74LVC1G34GV-Q100H
74LVC1G34GV-Q100H
    NEXPERIA(安世)
    SOT23-5
    IC BUFFER NON-INVERT 5.5V SC74A
74LVC1G34GV-Q100H 数据手册
74LVC1G34-Q100 Single buffer Rev. 2 — 9 December 2016 Product data sheet 1. General description The 74LVC1G34-Q100 provides a low-power, low-voltage single buffer. The input can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device in a mixed 3.3 V and 5 V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. Schmitt trigger action at all inputs makes the circuit highly tolerant of slower input rise and fall times. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide supply voltage range from 1.65 V to 5.5 V  5 V tolerant inputs for interfacing with 5 V logic  High noise immunity  Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8-B/JESD36 (2.7 V to 3.6 V).  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  24 mA output drive (VCC = 3.0 V)  CMOS low power consumption  Latch-up performance exceeds 250 mA  Direct interface with TTL levels  Inputs accept voltages up to 5 V  Multiple package options 74LVC1G34-Q100 Nexperia Single buffer 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G34GW-Q100 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1G34GV-Q100 40 C to +125 C SC-74A plastic surface-mounted package; 5 leads SOT753 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G34GW-Q100 YN 74LVC1G34GV-Q100 YN [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram  $ <    $ DDF Fig 1. Logic symbol < DDF DDF Fig 2. IEC logic symbol Fig 3. Logic diagram 6. Pinning information 6.1 Pinning /9&*4 QF  $  *1'   9&&  < DDD Fig 4. Pin configuration SOT353-1 and SOT753 74LVC1G34_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 2 of 13 74LVC1G34-Q100 Nexperia Single buffer 6.2 Pin description Table 3. Pin description Symbol Pin Description n.c. 1 not connected A 2 data input GND 3 ground (0 V) Y 4 data output VCC 5 supply voltage 7. Functional description Table 4. Function table[1] Input Output A Y L L H H [1] H = HIGH voltage level; L = LOW voltage level. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current output voltage VO IO output current ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature Conditions VI < 0 V [1] Min Max Unit 0.5 +6.5 V 50 - 0.5 +6.5 V mA - 50 Active mode [1][2] 0.5 VCC + 0.5 V Power-down mode [1][2] 0.5 +6.5 V - 50 mA - 100 mA 100 - mA - 250 mW 65 +150 C VO > VCC or VO < 0 V VO = 0 V to VCC Tamb = 40 C to +125 C [3] [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. 74LVC1G34_Q100 Product data sheet mA All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 13 74LVC1G34-Q100 Nexperia Single buffer 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature t/V input transition rise and fall rate Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC VO VCC = 0 V; Power-down mode 0 - 5.5 VO 40 - +125 C VCC = 1.65 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 5.5 V - - 10 ns/V Min Typ Max 0.65  VCC - - V 10. Static characteristics Table 7. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 VIH VIL VOH Conditions HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VCC = 1.65 V to 1.95 V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - LOW-level output voltage 74LVC1G34_Q100 Product data sheet 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V VOL Unit C[1] VCC  0.1 - - V IO = 4 mA; VCC = 1.65 V 1.2 1.54 - V IO = 8 mA; VCC = 2.3 V 1.9 2.15 - V IO = 12 mA; VCC = 2.7 V 2.2 2.50 - V IO = 24 mA; VCC = 3.0 V 2.3 2.62 - V IO = 32 mA; VCC = 4.5 V 3.8 4.11 - V IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.10 V IO = 4 mA; VCC = 1.65 V - 0.07 0.45 V IO = 8 mA; VCC = 2.3 V - 0.12 0.30 V IO = 12 mA; VCC = 2.7 V - 0.17 0.40 V IO = 24 mA; VCC = 3.0 V - 0.33 0.55 V IO = 32 mA; VCC = 4.5 V - 0.39 0.55 V VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 13 74LVC1G34-Q100 Nexperia Single buffer Table 7. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions [2] Min Typ Max Unit - 0.1 1 A II input leakage current VCC = 0 V to 5.5 V; VI = 5.5 V or GND IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - 0.1 2 A ICC supply current VCC = 1.65 V to 5.5 V; IO = 0 A; VI = 5.5 V or GND - 0.1 4 A ICC additional supply current VCC = 2.3 V to 5.5 V; VI = VCC  0.6 V; IO = 0 A - 5 500 A CI input capacitance VCC = 3.3 V; VI = GND to VCC - 4 - pF 0.65  VCC - - V 1.7 - - V [2] Tamb = 40 C to +125 C HIGH-level input voltage VIH VCC = 1.65 V to 1.95 V VCC = 2.3 V to 2.7 V LOW-level input voltage VIL VOH HIGH-level output voltage VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V VCC  0.1 - - V IO = 4 mA; VCC = 1.65 V 0.95 - - V IO = 8 mA; VCC = 2.3 V 1.7 - - V IO = 12 mA; VCC = 2.7 V 1.9 - - V IO = 24 mA; VCC = 3.0 V 2.0 - - V LOW-level output voltage IO = 32 mA; VCC = 4.5 V 3.4 - - V IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.10 V IO = 4 mA; VCC = 1.65 V - - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.80 V 0.7 V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V VOL 0.35  VCC V VI = VIH or VIL II input leakage current VCC = 0 V to 5.5 V; VI = 5.5 V or GND - - 1 A IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - - 2 A ICC supply current VCC = 1.65 V to 5.5 V; IO = 0 A; VI = 5.5 V or GND - - 4 A ICC additional supply current VCC = 2.3 V to 5.5 V; VI = VCC  0.6 V; IO = 0 A - - 500 A [1] All typical values are measured at Tamb = 25 C. [2] These typical values are measured at VCC = 3.3 V. 74LVC1G34_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 13 74LVC1G34-Q100 Nexperia Single buffer 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 6. Symbol Parameter 40 C to +85 C Conditions power dissipation capacitance CPD Unit Min Max Min Max VCC = 1.65 V to 1.95 V 1.0 4.0 8.6 1.0 11.0 ns VCC = 2.3 V to 2.7 V 0.5 2.6 4.4 0.5 5.6 ns VCC = 2.7 V 0.5 2.3 4.5 0.5 5.6 ns VCC = 3.0 V to 3.6 V 0.5 2.0 4.1 0.5 5.2 ns VCC = 4.5 V to 5.5 V 0.5 1.6 3.2 0.5 4.1 ns - 15 - - - pF [2] propagation delay A to Y; see Figure 5 tpd 40 C to +125 C Typ[1] [3] VI = GND to VCC; VCC = 3.3 V [1] Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V, and 5.0 V respectively. [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 12. Waveforms 9, 90 $LQSXW *1' W 3+/ W 3/+ 92+ 90
74LVC1G34GV-Q100H 价格&库存
很抱歉,暂时无法提供与“74LVC1G34GV-Q100H”相匹配的价格&库存,您可以联系我们找货
