. All rights reserved 10 / 13 74AHC3GU04-Q100 Nexperia Triple unbuffered inverter 14. Abbreviations Table 13. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model 15. Revision history Table 14. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AHC3GU04_Q100 v.2 20190227 Product data sheet - Modifications: • • • 74AHC3GU04_Q100 v.1 74AHC3GU04_Q100 Product data sheet 74AHC3GU04_Q100 v.1 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Package outline drawing SOT765-1 (VSSOP8) updated 20131118 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 February 2019 - © Nexperia B.V. 2019. All rights reserved 11 / 13 74AHC3GU04-Q100 Nexperia Triple unbuffered inverter equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 16. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or 74AHC3GU04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 February 2019 © Nexperia B.V. 2019. All rights reserved 12 / 13 74AHC3GU04-Q100 Nexperia Triple unbuffered inverter Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Marking.......................................................................... 1 5. Functional diagram.......................................................2 6. Pinning information......................................................2 6.1. Pinning.........................................................................2 6.2. Pin description............................................................. 2 7. Functional description................................................. 2 8. Limiting values............................................................. 3 9. Recommended operating conditions..........................3 10. Static characteristics..................................................4 10.1. Typical transfer characteristics.................................. 5 11. Dynamic characteristics.............................................6 11.1. Waveforms and test circuit........................................ 7 12. Application information............................................. 8 13. Package outline.......................................................... 9 14. Abbreviations............................................................ 11 15. Revision history........................................................11 16. Legal information......................................................12 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 27 February 2019 74AHC3GU04_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 February 2019 © Nexperia B.V. 2019. All rights reserved 13 / 13 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74AHC3GU04DP-Q100H 74AHC3GU04DC-Q100H
74AHC3GU04DC-Q100H 价格&库存
很抱歉,暂时无法提供与“74AHC3GU04DC-Q100H”相匹配的价格&库存,您可以联系我们找货
