MT3303-EN Series
High Voltage Omni-polar Hall-Effect Sensors
Features and Benefits
Applications
BiCMOS Technology
Wide Operating Voltage Range:
Supply Voltage 2.8~24V
Specified Operating Temperature
Solid-state Switch
Speed Detection
Angular Position Detection
Proximity Detection
Range: From -40℃~150℃
Low Operating Current: 2.3mA
Lead Free Package
Flat TO-92, SOT-23
Open Drain Output
Reverse Battery Protection
RoHS Compliant:2011/65/EU
Family Members
Part number
Description
MT3303A-EN
Flat TO-92 package, bulk packaging (1000pcs/bag)
MT3303AT-EN
SOT-23 package, tape and reel packaging(3000pcs/bag)
General Description
The MT3303-EN family are Hall-effect omni-polar switch designed in mixed-signal technology. The Hall
IC internally includes a voltage regulator for operation with supply voltage of 2.8 to 24V, a dynamic offset
cancellation system, a Schmitt trigger and an open-drain output driver, all in a single package.
As to its wide operating voltage range and extended choice of temperature range, it is quite suitable for
use in automotive, industrial and consumer applications. It also includes an anti-reverse bias block to
prevent from reverse bias condition.
MT3303-EN series provide a variety of packages to customers: SOT-23 for surface mount and flat
TO-92 for through-hole mount. All packages are RoHS compliant.
www.magntek.com.cn
Rev.3 07/2019
1 / 9
MT3303-EN Series
VS
Reference
Dynamic offset
cancelation
Regulator
Over
Current
Protect
OUT
COMP
Output
Driver
ESD
ITA
ESD
Hall Plate
GND
Functional Block Diagram
Function Description
Definition of Magnetic Parameters
BOP: Operating Point, Magnetic flux density applied on the branded side of the package which turns the
output driver ON (VOUT=Low)
BRP: Release Point, Magnetic flux density applied on the branded side of the package which turns the
output driver OFF (VOUT=High)
BHYST: Hysteresis Window,| BOP-BRP|
Definition of Switching Function
VOUT (V)
North Pole
BOP
B RP
VOUT(V)
Switching Behavior
www.magntek.com.cn
Rev.3 07/2019
2 / 9
B RP
BOP
South Pole
MT3303-EN Series
OR
OR
S N
S
S
N
N
S N
O
O
R
R
OUT=High
OUT=Low
Switching point of AT
OUT=High
OUT=Low
Note:
Direction of magnetic flux,
Close to the chip,
Far away to the chip
Pin Description
MT3303A-EN
MT3303AT-EN
Name
Number
VS
1
GND
OUT
Description
Name
Number
Power
VS
1
Power
2
Ground
GND
3
Ground
3
Open-drain Output
OUT
2
Open-drain Output
www.magntek.com.cn
Rev.3 07/2019
3 / 9
Description
MT3303-EN Series
Electrical and Magnetic Characteristics
Absolute Maximum Ratings
Absolute maximum ratings are limiting values to be applied individually, and beyond which the
serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure
to absolute maximum rating conditions for an extended period of time may affect device reliability.
Absolute maximum ratings: all voltages listed are referenced to GND.
Symbol
Parameters
Min
VS
Supply Voltage
Max
Units
27
V
-27
V
VRCC
Reverse Battery Voltage
VOUT
Output Voltage
27
V
IOUT
Continuous output current
50
mA
TA
Operating ambient Temperature
-40
150
TS
Storage temperature
-50
165
TJ
Junction Temperature
165
B
Magnetic Flux
No Limit
Power derating Curve
www.magntek.com.cn
Rev.3 07/2019
4 / 9
Gauss
MT3303-EN Series
MT3303-EN Specifications
At TA =-40 to150℃, VS = 2.8V to 24V (unless otherwise specified)
Symbol
Parameter
Test Condition
VS
Supply Voltage
Operating
IS
Supply Current
B< BRP
IOCP
Short Circuit Protection Current
B>BOP, VOUT=VS
VDSON
Output Saturation Voltage
IOUT=20mA, B> BOP
0.4
V
IOL
Output Leakage Current
VOUT=24V, B< BRP
10
μA
TR1,2
Output Rise Time
RL=1KOhm,CL=20pF
1.0
μs
TF1,2
Output Fall Time
RL=1KOhm,CL=20pF
1.0
μs
TPO1
Power On Time
25
μs
F C1
Chopping Frequency
200
KHz
SOT-23 Package Thermal
301
℃/W
230
℃/W
90
150
190
Gauss
70
120
160
Gauss
10
30
50
Gauss
TA =25℃
-190
-150
-90
Gauss
TA =25℃
-160
-120
-70
Gauss
-50
-30
-10
Gauss
RTH
dVS/dt>5V/uS,
B>BOP(MAX)
Min
Typ
Max
Units
2.8
24
V
1
2.3
3.5
mA
50
mA
Resistance
TO-92 Package Thermal
Resistance
BOPS
BRPS
BHYSTS
BOPN
BRPN
BHYSTN
Magnetic Operating Point of
South Pole
Magnetic Release Point of South
TA =25℃
Pole
Hysteresis Window of South Pole
Magnetic Operating Point of North
Pole
Magnetic Release Point of North
Pole
Hysteresis Window of North Pole
1 Guaranteed by device design and characterization.
2 CL = oscilloscope probe capacitance.
www.magntek.com.cn
Rev.3 07/2019
5 / 9
MT3303-EN Series
Characteristic Performance
Average Supply Current versus Supply Voltage
Average Supply Current versus Temperature
Magnetic Characteristics versus Temperature
VS=2.8V
VS=5V
VS=12V
V S=24V
www.magntek.com.cn
Rev.3 07/2019
6 / 9
MT3303-EN Series
Typical Application Circuit Note: RL recommend 1KOhm to 10KOhm
VS
RL
VS
100nF
OUT
MT3303-EN
1nF
GND
Typical Output Waveform
Magnetic
field
BOPS
B RPS
BRPN
BOPN
High
VOUT
Low
Power On Output Waveform (The Flat TO-92 package as an example)
VS
Magnetic
field
Digital
Output
B>BOPS or <BRPN
B
很抱歉,暂时无法提供与“MT3303AT-EN”相匹配的价格&库存,您可以联系我们找货
