B5817W THRU B5819W
Schottky Barrier Diode
www.sot23.com.tw
Features
High Current Capability
Low Forward Voltage Drop
Mechanical Data
SOD-123 Small Outline Plastic Package
Polarity: Color band denotes cathode end
Mounting Position: Any
Marking: B5817W:
B5818W:
B5819W:
Maximum Ratings & Thermal Characteristics (Ratings at 25
Parameters
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
ambient temperature unless otherwise specified.)
B5817W
Symbol
SJ
SK
SL
B5818W
B5819W
Unit
VRRM
40
V
VRMS
14
21
28
V
VDC
40
V
IFM
1.0
A
Peak forward surge current 8.3 ms single half
sine-wave
IFSM
9
A
2
Typical Current Squared Time
I T
0.336
AS
RθJA
250
/W
PD
500
mW
TSTG / TJ
-50-+150
Maximum average forward rectified current
Typical thermal resistance
Power Dissipation
Storage temperature range
Electrical Characteristics (Ratings at 25
Parameters
ambient temperature unless otherwise specified).
B5817W
Symbol
Maximum forward voltage
VF
Maximum reverse breakdown voltage
VR
Maximum reverse current
Type junction capacitance
2
B5818W
B5819W
Test conditions
Unit
IF = 0.5A
IF = 1.0A
IF = 3.0A
0.450
0.750
0.450
0.550
0.875
0.450
0.600
0.900
IR=1mA
40
V
V
IR
VR=20V B5817W
VR=30V B5818W
VR=40V B5819W
1.0
mA
Cj
VR = 4.0V, f = 1MHz
120
pF
RATING AND CHARACTERISTICS CURVES (B5817W THRU B5819W)
SOD-123 PA CKAGE OU TLINE
3 ODVWLFVXUIDFH PRXQWHGSDFNDJH
Precautions: PCB Design(Recommended land dimensions for SOD-123 diode. Electrode patterns for PCBs)
Ёᖗ䎱: 3.24
㛮
ᆑ: 0.55
⛞Ⲭᆑ: 1.00
㛮
䭓: 0.50
⛞Ⲭ䭓: 0.80
ᡔᴃ㽕∖:
1, ลᇕԧሎᇌ: 2.70 X 1.60
2: ⊼݀ᏂЎ: ±0.05
3, ᠔᳝ऩԡ: mm
很抱歉,暂时无法提供与“B5819W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.09112
- 10+0.08362
- 30+0.08212
