WSK96N08
N-Ch MOSFET
Product Summery
General Description
BVDSS
The WSK96N08 is the highest performance
trench N-ch MOSFET with extreme high cell
density , which provide excellent RDSON
and gate charge for most of the synchronous
buck converter applications .
80V
The WSK96N08 meet the RoHS and Green
Product requirement , 100% EAS
guaranteed with full function reliability
approved.
RDSON
ID
7mΩ
96A
TO-263-2L Pin Configuration
Applications
z Switching application
z Power management for inverter systems
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
80
V
VGS
Gate-Source Voltage
±25
V
1
90
A
1
64
A
360**
A
416***
mJ
ID@TC=25℃
ID@TC=100℃
IDM
EAS
Continuous Drain Current, VGS @ 10V
Pulsed Drain Current
2
3
Single Pulse Avalanche Energy
IAS
Avalanche Current
200
PD@TC=25℃
Total Power Dissipation3
185
W
PD@TC=100℃
92
W
TSTG
Storage Temperature Range
-55 to 175
TJ
Operating Junction Temperature Range
-55 to 175
Note:
A
* Repetitive rating;pulse width limited by max.junction temperature.
** Surface mounted on 1in2 FR-4 board.
*** Limited by TJmax , starting TJ=25°C , L = 0.5mH, RG= 25Ω, VGS =10V.
www.winsok.tw
Page 1
Dec.2014
WSK96N08
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
gf
gfs
orward Transconductance
V
V/℃
0.0
VGS=10V , ID=45A
7
9
mΩ
VGS=6V , ID=10A
10
12
mΩ
2
3
4
V
mV/℃
VGS=VDS , ID =250uA
-6.57
VDS=80V , VGS=0V , TJ=25℃
1
VDS=80V , VGS=0V , TJ=55℃
2
VGS=±20V , VDS=0V
±100
nA
VDS=5V , ID=20A
18
S
Gate-Drain Charge
28
Turn-On Delay Time
25
VDS=50V , VGS=10V , ID=120A
uA
nC
Rise Time
VDD=30V , VGS=10V ,
42
Turn-Off Delay Time
RG=6Ω ID=145A ,
62
Fall Time
RL=30Ω
19
3800
389
250
0.8
V
60
ns
125
nC
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
16
Qgd
Unit
Reference to 25℃ , ID=1mA
86
Gate-Source Charge
Tf
Max.
Total Gate Charge (10V)
Td(off)
80
Typ.
Qg
Tr
VGS=0V , ID=250uA
Min.
Qgs
Td(on)
Conditions
VDS=30V , VGS=0V , f=1MHz
Reverse Recovery Charge
ISD=45A,VGS=0V
ISD=45A,dISD/dt=100A/μs
ns
pF
Note: *Pulse test,pulse width ≤ 300us,duty cycle ≤ 2%
www.winsok.tw
Page 2
Dec.2014
WSK96N08
N-Ch MOSFET
Typical Operating Characteristics
Figure 2: Drain Current
ID-Drain Current(A)
Power Dissipation (w)
Figure 1: Power Dissipation
Tc-Case Temperature(℃)
Thermal
Zθjc
ID-Drain Current(A)
Impedance
Figure 4: Thermal Transient Impedance
Normalized Transient
Figure 3: Safe Operation Area
Maximum Effective Transient Thermal
Impedance, Junction-to-Case
Figure 5: Output Characteristics
Figure 6: Drain-Source On Resistance
ID-Drain Current(A)
RDS(ON)-ON-Resistance(mΩ)
VDS-Drain-Source Voltage(V)
VDS-Drain-Source Voltage (V)
www.winsok.tw
ID-Drain Current(A)
Page 3
Dec.2014
WSK96N08
N-Ch MOSFET
Figure 8: Source-Drain Diode Forward
IS-Source Current (A)
Normalized On-Resistance
Figure 7: On-Resistance vs. Temperature
Tj-Junction Temperature (℃)
Figure 9: Capacitance Characteristics
Figure 10: Gate Charge Characteristics
C-Capacitance(pF)
VGS-Gate-Source Voltage (V)
12
VSD-Source-Drain Voltage(V)
www.winsok.tw
Q G-Gate Charge (nC)
Page 4
Dec.2014
WSK96N08
N-Ch MOSFET
Device Per Unit
Package Type
Unit
Quantity
TO-263-2L
Reel
50
Package Information
TO-263-2L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
4.37
4.57
4.77
A1
1.22
1.27
1.42
A2
2.49
2.69
2.89
A3
0.25
b
0.7
0.81
0.96
b1
1.17
1.27
1.47
c
0.3
0.38
0.53
D1
8.5
8.7
8.9
D4
6.6
E
9.86
10.16
10.36
E5
7.06
2.54 BSC
e
H
14.7
15.1
15.5
H2
1.07
1.27
1.47
L
2
2.3
2.6
L1
1.4
1.55
1.7
L4
θ
www.winsok.tw
0.25 BSC
0°
Page 5
5°
9°
Dec.2014
WSK96N08
N-Ch MOSFET
Classification Profile
Classification Reflow Profiles
Profile Feature
Preheat & Soak
Temperature min (Tsmin)
Temperature max (Tsmax)
Time (Tsmin to Tsmax) (ts)
Average ramp-up rate
(Tsmaxto TP)
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body Temperature
(Tp)*
Time (tP)** within 5°C of the specified
classification temperature (Tc)
Average ramp-down rate (Tpto Tsmax)
Time 25°C to peak temperature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
100 °C
150 °C
150 °C
200 °C
60-120 seconds
60-120 seconds
3 °C/second max.
3°C/second max.
183 °C
217 °C
60-150 seconds
60-150 seconds
See Classification Temp in table 1
SeeClassification Tempin table 2
20** seconds
30** seconds
6 °C/second max.
6 °C/second max.
6 minutes max.
8 minutes max.
*Tolerance for peak profile Temperature (T p) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
www.winsok.tw
Page 6
Dec.2014
Attention
1,AnyandallWinsokpowerproductsdescribedorcontainedhereindonothavespecificationsthatcanhandle
applicationsthatrequireextremelyhighlevelsofreliability,suchaslifeͲsupportsystems,aircraft'scontrolsystems,or
otherapplicationswhosefailurecanbereasonablyexpectedtoresultinseriousphysicaland/ormaterialdamage.
ConsultwithyourWinsokpowerrepresentativenearestyoubeforeusinganyWinsokpowerproductsdescribedor
containedhereininsuchapplications.
2,Winsokpowerassumesnoresponsibilityforequipmentfailuresthatresultfromusingproductsatvaluesthatexceed,
evenmomentarily,ratedvalues(suchasmaximumratings,operatingconditionranges,orotherparameters)listedin
productsspecificationsofanyandallWinsokpowerproductsdescribedorcontainedherein.
3,SpecificationsofanyandallWinsokpowerproductsdescribedorcontainedhereinstipulatetheperformance,
characteristics,andfunctionsofthedescribedproductsintheindependentstate,andarenotguaranteesofthe
performance,characteristics,andfunctionsofthedescribedproductsasmountedinthecustomer’sproductsor
equipment.Toverifysymptomsandstatesthatcannotbeevaluatedinanindependentdevice,thecustomershouldalways
evaluateandtestdevicesmountedinthecustomer’sproductsorequipment.
4,WinsokpowerSemiconductorCO.,LTD.strivestosupplyhighͲqualityhighͲreliabilityproducts.However,anyandall
semiconductorproductsfailwithsomeprobability.Itispossiblethattheseprobabilisticfailurescouldgiverisetoaccidents
oreventsthatcouldendangerhumanlivesthatcouldgiverisetosmokeorfire,orthatcouldcausedamagetoother
property.Whendesigningequipment,adoptsafetymeasuressothatthesekindsofaccidentsoreventscannotoccur.Such
measuresincludebutarenotlimitedtoprotectivecircuitsanderrorpreventioncircuitsforsafedesign,redundantdesign,
andstructuraldesign.
5,IntheeventthatanyorallWinsokpowerproducts(includingtechnicaldata,services)describedorcontainedhereinare
controlledunderanyofapplicablelocalexportcontrollawsandregulations,suchproductsmustnotbeexportedwithout
obtainingtheexportlicensefromtheauthoritiesconcernedinaccordancewiththeabovelaw.
6,Nopartofthispublicationmaybereproducedortransmittedinanyformorbyanymeans,electronicormechanical,
includingphotocopyingandrecording,oranyinformationstorageorretrievalsystem,orotherwise,withouttheprior
writtenpermissionofWinsokpowerSemiconductorCO.,LTD.
7,Information(includingcircuitdiagramsandcircuitparameters)hereinisforexampleonly;itisnotguaranteedfor
volumeproduction. Winsokpowerbelievesinformationhereinisaccurateandreliable,butnoguaranteesaremadeor
impliedregardingitsuseoranyinfringementsofintellectualpropertyrightsorotherrightsofthirdparties.
8,Anyandallinformationdescribedorcontainedhereinaresubjecttochangewithoutnoticeduetoproduct/technology
improvement,etc.Whendesigningequipment,refertothe"DeliverySpecification"fortheWinsokpowerproductthatyou
Intendtouse.
9,thiscatalogprovidesinformationasofSep.2014. Specificationsandinformationhereinaresubjecttochangewithout
notice.
