BUK963R2-40B
N-channel TrenchMOS logic level FET
13 March 2014
Product data sheet
1. General description
Logic level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product has been designed and qualified to
the appropriate AEC standard for use in automotive critical applications.
2. Features and benefits
AEC Q101 compliant
Low conduction losses due to low on-state resistance
Suitable for logic level gate drive sources
Suitable for thermally demanding environments due to 175 °C rating
3. Applications
12 V loads
Automotive systems
General purpose power switching
Motors, lamps and solenoids
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
40
V
ID
drain current
VGS = 5 V; Tmb = 25 °C; Fig. 2; Fig. 3
100
A
Ptot
total power dissipation
Tmb = 25 °C; Fig. 1
300
W
VGS = 10 V; ID = 25 A; Tj = 25 °C
2.4
2.8
mΩ
VGS = 5 V; ID = 25 A; Tj = 25 °C;
2.7
3.2
mΩ
37
nC
[1]
Static characteristics
RDSon
drain-source on-state
resistance
Fig. 11; Fig. 12
Dynamic characteristics
QGD
gate-drain charge
VGS = 5 V; ID = 25 A; VDS = 32 V;
Tj = 25 °C; Fig. 13
BUK963R2-40B
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ID = 100 A; Vsup ≤ 40 V; RGS = 50 Ω;
1.2
J
Avalanche ruugedness
EDS(AL)S
non-repetitive drainsource avalanche
energy
[1]
VGS = 5 V; Tj(init) = 25 °C; unclamped
All individual parts of device must be ≤ 175 °C to achieve maximum current rating.
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
Simplified outline
1
G
gate
2
D
drain[1]
3
S
source
mb
D
mounting base; connected to
drain
Graphic symbol
mb
D
G
mbb076
2
1
S
3
D2PAK (SOT404)
[1]
It is not possible to make connection to pin 2.
6. Ordering information
Table 3.
Type number
Package
BUK963R2-40B
Name
Description
Version
D2PAK
plastic single-ended surface-mounted package (D2PAK); 3 leads SOT404
(one lead cropped)
7. Marking
Table 4.
Marking codes
Type number
Marking code
BUK963R2-40B
BUK963R2-40B
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
40
V
VDGR
drain-gate voltage
RGS = 20 kΩ
40
V
BUK963R2-40B
Product data sheet
All information provided in this document is subject to legal disclaimers.
13 March 2014
Nexperia B.V. 2017. All rights reserved
2 / 13
BUK963R2-40B
Nexperia
Symbol
Parameter
Conditions
Min
Max
Unit
VGS
gate-source voltage
-15
15
V
Ptot
Tmb = 25 °C; Fig. 1
300
W
ID
drain current
Tmb = 25 °C; VGS = 5 V; Fig. 2; Fig. 3
[1]
222
A
Tmb = 100 °C; VGS = 5 V; Fig. 2
[2]
100
A
[2]
100
A
888
A
IDM
peak drain current
Tmb = 25 °C; pulsed; tp ≤ 10 µs; Fig. 3
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
[1]
222
A
[2]
100
A
pulsed; tp ≤ 10 µs; Tmb = 25 °C
888
A
1.2
J
Source-drain diode
IS
source current
ISM
Tmb = 25 °C
peak source current
EDS(AL)S
non-repetitive drain-source
avalanche energy
[1]
[2]
Current is limited by power dissipation chip rating.
03na19
120
03nh38
250
ID
(A)
Pder
200
80
150
100
40
Capped at 100 A due to package
50
Fig. 1.
100
150
Tmb (°C)
Normalized total power dissipation as a
function of mounting base temperature
BUK963R2-40B
Product data sheet
Fig. 2.
150
Tmb (°C)
200
Continuous drain current as a function of
13 March 2014
100
3 / 13
BUK963R2-40B
Nexperia
03nh36
104
ID
(A)
103
Limit RDSon = VDS / ID
tp = 10 µs
100 µs
102
1 ms
DC
10 ms
10
100 ms
1
10- 1
Fig. 3.
1
10
102
VDS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
9. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance
from junction to
mounting base
Fig. 4
0.5
K/W
Rth(j-a)
thermal resistance
from junction to
ambient
minimum footprint; mounted on a
printed-circuit board
50
K/W
03nh37
1
Zth(j-mb)
(K/W)
10- 1
δ = 0.5
0.2
0.1
0.05
0.02
P
10- 2
single shot
10- 3
10- 6
Fig. 4.
δ=
tp
10- 5
10- 4
10- 3
10- 2
tp
T
t
T
10- 1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
BUK963R2-40B
Product data sheet
13 March 2014
4 / 13
BUK963R2-40B
Nexperia
10. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
drain-source
breakdown voltage
ID = 0.25 mA; VGS = 0 V; Tj = -55 °C
36
V
ID = 0.25 mA; VGS = 0 V; Tj = 25 °C
40
V
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 25 °C;
1.1
1.5
2
V
0.5
V
2.3
V
VDS = 40 V; VGS = 0 V; Tj = 25 °C
0.02
1
µA
VDS = 40 V; VGS = 0 V; Tj = 175 °C
500
µA
VGS = 15 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -15 V; VDS = 0 V; Tj = 25 °C
2
100
nA
2.4
2.8
mΩ
VGS = 4.5 V; ID = 25 A; Tj = 25 °C
3.5
mΩ
VGS = 5 V; ID = 25 A; Tj = 175 °C;
6
mΩ
2.7
3.2
mΩ
V(BR)DSS
VGS(th)
Fig. 10
ID = 1 mA; VDS = VGS; Tj = 175 °C;
Fig. 10
ID = 1 mA; VDS = VGS; Tj = -55 °C;
Fig. 10
IDSS
IGSS
RDSon
drain leakage current
gate leakage current
resistance
Fig. 11; Fig. 12
Fig. 11; Fig. 12
QG(tot)
total gate charge
ID = 25 A; VDS = 32 V; VGS = 5 V;
94
nC
QGS
gate-source charge
Tj = 25 °C; Fig. 13
17
nC
QGD
gate-drain charge
37
nC
Ciss
input capacitance
VGS = 0 V; VDS = 25 V; f = 1 MHz;
7877
10502 pF
Coss
output capacitance
Tj = 25 °C; Fig. 14
1397
1676
pF
Crss
reverse transfer
capacitance
608
833
pF
td(on)
turn-on delay time
VDS = 30 V; RL = 1.2 Ω; VGS = 5 V;
68
ns
tr
rise time
RG(ext) = 10 Ω; Tj = 25 °C
268
ns
td(off)
turn-off delay time
257
ns
tf
fall time
192
ns
LD
internal drain
inductance
4.5
nH
BUK963R2-40B
Product data sheet
from drain lead 6 mm from package to
center of die; Tj = 25 °C
13 March 2014
5 / 13
BUK963R2-40B
Nexperia
Symbol
Parameter
LS
internal source
inductance
Conditions
Min
Typ
Max
Unit
from upper edge of drain mounting
base to center of die; Tj = 25 °C
2.5
nH
from source lead to source bond pad;
Tj = 25 °C
7.5
nH
IS = 40 A; VGS = 0 V; Tj = 25 °C; Fig. 15
0.85
1.2
V
Source-drain diode
VSD
source-drain voltage
trr
reverse recovery time
IS = 20 A; dIS/dt = -100 A/µs;
70
ns
recovered charge
VGS = -10 V; VDS = 20 V; Tj = 25 °C
127
nC
Qr
350
ID
(A)
03nh56
10
5
4
3.8
280
03nh55
5
Label is VGS (V)
RDSon
(mΩ)
3.6
4
3.4
210
3.2
140
3
3
2.8
70
2.6
Fig. 5.
2.4
2.2
4
6
8
VDS (V)
2
10
Output characteristics: drain current as a
Fig. 6.
function of drain-source voltage; typical values
BUK963R2-40B
Product data sheet
3
11
VGS (V)
15
Drain-source on-state resistance as a function
of gate-source voltage; typical values
13 March 2014
7
6 / 13
BUK963R2-40B
Nexperia
03ng53
10- 1
03nh53
200
ID
(A)
gfs
(S)
10- 2
150
min
10- 3
typ
max
100
10- 4
50
10- 5
10- 6
Fig. 7.
2
VGS (V)
Sub-threshold drain current as a function of
gate-source voltage
Fig. 8.
03nh54
100
ID (A)
60
Forward transconductance as a function of
drain current; typical values
03ng52
2.5
VGS(th)
(V)
ID
(A)
2.0
75
max
1.5
typ
50
min
1.0
25
Fig. 9.
0.5
Tj = 175 °C
Tj = 25 °C
2
VGS (V)
3
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
BUK963R2-40B
Product data sheet
120
Tj (°C)
180
Fig. 10. Gate-source threshold voltage as a function of
13 March 2014
7 / 13
BUK963R2-40B
Nexperia
03nh57
8
2.8
3
RDSon
(mΩ)
03aa27
2
Label is VGS (V)
a
3.2
1.5
3.4
6
3.6
1
3.8
4
4
5
0.5
10
2
140
210
280
ID (A)
350
Fig. 11. Drain-source on-state resistance as a function
of drain current; typical values
60
Tj (° C)
180
03nh58
12000
VGS
(V)
Ciss
C
(pF)
4
120
Fig. 12. Normalized drain-source on-state resistance
factor as a function of junction temperature
03nh52
5
VDD = 14 V
8000
VDD = 32 V
3
Coss
2
4000
Crss
1
50
75
QG (nC)
Fig. 13. Gate-source voltage as a function of gate
charge; typical values
BUK963R2-40B
Product data sheet
100
1
10
VDS (V)
102
Fig. 14. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
13 March 2014
8 / 13
BUK963R2-40B
Nexperia
03nh51
100
IS
(A)
75
50
Tj = 175 °C
Tj = 25 °C
25
0.2
0.4
0.6
0.8
1.0
VSD (V)
Fig. 15. Source current as a function of source-drain voltage; typical values
BUK963R2-40B
Product data sheet
13 March 2014
9 / 13
BUK963R2-40B
Nexperia
11. Package outline
Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped)
SOT404
A
A1
E
mounting
base
D1
D
HD
2
Lp
1
3
b2
c
b
e
e
Q
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
max
nom
min
mm
A
A1
b
b2
c
4.5
1.40 0.85 1.45 0.64
4.1
1.27 0.60 1.05 0.46
D
D1
E
11
1.6
10.3
1.2
9.7
e
2.54
HD
Lp
Q
15.8
2.9
2.6
14.8
2.1
2.2
sot404_po
Outline
version
References
IEC
JEDEC
JEITA
European
projection
Issue date
06-03-16
13-02-25
SOT404
Fig. 16. Package outline D2PAK (SOT404)
BUK963R2-40B
Product data sheet
13 March 2014
10 / 13
BUK963R2-40B
Nexperia
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
12. Legal information
12.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
12.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
BUK963R2-40B
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
13 March 2014
11 / 13
BUK963R2-40B
Nexperia
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
12.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
BUK963R2-40B
Product data sheet
13 March 2014
12 / 13
BUK963R2-40B
Nexperia
13. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Marking ................................................................... 2
8
Limiting values .......................................................2
9
Thermal characteristics .........................................4
10
Characteristics ....................................................... 5
11
Package outline ................................................... 10
12
12.1
12.2
12.3
12.4
Legal information .................................................11
Data sheet status ............................................... 11
Definitions ...........................................................11
Disclaimers .........................................................11
Trademarks ........................................................ 12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 13 March 2014
BUK963R2-40B
Product data sheet
13 March 2014
13 / 13
很抱歉,暂时无法提供与“BUK963R2-40B,118”相匹配的价格&库存,您可以联系我们找货
