74HC139-Q100; 74HCT139-Q100
Dual 2-to-4 line decoder/demultiplexer
Rev. 1 — 19 June 2014
Product data sheet
1. General description
The 74HC139-Q100; 74HCT139-Q100 decodes two binary weighted address inputs
(nA0, nA1) to four mutually exclusive outputs (nY0 to nY3). Each decoder features an
enable input (nE). When nE is HIGH all outputs are forced HIGH. The enable input can be
used as the data input for a 1-to-4 demultiplexer application. Inputs include clamp diodes
that enable the use of current limiting resistors to interface inputs to voltages in excess of
VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Input levels:
For 74HC139-Q100: CMOS level
For 74HCT139-Q100: TTL level
Demultiplexing capability
2 independent 2-to-4 decoders
Multifunction capability
Suitable for memory decoding, data routing or code conversion
Complies with JEDEC standard no. 7A
Active LOW mutually exclusive outputs
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
Nexperia
3. Ordering information
Table 1.
Type number
Package
74HC139D-Q100
Temperature range
Name
Description
Version
40 C to +125 C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
40 C to +125 C
TSSOP16
plastic thin shrink small outline package;
16 leads; body width 4.4 mm
SOT403-1
74 HCT139D-Q100
74HC139DB-Q100
74HCT139DB-Q100
74HC139PW-Q100
74HCT139PW-Q100
4. Functional diagram
很抱歉,暂时无法提供与“74HC139D-Q100J”相匹配的价格&库存,您可以联系我们找货
