B2011 SERIES
2.00mm pitch board-in connector
Specifications
Current rating:1A AC,DC
Voltage rating:250V AC,DC
Temperature range:-40°C~+105°C
Contact resistance:20mΩMax.
Insulation resistance:500MΩMin.
Withstanding voltage:1000V AC/minute
*Compliant with RoHS and REACH*
*Meet the HF/Halogen Free need to
customize*
*Contact CJT for details*
Standards
E326732
E326732
0.80
2.25 REF.
6.15
3.50
CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn
B-13
B2011 SERIES
B2011-T
2.00mm pitch Crimp Terminal
2.35±0.25
Reference Informations:
*Used in CJT B2011H-XP series Housing
1.00±0.20
2.35±0.25
0.20
1.40±0.20
SEC:A-A
1.55±0.20
1.30
0.40
1.75±0.20
1.20±0.20
9.30±0.25
SEC:B-B
1.45±0.20
0.90±0.10
SEC:C-C
0.65±0.10
Unit:mm
Ordering information & Specifications:
Wire Range
Part NO.
Insulation O.D.
1.30mm(max)
AWG#24-#30
B2011-TB
1.30mm(max)
B2011-TP
AWG#24-#30
1.30mm(max)
B2011-GB
AWG#24-#30
1.30mm(max)
B2011-GP
AWG#24-#30
Optional Gold plating available but MOQ requested
B2011-T-A
Material
Brass
Phosphor Bronze
Brass
Phosphor Bronze
Finish
Tin over Nickel
Tin over Nickel
Gold over Nickel
Gold over Nickel
Qty/reel
10,000 PCS
10,000 PCS
10,000 PCS
10,000 PCS
*Used in CJT B2011HA-XP series Housing
1.90±0.20
0.50
SEC:A-A
SEC:B-B
0.82±0.05
1.55±0.20
0.50
SEC:C-C
1.55±0.20
C
4.15±0.20
C
0.40
1.05
B
1.05
B
1.40±0.20
A
7.45±0.25
A
1.50±0.20
1.80±0.20
0.20
Ø1.50
Unit:mm
Wire Range
Part NO.
Insulation O.D.
1.00mm(max)
AWG#28-#30
B2011-TB-A
1.00mm(max)
B2011-TP-A
AWG#28-#30
1.00mm(max)
B2011-GB-A
AWG#28-#30
1.00mm(max)
B2011-GP-A
AWG#28-#30
Material
Brass
Phosphor Bronze
Brass
Phosphor Bronze
Finish
Tin over Nickel
Tin over Nickel
Gold over Nickel
Gold over Nickel
Qty/reel
10,000 PCS
10,000 PCS
10,000 PCS
10,000 PCS
B-14
B2011 SERIES
B2011H-XP
2.00mm pitch Housing
*Material:Nylon 66,UL94V-0
*Suitable CJT B2011-T series Terminal
*Color:White
Ordering Information:
B2011H-XP - ***
1
2
1.Part No.
2.Material:
(blank):Nylon 66,UL94V-0
GWT:Nylon 66,UL94V-0,GWT 750°C
2.00±0.10
2.00±0.10
Ordering Information & Dimensions:
Ø0.80
A±0.20
PART NO.
P.C.B LAYOUT
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
16P
6.15±0.25
5.75±0.20
B±0.25
3.50±0.20
Circuit 1
Dimensions
A
B
2.00
5.20
4.00
7.20
6.00
9.20
8.00
11.20
10.00
13.20
12.00
15.20
14.00
17.20
16.00
19.20
18.00
21.20
20.00
23.20
22.00
25.20
24.00
27.20
26.00
29.20
28.00
31.20
30.00
33.20
Unit: mm
B2011HA-XP
*Suitable CJT B2011-T-A series Terminal
*Color:White
B2011HA-XP - ***
1
2
1.Part No.
2.Material:
2.00±0.10
Ø0.80
2.00±0.10
P.C.B LAYOUT
PART NO.
A±0.20
B±0.25
4.92±0.20
2.84±0.20
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
16P
Dimensions
A
B
2.00
4.40
4.00
6.40
6.00
8.40
8.00
10.40
10.00
12.40
12.00
14.40
14.00
16.40
16.00
18.40
18.00
20.40
20.00
22.40
22.00
24.40
24.00
26.40
26.00
28.40
28.00
30.40
30.00
32.40
Unit: mm
B-15
很抱歉,暂时无法提供与“B2011H-8P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.12236
- 200+0.11316
- 600+0.10396
- 3000+0.09476
