74HC2G17; 74HCT2G17
Dual non-inverting Schmitt trigger
Rev. 01 — 6 October 2006
Product data sheet
1. General description
The 74HC2G17; 74HCT2G17 is a high-speed Si-gate CMOS device.
The 74HC2G17; 74HCT2G17 provides two non-inverting Schmitt trigger buffers. They are
capable of transforming slowly changing input signals into sharply defined, jitter-free
output signals.
The inputs switch at different points for positive and negative-going signals. The difference
between the positive voltage VT+ and the negative voltage VT− is defined as the input
hysteresis voltage VH.
2. Features
n
n
n
n
n
n
n
n
n
Wide supply voltage range from 2.0 V to 6.0 V
Complies with JEDEC standard no. 7A
High noise immunity
ESD protection:
u HBM JESD22-A114-D exceeds 2000 V
u MM JESD22-A115-A exceeds 200 V
Low power dissipation
Balanced propagation delays
Unlimited input rise and fall times
Multiple package options
Specified from −40 °C to +85 °C and −40 °C to +125 °C
3. Applications
n Wave and pulse shaper for highly noisy environments
n Astable multivibrators
n Monostable multivibrators
74HC2G17; 74HCT2G17
Nexperia
4. Ordering information
Table 1.
Type number
Package
74HC2G17GW
Temperature range Name
Description
Version
−40 °C to +125 °C
plastic surface-mounted package; 6 leads
SOT363
SC-88
74HC2G17GV
−40 °C to +125 °C
SC-74
plastic surface-mounted package (TSOP6); 6 leads
SOT457
74HCT2G17GW
−40 °C to +125 °C
SC-88
SOT363
74HCT2G17GV
−40 °C to +125 °C
SC-74
SOT457
5. Marking
Table 2.
Marking
Type number
Marking code
74HC2G17GW
HV
74HC2G17GV
HV
74HCT2G17GW
TV
74HCT2G17GV
TV
6. Functional diagram
1
1A
1Y
6
3
2A
2Y
4
1
6
3
4
mnb067
mnb066
Fig 1. Logic symbol
Fig 2. IEC logic symbol
1A
1Y
2A
2Y
mnb068
Fig 3. Logic diagram
74HC_HCT2G17_1
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 18
74HC2G17; 74HCT2G17
Nexperia
7. Pinning information
7.1 Pinning
74HC2G17
74HCT2G17
1A
1
6
1Y
GND
2
5
VCC
2A
3
4
2Y
001aaf201
Fig 4. Pin configuration
7.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
1A
1
data input
GND
2
ground (0 V)
2A
3
data input
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
8. Functional description
Table 4.
Function table[1]
Input
Output
nA
nY
L
L
H
H
[1]
H = HIGH voltage level;
L = LOW voltage level.
74HC_HCT2G17_1
Product data sheet
3 of 18
74HC2G17; 74HCT2G17
Nexperia
9. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
−0.5
+7.0
V
IIK
input clamping current
VI < −0.5 V or VI > VCC + 0.5 V
[1]
±20
mA
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
±20
mA
output current
VO = −0.5 V to VCC + 0.5 V
[1]
±25
mA
supply current
[1]
50
mA
IGND
ground current
[1]
Tstg
storage temperature
IO
ICC
[2]
total power dissipation
Ptot
−50
mA
−65
+150
°C
250
mW
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SC-88 and SC-74 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
10. Recommended operating conditions
Table 6.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Type 74HC2G17
VCC
supply voltage
2.0
5.0
6.0
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
4.5
5.0
5.5
V
Type 74HCT2G17
VCC
supply voltage
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
11. Static characteristics
Table 7.
Static characteristics for 74HC2G17
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
HIGH-level output voltage
VI = VIH or VIL
IO = −20 µA; VCC = 2.0 V
1.9
2.0
V
IO = −20 µA; VCC = 4.5 V
4.4
4.5
V
Tamb = 25 °C
VOH
IO = −20 µA; VCC = 6.0 V
5.9
6.0
V
IO = −4.0 mA; VCC = 4.5 V
4.18
4.32
V
IO = −5.2 mA; VCC = 6.0 V
5.68
5.81
V
74HC_HCT2G17_1
Product data sheet
4 of 18
74HC2G17; 74HCT2G17
Nexperia
Table 7.
Static characteristics for 74HC2G17 …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VOL
LOW-level output voltage
VI = VIH or VIL
IO = 20 µA; VCC = 2.0 V
V
IO = 20 µA; VCC = 4.5 V
V
IO = 20 µA; VCC = 6.0 V
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
V
II
input leakage current
VI = GND or VCC; VCC = 6.0 V
±0.1
µA
ICC
supply current
VI = GND or VCC; IO = 0 A;
VCC = 6.0 V
1.0
µA
CI
input capacitance
2.0
pF
1.9
V
4.4
V
Tamb = −40 °C to +85 °C
VOH
VOL
VI = VIH or VIL
5.9
V
4.13
V
5.63
V
VI = VIH or VIL
0.1
V
0.1
V
0.1
V
0.33
V
0.33
V
II
±1.0
µA
ICC
supply current
VCC = 6.0 V
10.0
µA
1.9
V
4.4
V
Tamb = −40 °C to +125 °C
VOH
VI = VIH or VIL
5.9
V
3.7
V
5.2
V
74HC_HCT2G17_1
Product data sheet
5 of 18
74HC2G17; 74HCT2G17
Nexperia
Table 7.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VOL
VI = VIH or VIL
0.1
V
0.1
V
0.1
V
0.4
V
0.4
V
II
±1.0
µA
ICC
supply current
VCC = 6.0 V
20.0
µA
Table 8.
Static characteristics for 74HCT2G17
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VI = VIH or VIL; VCC = 4.5 V
IO = −20 µA
4.4
4.5
V
IO = −4.0 mA
4.18
4.32
V
V
Tamb = 25 °C
VOH
VOL
IO = −20 µA
IO = −4.0 mA
0.15
0.26
V
II
VI = GND or VCC; VCC = 5.5 V
±0.1
µA
ICC
supply current
VCC = 5.5 V
1.0
µA
∆ICC
additional supply current
VI = VCC − 2.1 V;
VCC = 4.5 V to 5.5 V; IO = 0 A
300
µA
CI
input capacitance
2.0
pF
IO = −20 µA
4.4
V
IO = −4.0 mA
4.13
V
IO = −20 µA
0.1
V
IO = −4.0 mA
0.33
V
VOH
VOL
II
±1.0
µA
ICC
supply current
VCC = 5.5 V
10.0
µA
∆ICC
VI = VCC − 2.1 V;
375
µA
74HC_HCT2G17_1
Product data sheet
6 of 18
74HC2G17; 74HCT2G17
Nexperia
Table 8.
Static characteristics for 74HCT2G17 …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
IO = −20 µA
4.4
V
IO = −4.0 mA
3.7
V
0.1
V
VOH
VOL
IO = −20 µA
IO = −4.0 mA
0.4
V
II
±1.0
µA
ICC
supply current
VCC = 5.5 V
20.0
µA
∆ICC
VI = VCC − 2.1 V;
410
µA
12. Dynamic characteristics
Table 9.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6.
Symbol
Parameter
25 °C
Conditions
−40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
(85 °C)
Max
(125 °C)
VCC = 2.0 V; CL = 50 pF
36
115
140
175
ns
VCC = 4.5 V; CL = 50 pF
12
22
27
34
ns
VCC = 6.0 V; CL = 50 pF
10
18
22
28
ns
95
110
ns
7
15
19
22
ns
5
13
16
19
ns
10
pF
74HC2G17
tpd
tt
CPD
propagation delay
transition time
power dissipation
capacitance
nA to nY; see Figure 5
nY; see Figure 5
VI = GND to VCC
[1]
[2]
[3]
74HC_HCT2G17_1
Product data sheet
7 of 18
74HC2G17; 74HCT2G17
Nexperia
Table 9.
Dynamic characteristics …continued
Symbol
Parameter
25 °C
Conditions
−40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
(85 °C)
Max
(125 °C)
21
29
36
45
6
15
19
22
ns
10
pF
74HCT2G17
propagation delay
tpd
[1]
tt
transition time
CPD
power dissipation
capacitance
ns
[2]
nY; see Figure 5
VI = GND to VCC − 1.5 V
[3]
[1]
tpd is the same as tPLH and tPHL
[2]
tt is the same as tTLH and tTHL
[3]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of the outputs.
13. Waveforms
VI
VM
VM
nA input
GND
tPLH
VOH
90 %
tPHL
90 %
nY output
VOL
10 %
10 %
tTLH
tTHL
001aaf302
Measurement points are given in Table 10.
VOL and VOH are typical voltage output drop that occur with the output load.
Fig 5. The data input (nA) to output (nY) propagation delays and output transition times
Table 10.
Measurement points
Type
Input
Output
VM
VI
tr = tf
VM
74HC2G17
0.5VCC
GND to VCC
6.0 ns
0.5VCC
74HCT2G17
1.3 V
GND to 3.0 V
6.0 ns
1.3 V
74HC_HCT2G17_1
Product data sheet
8 of 18
74HC2G17; 74HCT2G17
Nexperia
VCC
VCC
PULSE
GENERATOR
VI
VO
RL = 1 kΩ
open
D.U.T
RT
CL
50 pF
mgk563
Test data is given in Table 11.
Definitions test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig 6. Load circuitry for switching times
Table 11.
Test data
Type
Input
Test
VI
tr, tf
tPHL, tPLH
74HC2G17
GND to VCC
6 ns
open
74HCT2G17
GND to 3.0 V
6 ns
open
14. Transfer characteristics
Table 12. Transfer characteristics
Symbol Parameter
25 °C
Conditions
−40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
(85 °C)
Max
(125 °C)
VCC = 2.0 V
1.00
1.18
1.50
1.00
1.50
1.50
V
VCC = 4.5 V
2.30
2.60
3.15
2.30
3.15
3.15
V
VCC = 6.0 V
3.00
3.46
4.20
3.00
4.20
4.20
V
VCC = 2.0 V
0.30
0.60
0.90
0.30
0.90
0.90
V
VCC = 4.5 V
1.13
1.47
2.00
1.13
2.00
2.00
V
VCC = 6.0 V
1.50
2.06
2.60
1.50
2.60
2.60
V
VCC = 2.0 V
0.30
0.60
1.00
0.30
1.00
1.00
V
VCC = 4.5 V
0.60
1.13
1.40
0.60
1.40
1.40
V
VCC = 6.0 V
0.80
1.40
1.70
0.80
1.70
1.70
V
74HC2G17
VT+
VT−
VH
positive-going
threshold voltage
negative-going
threshold voltage
hysteresis voltage
see Figure 7, Figure 8
VT+ − VT−; see Figure 7,
Figure 8 and Figure 9
74HC_HCT2G17_1
Product data sheet
9 of 18
74HC2G17; 74HCT2G17
Nexperia
Table 12. Transfer characteristics …continued
Symbol Parameter
25 °C
Conditions
−40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
(85 °C)
Max
(125 °C)
VCC = 4.5 V
1.20
1.58
1.90
1.20
1.90
1.90
V
VCC = 5.5 V
1.40
1.78
2.10
1.40
2.10
2.10
V
VCC = 4.5 V
0.50
0.87
1.20
0.50
1.20
1.20
V
VCC = 5.5 V
0.60
1.11
1.40
0.60
1.40
1.40
V
VCC = 4.5 V
0.40
0.71
0.40
V
VCC = 5.5 V
0.40
0.67
0.40
V
74HCT2G17
VT+
VT−
VH
positive-going
threshold voltage
see Figure 7 and Figure 8
negative-going
threshold voltage
Figure 8 and Figure 10
hysteresis voltage
15. Waveforms transfer characteristics
VO
VI
VT+
VH
VT−
VO
VI
VH
VT−
VT+
Fig 7. Transfer characteristic
mnb154
mnb155
VT+ and VT- limits at 70 % and 20 %.
Fig 8. Definition of VT+, VT- and VH
74HC_HCT2G17_1
Product data sheet
10 of 18
74HC2G17; 74HCT2G17
Nexperia
mna028
100
mna029
1.0
ICC
(mA)
ICC
(µA)
0.8
0.6
50
0.4
0.2
VI (V)
2.5
a. VCC = 2.0 V
VI (V)
5.0
b. VCC = 4.5 V
mna030
1.6
ICC
(mA)
0.8
c.
3.0
VI (V)
6.0
VCC = 6.0 V
Fig 9. Typical 74HC2G17 transfer characteristics
74HC_HCT2G17_1
Product data sheet
11 of 18
74HC2G17; 74HCT2G17
Nexperia
mna031
2.0
mna032
3.0
ICC
(mA)
ICC
(mA)
2.0
1.0
1.0
VI (V)
a. VCC = 4.5 V.
3.0
VI (V)
6.0
b. VCC = 5.5 V.
Fig 10. Typical 74HCT2G17 transfer characteristics
16. Application information
The slow input rise and fall times cause additional power dissipation, this can be
calculated using the following formula:
Padd = fi × (tr × ∆ICC(AV) + tf × ∆ICC(AV)) × VCC where:
Padd = additional power dissipation (µW);
fi = input frequency (MHz);
tr = input rise time (ns); 10 % to 90 %;
tf = input fall time (ns); 90 % to 10 %;
∆ICC(AV) = average additional supply current (µA).
∆ICC(AV) differs with positive or negative input transitions, as shown in Figure 11 and
Figure 12.
74HC_HCT2G17_1
Product data sheet
12 of 18
74HC2G17; 74HCT2G17
Nexperia
mna036
200
∆ICC(AV)
(mA)
150
positive-going
edge
100
50
negative-going
edge
4.0
VCC (V)
6.0
Fig 11. ∆ICC(AV) as a function of VCC for 74HC2G17; linear change of VI between 0.1VCC to 0.9VCC
mna058
200
∆ICC(AV)
(µA)
150
positive-going
edge
100
negative-going
edge
50
4
VCC (V)
6
Fig 12. ∆ICC(AV) as a function of VCC for 74HCT2G17; linear change of VI between 0.1VCC to 0.9VCC
74HC_HCT2G17_1
Product data sheet
13 of 18
74HC2G17; 74HCT2G17
Nexperia
17. Package outline
Plastic surface-mounted package; 6 leads
SOT363
D
E
B
y
X
A
HE
6
5
v M A
4
Q
pin 1
index
A
A1
1
2
e1
3
bp
c
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.1
0.8
0.1
0.30
0.20
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.25
0.15
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
SOT363
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-08
06-03-16
SC-88
Fig 13. Package outline SOT363 (SC-88)
74HC_HCT2G17_1
Product data sheet
14 of 18
74HC2G17; 74HCT2G17
Nexperia
Plastic surface-mounted package (TSOP6); 6 leads
D
SOT457
E
B
y
A
HE
6
5
X
v M A
4
Q
pin 1
index
A
A1
c
1
2
3
Lp
bp
e
w M B
detail X
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.1
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
SOT457
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-11-07
06-03-16
SC-74
Fig 14. Package outline SOT457 (SC-74)
74HC_HCT2G17_1
Product data sheet
15 of 18
74HC2G17; 74HCT2G17
Nexperia
18. Abbreviations
Table 13.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
DUT
Device Under Test
19. Revision history
Table 14.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT2G17_1
20061006
Product data sheet
74HC_HCT2G17_1
Product data sheet
16 of 18
74HC2G17; 74HCT2G17
Nexperia
20. Legal information
20.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
20.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
20.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected to
result in personal injury, death or severe property or environmental damage.
Nexperia accepts no liability for inclusion and/or use of Nexperia
products in such equipment or applications and therefore
such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
20.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
21. Contact information
For additional information, please visit: http://www.nexperia.com
For sales office addresses, send an email to: salesaddresses@nexperia.com
74HC_HCT2G17_1
Product data sheet
17 of 18
Nexperia
74HC2G17; 74HCT2G17
22. Contents
1
2
3
4
5
6
7
7.1
7.2
8
9
10
11
12
13
14
15
16
17
18
19
20.2
20.3
20.4
21
22
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Transfer characteristics. . . . . . . . . . . . . . . . . . . 9
Waveforms transfer characteristics . . . . . . . . 10
Application information. . . . . . . . . . . . . . . . . . 12
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 14
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16
Legal information. . . . . . . . . . . . . . . . . . . . . . . 17
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Contact information. . . . . . . . . . . . . . . . . . . . . 17
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 06 October 2006
很抱歉,暂时无法提供与“74HCT2G17GV,125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.674593000+0.08178
- 9000+0.671449000+0.08140
- 12000+0.6714212000+0.08140
- 30000+0.6714130000+0.08140
- 45000+0.6713945000+0.08139
- 国内价格
- 1+1.91160
- 10+1.74960
- 30+1.71720
