XD74LS76 DIP16
Pin Arrangement
1CK
1
1PR
2
1CLR
3
1J
VCC
2CK
16
1K
15
1Q
14
1Q
4
13
GND
5
12
2K
11
2Q
10
2Q
9
2J
6
2PR
7
2CLR
8
J
CK K
PR
CLR
Q
Q
K CK J
CLR
PR
Q
Q
(Top view)
Function Table
Inputs
Outputs
Preset
L
Clear
H
Clock
X
J
X
K
X
Q
H
Q
L
H
L
L
L
X
X
X
X
X
X
L
H*
H
H*
H
H
H
H
L
H
L
L
Q0
H
Q0
L
H
H
H
H
L
H
H
H
L
H
Toggle
H
H
H
X
X
Q0
Q0
H; high level, L; low level, X; irrelevant, ↓; transition from high to low level,
Q0; level of Q before the indicated steady-state input conditions were established.
Q0; complement of Q0 or level of Q before the indicated steady-state input conditions were established.
Toggle; each output changes to the complement of its previous level on each active transition indicated by ↓.
* This configuration is nonstable; that is, it will not persist when preset and clear inputs return to their inactive (high) level.
Block Diagram (1/2)
Q
Q
Clear
Preset
K
J
Clock
1
XD74LS76 DIP16
Absolute Maximum Ratings
Item
Supply voltage
Symbol
VCC
Ratings
7
Unit
V
VIN
PT
7
400
V
mW
Tstg
–65 to +150
°C
Input voltage
Power dissipation
Storage temperature
Note: Voltage value, unless otherwise noted, are with respect to network ground terminal.
Recommended Operating Conditions
Item
Supply voltage
Symbol
VCC
Min
4.75
Typ
5.00
Max
5.25
Unit
V
IOH
IOL
–400
8
µA
mA
Topr
fclock
–20
75
30
°C
MHz
Output current
Operating temperature
Clock frequency
Pulse width
Clock High
Clear Preset Low
tw
tw
ns
Setup time
“H” Data
“L” Data
tsu
tsu
20↓
20↓
ns
th
0↓
ns
Hold time
Electrical Characteristics
(Ta = –20 to +75 °C)
Item
Input voltage
Symbol
VIH
min.
2.0
typ.*
max.
Unit
V
VIL
0.8
V
VOH
2.7
V
VCC = 4.75 V, VIH = 2 V, VIL = 0.8 V,
IOH = –400 µA
VOL
0.5
0.4
V
IOL = 8 mA
IOL = 4 mA
60
80
µA
VCC = 5.25 V, VI = 2.7 V
–0.4
–0.8
–0.8
–0.8
mA
VCC = 5.25 V, VI = 0.4 V
0.1
0.3
0.3
0.4
mA
VCC = 5.25 V, VI = 7 V
IOS
–20
–100
mA
VCC = 5.25 V
ICC
4
6
mA
VCC = 5.25 V
Output voltage
J, K
Clear
Preset
Clock
Input
current
J, K
Clear
Preset
Clock
J, K
Clear
Preset
Clock
Short-circuit output
current
Supply current***
IIH
IIL**
II
Condition
VIL = 0.8 V
Input clamp voltage
VIK
–1.5
V
VCC = 4.75 V, IIN = –18 mA
Notes: * VCC = 5 V, Ta = 25°C
** IIL should not be measured when preset and clear inputs are low at same time.
*** With all outputs open, ICC is measured with the Q and Q outputs high in turn.
At the time of measurement, the clock input is grounded.
2
XD74LS76 DIP16
Switching Characteristics
(VCC = 5 V, Ta = 25°C)
Item
Symbol
Maximum clock frequency
fmax
tPLH
Propagation delay time
Inputs
Outputs
Clear
Preset
Clock
tPHL
Q, Q
min.
typ.
max.
Unit
30
45
15
MHz
ns
15
ns
Condition
CL = 15 pF, RL = 2 kΩ
Timing Definition
tw
3V
1.3 V
1.3 V
1.3 V
Clock
tsu
th
tsu
0V
th
3V
1.3 V
1.3 V
1.3 V
J, K
0V
"H" Data
"L" Data
Testing Method
Test Circuit
1. ƒmax, tPLH, tPHL, (Clock→Q, Q)
VCC
Output Q
Input 4.5V
RL
J
P.G.
Zout=50Ω
PR
Load circuit 1
Q
CL
CK
Output Q
K
CLR
Notes:
Q
1. Test is put into the each flip-flop.
2. CL includes probe and jig capacitance.
3. All diodes are 1S2074(H).
3
Same as Load Circuit 1.
XD74LS76 DIP16
2. tPHL, tPLH (Clear, Preset→ Q, Q)
VCC
Input
Output Q
P.G.
Zout=50Ω
RL
PR
Load circuit 1
Q
J
CL
4.5V
CK
Input
Output Q
K
Q
CLR
P.G.
Zout=50Ω
Notes:
Waveforms 1
tTLH
tTHL
tw(L)
90% 90%
1.3 V 1.3 V
Clock
10%
3V
1.3 V
1.3 V
10%
0V
tw(H)
tPLH
tPHL
VOH
1.3 V
Q
tPHL
1.3 V
VOL
tPLH
Q
VOH
1.3 V
1.3 V
VOL
Note:
Clock input pulse; tTLH ≤ 15 ns, tTHL ≤ 6 ns, PRR = 1 MHz, duty cycle = 50% and for fmax.,
tTLH = tTHL ≤ 2.5 ns
4
XD74LS76 DIP16
Waveforms 2
tTHL
Clear
tTLH
90%
1.3V
10%
3V
90%
1.3V
10%
tw (CLR)
0V
tTHL
tTLH
90%
1.3V
10%
Preset
90%
1.3V
10%
tw (PR)
3V
0V
tPHL
tPLH
1.3V
Q
VOH
1.3V
tPLH
VOL
VOH
Q
Note:
1.3V
1.3V
tPHL
Crear and preset input pulse; tTLH ≤ 15 ns, tTHL ≤ 6 ns, PRR = 1 MHz,
DIP
5
VOL
很抱歉,暂时无法提供与“XD74LS76”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.20590
- 50+1.70060
- 150+1.51900
- 500+1.29220
