74ALVC541BQ-Q100X
74ALVC541BQ-Q100X
    NEXPERIA(安世)
    QFN20_EP
    类型:缓冲器,非反相 电源电压:1.65V~3.6V 输出类型:三态 低电平输出电流(IOL):24mA 高电平输出电流(IOH):24mA 工作温度:-40℃~+85℃
74ALVC541BQ-Q100X 数据手册
74ALVC541-Q100 Octal buffer/line driver; 3-state Rev. 1 — 19 May 2014 Product data sheet 1. General description The 74ALVC541-Q100 is an octal non-inverting buffer/line driver with 3-state bus compatible outputs. The output enable inputs OE0 and OE1, control the 3-state outputs. A HIGH on OEn causes the outputs to assume a high-impedance OFF-state. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 3) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 3)  Specified from 40 C to +85 C  Wide supply voltage range from 1.65 V to 3.6 V  3.6 V tolerant inputs/outputs  CMOS LOW power consumption  Direct interface with TTL levels (2.7 V to 3.6 V)  Power-down mode  Latch-up performance exceeds 250 mA  Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.5 V)  JESD8B/JESD36 (2.7 V to 3.6 V)  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 ) 74ALVC541-Q100 Nexperia Octal buffer/line driver; 3-state 3. Ordering information Table 1. Ordering information Type number Package 74ALVC541D-Q100 Temperature range Name Description Version 40 C to +85 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 TSSOP20 plastic thin shrink small outline package; 20 leads; SOT360-1 body width 4.4 mm 74ALVC541PW-Q100 40 C to +85 C 74ALVC541BQ-Q100 40 C to +85 C DHVQFN20 plastic dual-in-line compatible thermal enhanced SOT764-1 very thin quad flat package no leads; 20 terminals; body 2.5  4.5  0.85 mm 4. Functional diagram      $
74ALVC541BQ-Q100X 价格&库存
很抱歉,暂时无法提供与“74ALVC541BQ-Q100X”相匹配的价格&库存,您可以联系我们找货
