74ALVC541-Q100
Octal buffer/line driver; 3-state
Rev. 1 — 19 May 2014
Product data sheet
1. General description
The 74ALVC541-Q100 is an octal non-inverting buffer/line driver with 3-state bus
compatible outputs. The output enable inputs OE0 and OE1, control the 3-state outputs.
A HIGH on OEn causes the outputs to assume a high-impedance OFF-state.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 3) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 3)
Specified from 40 C to +85 C
Wide supply voltage range from 1.65 V to 3.6 V
3.6 V tolerant inputs/outputs
CMOS LOW power consumption
Direct interface with TTL levels (2.7 V to 3.6 V)
Power-down mode
Latch-up performance exceeds 250 mA
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.5 V)
JESD8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
74ALVC541-Q100
Nexperia
3. Ordering information
Table 1.
Type number
Package
74ALVC541D-Q100
Temperature range Name
Description
Version
40 C to +85 C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
TSSOP20
plastic thin shrink small outline package; 20 leads; SOT360-1
body width 4.4 mm
74ALVC541PW-Q100 40 C to +85 C
74ALVC541BQ-Q100
40 C to +85 C
DHVQFN20 plastic dual-in-line compatible thermal enhanced SOT764-1
very thin quad flat package no leads; 20 terminals;
body 2.5 4.5 0.85 mm
4. Functional diagram
很抱歉,暂时无法提供与“74ALVC541D-Q100J”相匹配的价格&库存,您可以联系我们找货
