MT3303A-EN
MT3303A-EN
    MAGNTEK(麦歌恩)
    TO-92-3
    磁性编码器 TO-92 2.8~24V
MT3303A-EN 数据手册
MT3303-EN Series High Voltage Omni-polar Hall-Effect Sensors Features and Benefits ⚫ ⚫ ⚫ Applications BiCMOS Technology Wide Operating Voltage Range: Supply Voltage 2.8~24V Specified Operating Temperature ⚫ ⚫ ⚫ ⚫ Solid-state Switch Speed Detection Angular Position Detection Proximity Detection Range: From -40℃~150℃ ⚫ ⚫ ⚫ ⚫ ⚫ Low Operating Current: 2.3mA Lead Free Package Flat TO-92, SOT-23 Open Drain Output Reverse Battery Protection RoHS Compliant:2011/65/EU Family Members Part number Description MT3303A-EN Flat TO-92 package, bulk packaging (1000pcs/bag) MT3303AT-EN SOT-23 package, tape and reel packaging(3000pcs/bag) General Description The MT3303-EN family are Hall-effect omni-polar switch designed in mixed-signal technology. The Hall IC internally includes a voltage regulator for operation with supply voltage of 2.8 to 24V, a dynamic offset cancellation system, a Schmitt trigger and an open-drain output driver, all in a single package. As to its wide operating voltage range and extended choice of temperature range, it is quite suitable for use in automotive, industrial and consumer applications. It also includes an anti-reverse bias block to prevent from reverse bias condition. MT3303-EN series provide a variety of packages to customers: SOT-23 for surface mount and flat TO-92 for through-hole mount. All packages are RoHS compliant. www.magntek.com.cn Rev.3 07/2019 1 / 9 MT3303-EN Series High Voltage Omni-polar Hall-Effect Sensors VS Reference Dynamic offset cancelation Regulator Over Current Protect OUT COMP Output Driver ESD ITA ESD Hall Plate GND Functional Block Diagram Function Description Definition of Magnetic Parameters BOP: Operating Point, Magnetic flux density applied on the branded side of the package which turns the output driver ON (VOUT=Low) BRP: Release Point, Magnetic flux density applied on the branded side of the package which turns the output driver OFF (VOUT=High) BHYST: Hysteresis Window,| BOP-BRP| Definition of Switching Function VOUT (V) North Pole BOP B RP VOUT(V) 0 0 Switching Behavior www.magntek.com.cn Rev.3 07/2019 2 / 9 B RP BOP South Pole MT3303-EN Series High Voltage Omni-polar Hall-Effect Sensors OR OR S N S S N N S N O O R R OUT=High OUT=Low Switching point of AT OUT=High OUT=Low Switching point of A Note: Direction of magnetic flux, Close to the chip, Far away to the chip Pin Description MT3303A-EN MT3303AT-EN Name Number VS 1 GND OUT Description Name Number Power VS 1 Power 2 Ground GND 3 Ground 3 Open-drain Output OUT 2 Open-drain Output www.magntek.com.cn Rev.3 07/2019 3 / 9 Description MT3303-EN Series High Voltage Omni-polar Hall-Effect Sensors Electrical and Magnetic Characteristics Absolute Maximum Ratings Absolute maximum ratings are limiting values to be applied individually, and beyond which the serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to absolute maximum rating conditions for an extended period of time may affect device reliability. Absolute maximum ratings: all voltages listed are referenced to GND. Symbol Parameters Min VS Supply Voltage Max Units - 27 V -27 - V VRCC Reverse Battery Voltage VOUT Output Voltage - 27 V IOUT Continuous output current - 50 mA TA Operating ambient Temperature -40 150 ℃ TS Storage temperature -50 165 ℃ TJ Junction Temperature - 165 ℃ B Magnetic Flux No Limit Power derating Curve www.magntek.com.cn Rev.3 07/2019 4 / 9 Gauss MT3303-EN Series High Voltage Omni-polar Hall-Effect Sensors MT3303-EN Specifications At TA =-40 to150℃, VS = 2.8V to 24V (unless otherwise specified) Symbol Parameter Test Condition VS Supply Voltage Operating IS Supply Current B< BRP IOCP Short Circuit Protection Current B>BOP, VOUT=VS VDSON Output Saturation Voltage IOUT=20mA, B> BOP - - 0.4 V IOL Output Leakage Current VOUT=24V, B< BRP - - 10 μA TR1,2 Output Rise Time RL=1KOhm,CL=20pF - - 1.0 μs TF1,2 Output Fall Time RL=1KOhm,CL=20pF - - 1.0 μs TPO1 Power On Time - - 25 μs F C1 Chopping Frequency - 200 - KHz SOT-23 Package Thermal - 301 - ℃/W - 230 - ℃/W 90 150 190 Gauss 70 120 160 Gauss 10 30 50 Gauss TA =25℃ -190 -150 -90 Gauss TA =25℃ -160 -120 -70 Gauss -50 -30 -10 Gauss RTH dVS/dt>5V/uS, B>BOP(MAX) Min Typ Max Units 2.8 - 24 V 1 2.3 3.5 mA 50 mA Resistance TO-92 Package Thermal Resistance BOPS BRPS BHYSTS BOPN BRPN BHYSTN Magnetic Operating Point of South Pole Magnetic Release Point of South TA =25℃ Pole Hysteresis Window of South Pole Magnetic Operating Point of North Pole Magnetic Release Point of North Pole Hysteresis Window of North Pole 1 Guaranteed by device design and characterization. 2 CL = oscilloscope probe capacitance. www.magntek.com.cn Rev.3 07/2019 5 / 9 MT3303-EN Series High Voltage Omni-polar Hall-Effect Sensors Characteristic Performance Average Supply Current versus Supply Voltage Average Supply Current versus Temperature Magnetic Characteristics versus Temperature VS=2.8V Magnetic Characteristics versus Temperature VS=5V Magnetic Characteristics versus Temperature VS=12V Magnetic Characteristics versus Temperature V S=24V www.magntek.com.cn Rev.3 07/2019 6 / 9 MT3303-EN Series High Voltage Omni-polar Hall-Effect Sensors Typical Application Circuit Note: RL recommend 1KOhm to 10KOhm VS RL VS 100nF OUT MT3303-EN 1nF GND Typical Output Waveform Magnetic field BOPS B RPS BRPN BOPN High VOUT Low Power On Output Waveform (The Flat TO-92 package as an example) VS Magnetic field Digital Output B>BOPS or <BRPN B
MT3303A-EN 价格&库存
很抱歉,暂时无法提供与“MT3303A-EN”相匹配的价格&库存,您可以联系我们找货
MT3303A-EN
