74HC3G34DP-Q100H
74HC3G34DP-Q100H
    NEXPERIA(安世)
    TSSOP8_3X3MM
    类型:缓冲器,非反相 电源电压:2V~6V 输出类型:推挽 低电平输出电流(IOL):5.2mA 高电平输出电流(IOH):5.2mA
74HC3G34DP-Q100H 数据手册
74HC3G34-Q100; 74HCT3G34-Q100 Triple buffer gate Rev. 2 — 11 June 2018 1 Product data sheet General description The 74HC3G34-Q100; 74HCT3G34-Q100 is a triple buffer. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2 Features and benefits • Automotive product qualification in accordance with AEC-Q100 (Grade 1) – Specified from -40 °C to +85 °C and from -40 °C to +125 °C • Wide supply voltage range from 2.0 V to 6.0 V • Input levels: – For 74HC3G34-Q100: CMOS level – For 74HCT3G34-Q100: TTL level • Complies with JEDEC standard no. 7 A • Symmetrical output impedance • High noise immunity • Low-power dissipation • Balanced propagation delays • Multiple package options • ESD protection: – MIL-STD-883, method 3015 exceeds 2000 V – HBM JESD22-A114F exceeds 2000 V – MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) 3 Ordering information Table 1. Ordering information Type number 74HC3G34DP-Q100 Package Temperature range Name Description Version -40 °C to +125 °C TSSOP8 plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm SOT505-2 -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; body width 2.3 mm SOT765-1 74HCT3G34DP-Q100 74HC3G34DC-Q100 74HCT3G34DC-Q100 Nexperia 74HC3G34-Q100; 74HCT3G34-Q100 Triple buffer gate 4 Marking Table 2. Marking [1] Type number Marking code 74HC3G34DP-Q100 H34 74HCT3G34DP-Q100 T34 74HC3G34DC-Q100 P34 74HCT3G34DC-Q100 U34 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5 Functional diagram 1 1A 1Y 7 2 3Y 3A 6 3 2A 2Y 5 mna744 1 7 3 1 5 6 1 2 mna745 Figure 1.  Logic symbol 6 1 Figure 2.  IEC logic symbol Pinning information 6.1 Pinning 74HC3G34-Q100 74HCT3G34-Q100 1A 1 8 VCC 3Y 2 7 1Y 2A 3 6 3A GND 4 5 2Y aaa-007610 Figure 3.  Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8) 74HC_HCT3G34_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 June 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 13 Nexperia 74HC3G34-Q100; 74HCT3G34-Q100 Triple buffer gate 6.2 Pin description Table 3. Pin description Symbol Pin Description 1A, 2A, 3A 1, 3, 6 data input 1Y, 2Y, 3Y 7, 5, 2 data output GND 4 ground (0 V) VCC 8 supply voltage 7 Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level. Input Output nA nY L L H H 8 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current Conditions Unit -0.5 +7.0 V VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA [1] - ±20 mA - ±25 mA - 50 mA -50 - mA -65 +150 °C - 300 mW output clamping current VO < -0.5 V or VO > VCC + 0.5 V IO output current VO = -0.5 V to (VCC + 0.5 V) ICC quiescent supply current IGND ground current Tstg storage temperature total power dissipation Max [1] IOK Ptot Min Tamb = -40 °C to +125 °C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K. For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K. 74HC_HCT3G34_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 June 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 13 Nexperia 74HC3G34-Q100; 74HCT3G34-Q100 Triple buffer gate 9 Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74HC3G34 74HCT3G34 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 10 Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C Min [1] Typ -40 °C to +125 °C Max Min Max Unit 74HC3G34 VIH VIL VOH VOL II HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current 74HC_HCT3G34_Q100 Product data sheet VCC = 2.0 V 1.5 1.2 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 4.13 4.32 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.63 5.81 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.33 - 0.4 V - - ±1.0 - ±1.0 μA VI = VIH or VIL VI = VIH or VIL VI = VCC or GND; VCC = 6.0 V All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 June 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 13 Nexperia 74HC3G34-Q100; 74HCT3G34-Q100 Triple buffer gate Symbol Parameter Conditions -40 °C to +85 °C Min ICC supply current per input pin; VI = VCC or GND; IO = 0 A; VCC = 6.0 V CI input capacitance [1] Typ -40 °C to +125 °C Max Min Max Unit - - 10 - 20 μA - 1.5 - - - pF 74HCT3G34 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - V IO = -4.0 mA; VCC = 4.5 V 4.13 4.32 - 3.7 - V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.33 - 0.4 V VOL LOW-level output voltage VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 10 - 20 μA ΔICC additional supply current per input; VCC = 4.5 V to 5.5 V; VI = VCC - 2.1 V; IO = 0 A - - 375 - 410 μA CI input capacitance - 1.5 - - - pF [1] All typical values are measured at Tamb = 25 °C. 11 Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 5. Symbol Parameter Conditions -40 °C to +85 °C Min [1] Typ -40 °C to +125 °C Unit Max Min Max 74HC3G34 tpd propagation delay nA to nY; see Figure 4 [2] VCC = 2.0 V - 29 95 - 125 ns VCC = 4.5 V - 9 19 - 25 ns - 8 16 - 20 ns VCC = 2.0 V - 18 95 - 125 ns VCC = 4.5 V - 6 19 - 25 ns - 5 16 - 20 ns - 10 - - - pF VCC = 6.0 V tt transition time nY; see Figure 4 [3] VCC = 6.0 V CPD power dissipation VI = GND to VCC capacitance 74HC_HCT3G34_Q100 Product data sheet [4] All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 June 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 13 Nexperia 74HC3G34-Q100; 74HCT3G34-Q100 Triple buffer gate Symbol Parameter Conditions -40 °C to +85 °C Min [1] Typ -40 °C to +125 °C Unit Max Min Max 74HCT3G34 tpd [2] propagation delay nA to nY; see Figure 4 VCC = 4.5 V tt transition time CPD [1] [2] [3] [4] nY; VCC = 4.5 V; see Figure 4 power dissipation VI = GND to VCC - 1.5 V capacitance - 10 23 - 29 ns [3] - 6 19 - 25 ns [4] - 9 - - - pF All typical values are measured at Tamb = 25 °C. tpd is the same as tPLH and tPHL. tt is the same as tTLH and tTHL. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL x VCC x fo) = sum of outputs. 11.1 Waveform and test circuit VI input nA VM VM GND t PHL t PLH VOH output nY 90 % VM VM 10 % VOL t THL t TLH 001aad982 Measurement points are given in Table 9. VOL and VOH are typical voltage output levels that occur with the output load. Figure 4.  Propagation delay data input (nA) to data output (nY) and transition time output (nY) Table 9. Measurement points Type Input Output VM VM 74HC3G34-Q100 0.5 x VCC 0.5 x VCC 74HCT3G34-Q100 1.3 V 1.3 V 74HC_HCT3G34_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 June 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 13 Nexperia 74HC3G34-Q100; 74HCT3G34-Q100 Triple buffer gate VI negative pulse tW 90 % VM VM 10 % 0V tf tr VI positive pulse 0V tr tf 90 % VM VM 10 % tW VCC VI G DUT VCC VO RT RL S1 open CL 001aad983 Test data is given in Table 10. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Figure 5.  Test circuit for measuring switching times Table 10. Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH GND to VCC ≤ 6 ns 50 pF 1 kΩ open 74HCT3G34-Q100 GND to 3 V ≤ 6 ns 50 pF 1 kΩ open 74HC3G34-Q100 74HC_HCT3G34_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 June 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 13 Nexperia 74HC3G34-Q100; 74HCT3G34-Q100 Triple buffer gate 12 Package outline TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm D E A SOT505-2 X c HE y v M A Z 5 8 A A2 pin 1 index (A3) A1 θ Lp L 1 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e HE L Lp v w y Z(1) θ mm 1.1 0.15 0.00 0.95 0.75 0.25 0.38 0.22 0.18 0.08 3.1 2.9 3.1 2.9 0.65 4.1 3.9 0.5 0.47 0.33 0.2 0.13 0.1 0.70 0.35 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT505-2 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 02-01-16 --- Figure 6.  Package outline SOT505-2 (TSSOP8) 74HC_HCT3G34_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 June 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 13 Nexperia 74HC3G34-Q100; 74HCT3G34-Q100 Triple buffer gate VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm A max. max nom min 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v 0.2 w 0.08 y 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Figure 7.  Package outline SOT765-1 (VSSOP8) 74HC_HCT3G34_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 June 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 13 Nexperia 74HC3G34-Q100; 74HCT3G34-Q100 Triple buffer gate 13 Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 14 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT3G34_Q100 v.1 20180611 Product data sheet - Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74HC_HCT3G34_Q100 v.1 20130516 74HC_HCT3G34_Q100 Product data sheet Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 June 2018 74HC_HCT3G34_Q100 v.1 - © Nexperia B.V. 2018. All rights reserved. 10 / 13 Nexperia 74HC3G34-Q100; 74HCT3G34-Q100 Triple buffer gate 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation 74HC_HCT3G34_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 June 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 13 Nexperia 74HC3G34-Q100; 74HCT3G34-Q100 Triple buffer gate Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 74HC_HCT3G34_Q100 Product data sheet 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 2 — 11 June 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 13 Nexperia 74HC3G34-Q100; 74HCT3G34-Q100 Triple buffer gate Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Marking .................................................................2 Functional diagram ............................................. 2 Pinning information ............................................ 2 Pinning ............................................................... 2 Pin description ................................................... 3 Functional description ........................................3 Limiting values .................................................... 3 Recommended operating conditions ................ 4 Static characteristics .......................................... 4 Dynamic characteristics .....................................5 Waveform and test circuit .................................. 6 Package outline ...................................................8 Abbreviations .................................................... 10 Revision history ................................................ 10 Legal information .............................................. 11 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 June 2018 Document identifier: 74HC_HCT3G34_Q100 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVCH244AD-Q100J 74HC3G34DP-Q100H 74HC3G34DC-Q100H 74HCT3G34DC-Q100H
74HC3G34DP-Q100H 价格&库存
很抱歉,暂时无法提供与“74HC3G34DP-Q100H”相匹配的价格&库存,您可以联系我们找货
