XL5532
XL5532
    XINLUDA(信路达)
    SOP-8
    通用放大器 SOP-8
XL5532 数据手册
XL5532 SOP-8 XD5532 DIP-8 1 Features 3 Description • The XDXL/5532 devices are high-performance operational amplifiers combining excellent DC and AC characteristics. They feature very low noise, high output-drive capability, high unity-gain and maximum-output-swing bandwidths, low distortion, high slew rate, inputprotection diodes, and output short-circuit protection. These operational amplifiers are compensated internally for unity-gain operation. These devices have specified maximum limits for equivalent input noise voltage. 1 • • • • • Equivalent Input Noise Voltage: 5 nV/√Hz Typ at 1 kHz Unity-Gain Bandwidth: 10 MHz Typ Common-Mode Rejection Ratio: 100 dB Typ High DC Voltage Gain: 100 V/mV Typ Peak-to-Peak Output Voltage Swing 26 V Typ With VCC± = ±15 V and RL = 600 Ω High Slew Rate: 9 V/μs Typ 2 Applications • • • • • • • AV Receivers Embedded PCs Netbooks Video Broadcasting and Infrastructure: Scalable Platforms DVD Recorders and Players Multichannel Video Transcoders RIN Pro Audio Mixers VIN 4 Simplified Schematic + RG VOUT RF 1 1 XL5532 SOP-8 XD5532 DIP-8 5 Pin Configuration and Functions XDXL / 5532 (TOP VIEW) 1OUT 1 8 VCC+ 1IN– 2 7 2OUT 1IN+ 3 6 2IN– VCC– 4 5 2IN+ Pin Functions PIN NAME NO. 1IN+ 3 1INOUT1 TYPE DESCRIPTION I Noninverting input 2 I Inverting Input 1 O Output 2IN+ 5 I Noninverting input 2IN- 6 I Inverting Input 2OUT 7 O Output VCC+ 8 — Positive Supply VCC- 4 — Negative Supply 2 XL5532 SOP-8 XD5532 DIP-8 6 Specifications 6.1 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1) VCC+ Supply voltage (2) VCC VCC– Input voltage, either input (2) (3) Input current (4) MIN MAX 0 22 V V –22 0 VCC– VCC+ –10 10 Duration of output short circuit (5) Operating virtual-junction temperature Tstg Storage temperature range (2) (3) (4) (5) V mA Unlimited TJ (1) UNIT 150 –65 150 °C °C Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. All voltage values, except differential voltages, are with respect to the midpoint between VCC+ and VCC–. The magnitude of the input voltage must never exceed the magnitude of the supply voltage. Excessive input current will flow if a differential input voltage in excess of approximately 0.6 V is applied between the inputs, unless some limiting resistance is used. The output may be shorted to ground or either power supply. Temperature and/or supply voltages must be limited to ensure the maximum dissipation rating is not exceeded. 6.2 ESD Ratings VALUE V(ESD) (1) (2) Electrostatic discharge Human body model (HBM), per ANSI/ESDA/JEDEC JS-001, all pins (1) 2000 Charged device model (CDM), per JEDEC specification JESD22C101, all pins (2) 1000 UNIT V JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. 6.3 Recommended Operating Conditions VCC+ Supply voltage VCC– Supply voltage TA XDXL/5532 Operating free-air temperature MIN MAX 5 15 UNIT V –5 –15 V 0 70 °C 6.4 Thermal Information XDXL/5532 THERMAL METRIC (1) D P PS UNIT 95 °C/W 8 PINS RθJA (1) (2) (3) Junction-to-ambient thermal resistance (2) (3) 97 85 For more information about traditional and new thermal metrics, see the IC Package Thermal Metrics application report, SPRA953. The package thermal impedance is calculated in accordance with JESD 51-7. Maximum power dissipation is a function of TJ(max), θJA, and TA. The maximum allowable power dissipation at any allowable ambient temperature is PD = (TJ(max) – TA) / θJA. Operating at the absolute maximum TJ of 150°C can affect reliability. 3 XL5532 SOP-8 XD5532 DIP-8 6.5 Electrical Characteristics VCC± = ±15 V, TA = 25°C (unless otherwise noted) TEST CONDITIONS (1) PARAMETER VIO Input offset voltage IIO Input offset current IIB Input bias current VICR Common-mode input-voltage range VOPP Maximum peak-to-peak output-voltage swing TA = 25°C VO = 0 TYP MAX 0.5 4 TA = Full range (2) 5 TA = 25°C 10 TA = Full range (2) 200 TA = Full range (2) RL ≥ 2 kΩ, VO±10 V 800 1000 RL ≥ 600 Ω, VCC± = ±15 V Large-signal differential-voltage amplification 150 200 TA = 25°C RL ≥ 600 Ω, VO = ±10 V AVD MIN UNIT mV nA nA ±12 ±13 V V 24 26 TA = 25°C 15 50 TA = Full range (2) 10 TA = 25°C 25 TA = Full range (2) 15 V/mV 100 Avd Small-signal differential-voltage amplification f = 10 kHz 2.2 V/mV BOM Maximum output-swing bandwidth RL = 600 Ω, VO = ±10 V 140 kHz B1 Unity-gain bandwidth RL = 600 Ω, CL = 100 pF ri Input resistance zo Output impedance 30 AVD = 30 dB, RL = 600 Ω, f = 10 kHz 10 MHz 300 kΩ 0.3 Ω dB CMRR Common-mode rejection ratio VIC = VICR min 70 100 kSVR Supply-voltage rejection ratio (ΔVCC±/ΔVIO) VCC± = ±9 V to ±15 V, VO = 0 80 100 IOS Output short-circuit current 10 38 60 mA ICC Total supply current VO = 0, No load 8 16 mA Crosstalk attenuation (VO1/VO2) V01 = 10 V peak, f = 1 kHz (1) (2) dB 110 dB All characteristics are measured under open-loop conditions, with zero common-mode input voltage, unless otherwise specified. Full temperature ranges are: 0°C to 70°C for the XDXL/5532 devices. 6.6 Operating Characteristics VCC± = ±15 V, TA = 25°C (unless otherwise noted) XDXL/5532 PARAMETER SR TEST CONDITIONS Slew rate at unity gain Overshoot factor Vn Equivalent input noise voltage In Equivalent input noise current MIN TYP MAX XDXL/5532 MIN TYP MAX UNIT 9 9 V/μs 10 10 % f = 30 Hz 8 8 10 f = 1 kHz 5 5 6 f = 30 Hz 2.7 2.7 f = 1 kHz 0.7 0.7 VI = 100 mV, RL = 600 Ω, AVD = 1, CL = 100 pF 4 nV/√Hz pA/√Hz XL5532 SOP-8 XD5532 DIP-8 1.6 16 1.4 Equivalent input noise current (pA) 18 14 12 10 8 6 4 2 0 10 100 1000 Frequency (Hz) 10000 1.2 1 0.8 0.6 0.4 0.2 0 10 100000 Figure 1. Equivalent Input Noise Voltage vs Frequency 100 Frequency (Hz) 160 140 120 100 80 60 40 20 0 -40 -20 0 1000 Figure 2. Equivalent Input Noise Current vs Frequency 180 Output Swing Bandwidth (kHz) Equivalent input noise Voltage (nV) 6.7 Typical Characteristics 20 40 Temperature (C) 60 80 Figure 3. Output Swing Bandwidth vs Temperature at VCC = ±10 V 5 100 XL5532 SOP-8 XD5532 DIP-8 7 Detailed Description 7.1 Overview The XDXL/5532 devices are high-performance operational amplifiers combining excellent dc and ac characteristics. They feature very low noise, high output-drive capability, high unity-gain and maximum-output-swing bandwidths, low distortion, high slew rate, input-protection diodes, and output shortcircuit protection. These operational amplifiers are compensated internally for unity-gain operation. These devices have specified maximum limits for equivalent input noise voltage. 7.2 Functional Block Diagram VCC+ 36 pF IN+ 37 pF 14 pF 15 W OUT 7 pF IN– 15 W 460 W VCC– Component values shown are nominal. 7.3 Feature Description 7.3.1 Unity-Gain Bandwidth The unity-gain bandwidth is the frequency up to which an amplifier with a unity gain may be operated without greatly distorting the signal. The XDXL/5532 devices have a 10-MHz unity-gain bandwidth. 7.3.2 Common-Mode Rejection Ratio The common-mode rejection ratio (CMRR) of an amplifier is a measure of how well the device rejects unwanted input signals common to both input leads. It is found by taking the ratio of the change in input offset voltage to the change in the input voltage and converting to decibels. Ideally the CMRR would be infinite, but in practice, amplifiers are designed to have it as high as possible. The CMRR of the XDXL/5532 devices is 100 dB. 7.3.3 Slew Rate The slew rate is the rate at which an operational amplifier can change its output when there is a change on the input. The XDXL/5532 devices have a 9-V/ms slew rate. 7.4 Device Functional Modes The XDXL/5532 devices are powered on when the supply is connected. Each of these devices can be operated as a single supply operational amplifier or dual supply amplifier depending on the application. 6 XL5532 SOP-8 XD5532 DIP-8 8 Application and Implementation 8.1 Typical Application Some applications require differential signals. Figure 4 shows a simple circuit to convert a single-ended input of 2 V to 10 V into differential output of ±8 V on a single 15-V supply. The output range is intentionally limited to maximize linearity. The circuit is composed of two amplifiers. One amplifier acts as a buffer and creates a voltage, VOUT+. The second amplifier inverts the input and adds a reference voltage to generate VOUT–. Both VOUT+ and VOUT– range from 2 V to 10 V. The difference, VDIFF, is the difference between VOUT+ and VOUT–. R2 15 V R1 VOUT+ R3 VREF 12 V + R4 VDIFF ± VOUT+ + VIN Figure 4. Schematic for Single-Ended Input to Differential Output Conversion 8.1.1 Design Requirements The design requirements are as follows: • Supply voltage: 15 V • Reference voltage: 12V • Input: 2 V to 10 V • Output differential: ±8 V 7 XL5532 SOP-8 XD5532 DIP-8 Typical Application (continued) 8.1.2 Detailed Design Procedure The circuit in Figure 4 takes a single-ended input signal, VIN, and generates two output signals, VOUT+ and VOUT– using two amplifiers and a reference voltage, VREF. VOUT+ is the output of the first amplifier and is a buffered version of the input signal, VIN Equation 1. VOUT– is the output of the second amplifier which uses VREF to add an offset voltage to VIN and feedback to add inverting gain. The transfer function for VOUT– is Equation 2. VOUT+ = VIN (1) æ R 4 ö æ R2 ö R2 Vout - = Vref ´ ç - Vin ´ ÷ ´ ç1 + ÷ R1 ø R1 è R3+ R 4 ø è (2) The differential output signal, VDIFF, is the difference between the two single-ended output signals, VOUT+ and VOUT–. Equation 3 shows the transfer function for VDIFF. By applying the conditions that R1 = R2 and R3 = R4, the transfer function is simplified into Equation 6. Using this configuration, the maximum input signal is equal to the reference voltage and the maximum output of each amplifier is equal to the VREF. The differential output range is 2×VREF. Furthermore, the common mode voltage will be one half of VREF (see Equation 7). æ öæ æ R ö R4 R2 ö VD IF F = V O U T + - V O U T - = VIN ´ ç 1 + 2 ÷ - VR E F ´ ç ÷ ç1 + ÷ R1 ø R1 ø è è R3 + R4 ø è VOUT+ = VIN VOUT– = VREF – VIN VDIFF = 2×VIN – VREF (3) (4) (5) (6) + VOUT - ö 1 æV Vcm = ç OUT + ÷ = VREF 2 è ø 2 (7) 8.1.2.1 Amplifier Selection Linearity over the input range is key for good dc accuracy. The common mode input range and the output swing limitations determine the linearity. In general, an amplifier with rail-to-rail input and output swing is required. Bandwidth is a key concern for this design. Since the 5532 has a bandwidth of 10 MHz, this circuit will only be able to process signals with frequencies of less than 10 MHz. 81.2.2 Passive Component Selection Because the transfer function of VOUT– is heavily reliant on resistors (R1, R2, R3, and R4), use resistors with low tolerances to maximize performance and minimize error. This design used resistors with resistance values of 36 kΩ with tolerances measured to be within 2%. But, if the noise of the system is a key parameter, the user can select smaller resistance values (6 kΩ or lower) to keep the overall system noise low. This ensures that the noise from the resistors is lower than the amplifier noise. 8.1.3 Application Curves The measured transfer functions in Figure 5, Figure 6, and Figure 7 were generated by sweeping the input voltage from 0 V to 12V. However, this design should only be used between 2 V and 10 V for optimum linearity. 8 XL5532 SOP-8 XD5532 DIP-8 12 8 10 4 8 VOUT+ (V) 12 0 6 ±4 4 ±8 2 0 ±12 0 1 2 3 4 5 6 7 8 9 10 11 VIN (V) 12 0 1 2 3 4 Figure 5. Differential Output Voltage vs Input Voltage 10 8 6 4 2 0 1 2 3 4 6 7 8 9 10 11 12 C001 Figure 6. Positive Output Voltage Node vs Input Voltage 12 0 5 VIN (V) C003 VOUTt (V) VDIFF (V) Typical Application (continued) 5 6 VIN (V) 7 8 9 10 11 12 C002 Figure 7. Positive Output Voltage Node vs Input Voltage 9 XL5532 SOP-8 XD5532 DIP-8 9 Power Supply Recommendations The XDXL/5532 devices are specified for operation over the range of ±5 to ±15 V; many specifications apply from 0°C to 70°C (XDXL/5532) The Typical Characteristics section presents parameters that can exhibit significant variance with regard to operating voltage or temperature. Place 0.1-μF bypass capacitors close to the power-supply pins to reduce errors coupling in from noisy or high impedance power supplies. For more detailed information on bypass capacitor placement, refer to the Layout Guidelines. 10 Layout 10.1 Layout Guidelines • • • • • • For best operational performance of the device, use good PCB layout practices, including: Noise can propagate into analog circuitry through the power pins of the circuit as a whole and the operational amplifier. Bypass capacitors are used to reduce the coupled noise by providing low impedance power sources local to the analog circuitry. – Connect low-ESR, 0.1-μF ceramic bypass capacitors between each supply pin and ground, placed as close to the device as possible. A single bypass capacitor from V+ to ground is applicable for single supply applications. Separate grounding for analog and digital portions of circuitry is one of the simplest and most-effective methods of noise suppression. One or more layers on multilayer PCBs are usually devoted to ground planes. A ground plane helps distribute heat and reduces EMI noise pickup. Make sure to physically separate digital and analog grounds, paying attention to the flow of the ground current. For more detailed information, refer to Circuit Board Layout Techniques, SLOA089. To reduce parasitic coupling, run the input traces as far away from the supply or output traces as possible. If it is not possible to keep them separate, it is much better to cross the sensitive trace perpendicular as opposed to in parallel with the noisy trace. Place the external components as close to the device as possible. Keeping RF and RG close to the inverting input minimizes parasitic capacitance, as shown in Layout Example. Keep the length of input traces as short as possible. Always remember that the input traces are the most sensitive part of the circuit. Consider a driven, low-impedance guard ring around the critical traces. A guard ring can significantly reduce leakage currents from nearby traces that are at different potentials. 10.2 Layout Example VIN RIN + RG VOUT RF Figure 8. Operational Amplifier Schematic for Noninverting Configuration 10 XL5532 SOP-8 XD5532 DIP-8 Layout Example (continued) Place components close to device and to each other to reduce parasitic errors Run the input traces as far away from the supply lines as possible VS+ RF OUT1 VCC+ GND IN1í OUT2 VIN IN1+ IN2í VCCí IN2+ RG GND RIN Use low-ESR, ceramic bypass capacitor Only needed for dual-supply operation GND VS(or GND for single supply) Ground (GND) plane on another layer Figure 9. Operational Amplifier Board Layout for Noninverting Configuration 11 XL5532 SOP-8 XD5532 DIP-8 SCALE 2.800 SMALL OUTLINE INTEGRATED CIRCUIT C SEATING PLANE .228-.244 TYP [5.80-6.19] A .004 [0.1] C PIN 1 ID AREA 6X .050 [1.27] 8 1 2X .150 [3.81] .189-.197 [4.81-5.00] NOTE 3 4X (0 -15 ) 4 5 B 8X .012-.020 [0.31-0.51] .010 [0.25] C A B .150-.157 [3.81-3.98] NOTE 4 .069 MAX [1.75] .005-.010 TYP [0.13-0.25] 4X (0 -15 ) SEE DETAIL A .010 [0.25] .004-.010 [0.11-0.25] 0 -8 .016-.050 [0.41-1.27] DETAIL A (.041) [1.04] TYPICAL NOTES: 1. Linear dimensions are in inches [millimeters]. Dimensions in parenthesis are for reference only. Controlling dimensions are in inches. Dimensioning and tolerancing per ASME Y14.5M. 2. This drawing is subject to change without notice. 3. This dimension does not include mold flash, protrusions, or gate burrs. Mold flash, protrusions, or gate burrs shall not exceed .006 [0.15] per side. 4. This dimension does not include interlead flash. 5. Reference JEDEC registration MS-012, variation AA. 12 XL5532 SOP-8 XD5532 DIP-8 13
XL5532 价格&库存
很抱歉,暂时无法提供与“XL5532”相匹配的价格&库存,您可以联系我们找货
