74HC151PW,118
74HC151PW,118
    NEXPERIA(安世)
    TSSOP16_5X4.4MM
    8输入多路复用器 TSSOP16_5X4.4MM 2~6V
74HC151PW,118 数据手册
74HC151; 74HCT151 8-input multiplexer Rev. 6 — 28 December 2015 Product data sheet 1. General description The 74HC151; 74HCT151 are 8-bit multiplexer with eight binary inputs (I0 to I7), three select inputs (S0 to S2) and an enable input (E). One of the eight binary inputs is selected by the select inputs and routed to the complementary outputs (Y and Y). A HIGH on E forces the output Y LOW and output Y HIGH. Inputs also include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Specified in compliance with JEDEC standard no. 7A  Input levels:  For 74HC151: CMOS level  For 74HCT151: TTL level  Low-power dissipation  Non-inverting data path  ESD protection:  HBM JESD22-A114F exceeds 2 000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description 74HC151D 40 C to +125 C SO16 plastic small outline package; 16 leads; body width SOT109-1 3.9 mm 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; SOT403-1 body width 4.4 mm 74HCT151D 74HC151DB 74HCT151DB 74HC151PW 74HCT151PW Version SOT338-1 74HC151; 74HCT151 Nexperia 8-input multiplexer 4. Functional diagram  Fig 1.         , , , , , , , , <  <  ( 6 6 6    DDD Logic symbol , , ,   ,      ,  ,  ,  ,   , , , 6 6 , , < , < , 08/7,3/(;(5 6 , ( < < DDD  Fig 2. Functional diagram 74HC_HCT151 Product data sheet 6  Fig 3. 6 6 ( DDD Logic diagram All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 December 2015 © Nexperia B.V. 2017. All rights reserved 2 of 18 74HC151; 74HCT151 Nexperia 8-input multiplexer 5. Pinning information 5.1 Pinning +& +&7 ,  ,   9&&  , ,   , ,   , <   , <   6 (   6 *1'   6 DDD Fig 4. Pin configuration SO16 and (T)SSOP16 5.2 Pin description Table 2. Pin description Symbol Pin Description I0 to I7 4, 3, 2, 1, 15, 14, 13, 12 data inputs Y 5 multiplexer output Y 6 complementary multiplexer output E 7 enable input (active LOW) GND 8 ground (0 V) S0, S1, S2 11, 10, 9 common data select inputs VCC 16 supply voltage 74HC_HCT151 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 December 2015 © Nexperia B.V. 2017. All rights reserved 3 of 18 74HC151; 74HCT151 Nexperia 8-input multiplexer 6. Functional description Function table[1] Table 3. Input Output E S2 S1 S0 I0 I1 I2 I3 I4 I5 I6 I7 Y Y H X X X X X X X X X X X H L L L L L L X X X X X X X H L L L L L H X X X X X X X L H L L L H X L X X X X X X H L L L L H X H X X X X X X L H L L H L X X L X X X X X H L L L H L X X H X X X X X L H L L H H X X X L X X X X H L L L H H X X X H X X X X L H L H L L X X X X L X X X H L L H L L X X X X H X X X L H L H L H X X X X X L X X H L L H L H X X X X X H X X L H L H H L X X X X X X L X H L L H H L X X X X X X H X L H L H H H X X X X X X X L H L L H H H X X X X X X X H L H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current IOK Conditions Min Max 0.5 +7 Unit V VI < 0.5 V or VI > VCC + 0.5 V - 20 mA output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA VO = 0.5 V to (VCC + 0.5 V) IO output current - 25 mA ICC supply current - +50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C 74HC_HCT151 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 December 2015 © Nexperia B.V. 2017. All rights reserved 4 of 18 74HC151; 74HCT151 Nexperia 8-input multiplexer Table 4. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Ptot total power dissipation Tamb = 40 C to +125 C Min Max Unit SO16 package [1] - 500 mW (T)SSOP16 package [2] - 500 mW [1] For SO16 package: Ptot derates linearly with 8 mW/K above 70 C. [2] For SSOP16 and TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC151 74HCT151 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V input voltage 0 - VCC 0 - VCC V output voltage 0 - VCC 0 - VCC V VCC supply voltage VI VO Tamb ambient temperature t/V input transition rise and fall rate 74HC_HCT151 Product data sheet 40 +25 +125 40 +25 +125 VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 December 2015 © C Nexperia B.V. 2017. All rights reserved 5 of 18 74HC151; 74HCT151 Nexperia 8-input multiplexer 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 25 C Conditions Min Typ VCC = 2.0 V 1.5 VCC = 4.5 V 3.15 VCC = 6.0 V 4.2 VCC = 2.0 V - VCC = 4.5 V - VCC = 6.0 V Tamb = 40 C to +85 C Tamb = 40 C to Unit +125 C Max Min Max Min Max 1.2 - 1.5 - 1.5 - V 2.4 - 3.15 - 3.15 - V 3.2 - 4.2 - 4.2 - V 0.8 0.5 - 0.5 - 0.5 V 2.1 1.35 - 1.35 - 1.35 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC151 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 A CI input capacitance - 3.5 - - - - - pF 74HC_HCT151 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 December 2015 © Nexperia B.V. 2017. All rights reserved 6 of 18 74HC151; 74HCT151 Nexperia 8-input multiplexer Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 25 C Conditions Min Typ Tamb = 40 C to +85 C Tamb = 40 C to Unit +125 C Max Min Max Min Max 74HCT151 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V IO = 4 mA 3.98 4.32 - 3.84 - 3.7 - V IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA - 0.15 0.26 - 0.33 - 0.4 V VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 A ICC additional supply current VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A - 45 162 - 203 - 221 A per input pin; In inputs CI input capacitance 74HC_HCT151 Product data sheet per input pin; E input - 30 108 - 135 - 147 A per input pin; Sn input - 150 540 - 675 - 735 A - 3.5 - - - - - pF All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 December 2015 © Nexperia B.V. 2017. All rights reserved 7 of 18 74HC151; 74HCT151 Nexperia 8-input multiplexer 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 7. Symbol Parameter Tamb = 25 C Conditions Tamb = 40 C to +85 C Tamb = 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 52 170 - 215 - 255 ns VCC = 4.5 V - 19 34 - 43 - 51 ns VCC = 5 V; CL = 15 pF - 17 - - - - - ns - 15 29 - 37 - 43 ns 74HC151 tpd propagation delay In to Y; see Figure 5 [1] VCC = 6.0 V In to Y; see Figure 5 [1] VCC = 2.0 V - 58 185 - 230 - 280 ns VCC = 4.5 V - 21 37 - 46 - 56 ns VCC = 5 V; CL = 15 pF - 17 - - - - - ns - 17 31 - 39 - 48 ns VCC = 2.0 V - 61 185 - 230 - 280 ns VCC = 4.5 V - 22 37 - 46 - 56 ns VCC = 5 V; CL = 15 pF - 19 - - - - - ns - 18 31 - 39 - 48 ns VCC = 2.0 V - 61 205 - 255 - 310 ns VCC = 4.5 V - 22 41 - 51 - 62 ns VCC = 6.0 V Sn to Y; see Figure 6 [1] VCC = 6.0 V Sn to Y; see Figure 6 [1] VCC = 5 V; CL = 15 pF - 19 - - - - - ns VCC = 6.0 V - 18 35 - 43 - 53 ns VCC = 2.0 V - 41 125 - 155 - 190 ns VCC = 4.5 V - 15 25 - 31 - 38 ns VCC = 5 V; CL = 15 pF - 12 - - - - - ns VCC = 6.0 V - 12 21 - 26 - 32 ns E to Y; see Figure 6 E to Y; see Figure 6 VCC = 2.0 V - 47 145 - 180 - 220 ns VCC = 4.5 V - 17 29 - 36 - 44 ns VCC = 5 V; CL = 15 pF - 14 - - - - - ns - 14 25 - 31 - 38 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 6.0 V tt transition time 74HC_HCT151 Product data sheet Y, Y; see Figure 5 [2] All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 December 2015 © Nexperia B.V. 2017. All rights reserved 8 of 18 74HC151; 74HCT151 Nexperia 8-input multiplexer Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 7. Symbol Parameter CPD power dissipation capacitance Tamb = 25 C Conditions Tamb = 40 C to +85 C Tamb = 40 C to +125 C Unit Min Typ Max Min Max Min Max - 40 - - - - - pF - 22 38 - 48 - 57 ns - 19 - - - - - ns VCC = 4.5 V - 22 38 - 48 - 57 ns VCC = 5 V; CL = 15 pF - 19 - - - - - ns - 23 41 - 51 - 62 ns - 20 - - - - - ns - 25 43 - 54 - 65 ns - 20 - - - - - ns - 16 29 - 36 - 44 ns - 13 - - - - - ns VCC = 4.5 V - 21 36 - 45 - 54 ns VCC = 5 V; CL = 15 pF - 18 - - - - - ns - 7 15 - 19 - 22 ns - 40 - - - - - pF CL = 50 pF; f = 1 MHz; VI = GND to VCC [3] In to Y; see Figure 5 [1] 74HCT151 tpd propagation delay VCC = 4.5 V VCC = 5 V; CL = 15 pF [1] In to Y; see Figure 5 [1] Sn to Y; see Figure 6 VCC = 4.5 V VCC = 5 V; CL = 15 pF [1] Sn to Y; see Figure 6 VCC = 4.5 V VCC = 5 V; CL = 15 pF [1] E to Y; see Figure 6 VCC = 4.5 V VCC = 5 V; CL = 15 pF [1] E to Y; see Figure 6 transition time tt power dissipation capacitance CPD [2] Y, Y; see Figure 5 VCC = 4.5 V CL = 50 pF; f = 1 MHz; VI = GND to VCC  1.5 V [3] [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC_HCT151 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 December 2015 © Nexperia B.V. 2017. All rights reserved 9 of 18 74HC151; 74HCT151 Nexperia 8-input multiplexer 11. Waveforms 9, 90 ,QLQSXW 90 *1' W3+/ 92+ W3/+   90
74HC151PW,118 价格&库存
很抱歉,暂时无法提供与“74HC151PW,118”相匹配的价格&库存,您可以联系我们找货
74HC151PW,118
  • 50+1.5480550+0.18777
  • 100+1.44557100+0.17534
  • 250+1.43106250+0.17358
  • 500+1.42925500+0.17336
74HC151PW,118
  • 1+5.217051+0.63280
  • 3+4.723293+0.57291
  • 10+4.4158610+0.53562
  • 25+3.9407425+0.47799
  • 100+3.14886100+0.38194
  • 500+2.53400500+0.30736
  • 2500+1.993662500+0.24182
74HC151PW,118
    • 10+1.76733
    • 25+1.64484
    • 100+1.39462
    • 250+1.38062
    • 500+1.37887
    74HC151PW,118
    • 2500+0.918162500+0.11137
    • 7500+0.913877500+0.11085
    • 10000+0.9138510000+0.11085
    • 25000+0.9138325000+0.11085
    • 37500+0.9138137500+0.11084
