SK102 THRU SK1010
Reverse Voltage - 20 to 100 Volts
Forward Current - 10.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
DO-214AB/SMC
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
0.245(6.22)
0.220(5.59)
0.126 (3.20)
0.114 (2.90)
Built-in strain relief,ideal for automated placement
0.280(7.11)
0.260(6.60)
High forward surge current capability
High temperature soldering guaranteed:
0.012(0.305)
0.006(0.152)
250 °C/10 seconds at terminals
0.103(2.62)
0.079(2.06)
0.060(1.52)
0.030(0.76)
Mechanical Data
0.008(0.203)MAX.
0.320(8.13)
0.305(7.75)
Case: JEDEC DO-214AB/SMC molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denotes cathode end Mounting
Position: Any
Weight : 0.007 ounce, 0.25 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 10.0A
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
VRRM
VRMS
VDC
MDD
SK102
MDD
SK103
21
30
MDD
MDD
SK1035 SK104
35
24.5
35
40
28
40
MDD
MDD
SK1045 SK106
45
31.5
45
60
42
60
MDD
SK108
80
56
80
MDD
SK1010
100
70
100
UNITS
V
V
V
I(AV)
10.0
A
IFSM
250
A
VF
IR
0.65
0.85
V
1.0
mA
CJ
RJA
18.0
℃/W
TJ
-50 to +150
TSTG
-50 to +150
pF
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
DN:T20519A0
http://www.microdiode.com
Rev:2020A0
Page :1
SK102 THRU SK1010
Typical Characterisitics
Figure 1
Typical Forward Characteristics
100
Figure 2
Forward Derating Curve
600
12
400
10
200
100
8.0
60
6.0
40
Amps
SK102-SK1045
SK105-SK1010
Amps
10
2.0
Single Phase, Half Wave
60Hz Resistive or Inductive Load
6
4
80
100
2
120
140
160
180
°C
25°C
Average Forward Rectified Current - Amperes versus
1
Lead Temperature - C
.6
.4
.2
.1
.2
.4
.6
.8
1.0
1.4
1.2
Volts
Instantaneous Forward Current - Amperes versus
Instantaneous Forward Voltage - Volts
Figure 3
Junction Capacitance
100
600
400
200
pF
TJ=25°C
100
60
40
.1
.2
.4
1
2
4
10
100
200
400
1000
Volts
Junction Capacitance - pF versus
The curve above is for reference only.
Rev:2020A0
Page :2
SK102 THRU SK1010
Figure 4
Typical Reverse Characteristics
Figure 5
Peak Forward Surge Current
600
10
500
6
4
400
2
300
100°C
Amps
1
200
.6
100
.4
mAmps
1
2
4
6
8 10
60 80
100
75°C
mAmps
Cycles
.1
Peak Forward Surge Current - Amperes versus Number Of
.06
Cycles At 60Hz - Cycles
.04
.02
25°C
SK102-SK1045
SK105-SK1010
.01
.006
.004
.002
.001
60
80
100
120
140
Volts
Instantaneous Reverse Leakage Current - MicroAmperes versus
Percent Of Rated Peak Reverse Voltage - Volts
Rev:2020A0
Page :2
SK102 THRU SK1010
Packing information
unit:mm
P0
P1
Item
Symbol
Tolerance
SMC
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
6.15
8.41
2.42
1.50
330.00
50.00
13.00
1.75
7.50
8.00
4.00
2.00
0.25
16.00
16.50
d
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
SMC
13"
3,000
4.0
BOX
(pcs)
6000
INNER
BOX
(mm)
REEL
DIA,
(mm)
190*190*41
330
CARTON
SIZE
(mm)
CARTON
(pcs)
365*365*340
42000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Unit (inch)
Symbol
Unit (mm)
A
4.3
0.170
B
0.160
C
4.1
7.9
0.311
D
3.8
0.150
E
12
0.472
Important Notice and Disclaimer
Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the latest product information and
specifications before final design,purchase or use.
Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its
products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application
assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with
products which are purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode
Electronics (Jiangsu).
Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support
devices or systems without express written approval of Microdiode Electronics (Jiangsu).
Rev:2020A0
Page :3
很抱歉,暂时无法提供与“SK1045-SMC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.67680
- 50+0.62604
- 200+0.58374
- 600+0.54144
- 1500+0.50760
- 3000+0.48645
