PART CODE:
SMBSK1045S1045
SPECIFICATION SHEET
SPECIFICATION SHEET NO.
N1230- SMBSK1045S1045
DATE
Dec.30, 2021
REVISION
A0
DESCRIPITION
SMD Schottky Barrier Rectifier, 2 Pads, SMB series,
SK1045B Type Reverse Voltage 45V Max. Forward Current 10A Max.
Operating Temp. Range -50°C ~+150°C,
Package in Tape/Reel, 3000pcs/Reel
RoHS/RoHS III compliant
CUSTOMER
CUSTOMER PART NUMBER
CROSS REF. PART NUMBER
ORIGINAL PART NUMBER
MDD SK1045B
PART CODE
SMBSK1045S1045
VENDOR APPROVE
Issued/Checked/Approved
DATE: Dec.30, 2021
CUSTOMER APPROVE
DATE:
1/8/2022
NextGen Components, Inc.
1
sales@NextGenComponent.com
www.NextGenComponent.com
PART CODE:
SMBSK1045S1045
SMD SCHOTTKY BARRIER RECTIFIER SMB SERIES
MAIN FEATURE
• The plastic package carries Underwriters Laboratory Flammability Classification 94V-0
• Low reverse leakage
• Built-in strain relief
• Low power loss, high efficiency
• High forward surge current capability
• High temperature soldering guaranteed: 250℃/ 10 seconds at terminals
• Metal silicon junction, majority carrier conduction
APPLICATION
• For surface mounted applications
RFQ
PART CODE GUIDE
Request For Quotation
SMB
SK1045
S
1045
1
2
3
4
1) SMB: SMD Schottky Barrier Rectifier, 2 Pads, Package SMB series
2) SK1045: Type code for original part number SK1045B
3) S: Package code, Tape/reel, 3000pcs/reel.
4) 1045: Specification code for Reverse Voltage 45V Max. Forward Current 10A Max.
2
PART CODE:
SMBSK1045S1045
DIMENSION (Unit: Inch/mm)
Marking: SK1045B
Image for reference
SMB/DO-214AA
Recommend Pad Layout
Symbol
Unit
(inch)
Unit
(mm)
A
0.110
2.80
B
0.094
2.40
C
0.181
4.60
D
0.086
2.20
E
0.276
7.00
3
PART CODE:
SMBSK1045S1045
MECHANICAL DATA
Case
Terminals
Polarity
Mounting
Position
Weight
per piece
JEDEC SMB/DO-214AA
molded plastic body
Solder plated,
Solderable per
MIL-STD-750,
Method 2026
Polarity symbol
marking on case
Any
0.0020 Ounce,
0.070 grams
MAX. RATING & CHARACTERISTICS
Parameter
SYMBOLS
VALUE
Min.
Typical
UNITS
Max.
Repetitive peak reverse voltage
V RRM
45
Volts
RMS voltage
V RMS
31.5
Volts
DC blocking voltage
V DC
45
Volts
Average forward output rectified current
I AV
10
A
at TL (see fig.1)
I FSM
Peak forward surge current 8.3ms single half
250
A
sine-wave superimposed on rated load
(JEDEC Method)
Instantaneous forward voltage at 10A
DC reverse current at rated DC
blocking voltage
TA=25℃
VF
0.65
Volts
IR
1.0
mA
mA
TA=100℃
Junction capacitance (NOTE 2)
CJ
500
pF
Thermal resistance (Note 3)
R QJA
18.0
°C/W
Operating junction temperature range
Storage temperature range
TJ
-50
+150
°C
T STG
-50
+150
°C
Note
1. Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz, resistive or inductive load, for
capacitive load current derate by 20%.
2. Measured at 1.0MHz and applied reverse voltage of 4.0Voltage
3. P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas.
4
PART CODE:
SMBSK1045S1045
RELIABILITY
Number
Experiment Items
Experiment Method And Conditions
Reference
Documents
1
Solder Resistance Test
Test 250°C± 5°C for 10 ± 2 sec.
Immerse body into solder 1/16” ± 1/32"
MIL-STD-750D
METHOD-2031.2
2
Solderability Test
230°C ±5°C for 5 sec.
MIL-STD-750D
METHOD-2026.1 0
3
Pull Test
1 kg in axial lead direction for 10 sec.
MIL-STD-750D
METHOD-2036.4
4
Bend Test
0.5Kg Weight Applied To Each Lead,
Bending Arcs 90 °C ± 5 °C For 3 Times
MIL-STD-750D
METHOD-2036.4
5
High Temperature Reverse
Bias Test
TA=100°C for 1000 Hours at VR=80%
Rated VR
MIL-STD-750D
METHOD-1038.4
6
Forward Operation Life Test
TA=25°C Rated Average Rectified
Current
MIL-STD-750D
METHOD-1027.3
7
Intermittent Operation Life
Test
On state: 5 min with rated IRMS Power
Off state: 5 min with Cool Forced Air.
On and off for 1000 cycles.
MIL-STD-750D
METHOD-1036.3
8
Pressure Cooker Test
15 PSIG, TA=121°C, 4 hours
MIL-S-19500
APPENOIXC
9
Temperature Cycling Test
-55°C~+125°C; 30 Minutes For Dwelled
Time 5 minutes for transferred time.
Total: 10 cycles.
MIL-STD-750D
METHOD-1051.7
10
Thermal Shock Test
0°C for 5 minutes., 100°C for 5minutes,
Total: 10 cycles
MIL-STD-750D
METHOD-1056.7
11
Forward Surge Test
8.3ms Single Sale Sine-wave One Surge.
MIL-STD-750D
METHOD-4066.4
12
Humidity Test
TA=65°C, RH=98% for 1000 hours.
MIL-STD-750D
METHOD-1021.3
13
High Temperature Storage
life Test
150°C for 1000 Hours
MIL-STD-750D
METHOD-1031.5
5
PART CODE:
SMBSK1045S1045
SUGGESTED REFLOW PROFILE (For Reference Only)
Profile Feature
Pb-Free Assembly
Average Ramp-up Rate (Ts Max to Tp)
3℃/second Max
Preheat
Temperature Min (Ts Min.)
150℃
Temperature Max (Ts Max.)
200℃
Time (ts Min. to ts Max.)
60~180 seconds
Temperature (TL)
217℃
Time (tL)
60~150 seconds
Time maintained
above
Peak/Classification Temperature (Tp)
250 ℃
Time within 5℃ of actual Peak Temperature (tp)
10 seconds
Ramp-down rate
6 ℃ /Second Max.
Time 25 ℃ to Peak Temperature
6 minutes Max.
Suggest reflow times
3 Times Max.
6
PART CODE:
SMBSK1045S1045
RATINGS AND CHARACTERISTIC CURVES (For Reference Only)
7
PART CODE:
SMBSK1045S1045
8
PART CODE:
SMBSK1045S1045
9
PART CODE:
SMBSK1045S1045
10
PART CODE:
SMBSK1045S1045
TAPE/REEL (Unit: mm)
All Devices are packed in accordance with EIA standard RS-481-A and specifications.
Item
Symbol
Tolerance
SMB/DO-214AA
Carrier width
A
0.1
3.81
Carrier Length
B
0.1
5.41
Carrier Depth
C
0.1
2.42
Sprocket hole
d
0.05
1.50
13”Reel outside diameter
D
2.0
330.00
13”Reel inner diameter
D1
Min.
50.00
7”Reel outside diameter
7”Reel inner diameter
Feed hole diameter
D2
0.5
13.00
Sprocket hole position
E
0.1
1.75
Punch hole position
F
0.1
5.55
Punch hole pitch
P
0.1
8.00
Sprocket hole pitch
P0
0.1
4.00
Embossment center
P1
0.1
2.00
Overall tape thickness
T
0.1
0.30
Tape width
W
0.3
12.00
Reel width
W1
1.0
12.30
11
PART CODE:
SMBSK1045S1045
PACKAGE For Reference
Case Code
SMB
Reel Size
13”
Reel Size
330 mm
MPQ/Reel
3000 pcs
Qty. /Box
6000 pcs
G.W/Box
6 lbs
DISCLAIMER
NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein
without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany
the sale of any such product(s) or information
12
很抱歉,暂时无法提供与“SK1045B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.67680
- 100+0.62880
- 300+0.58080
- 500+0.53280
- 2000+0.50880
- 5000+0.49440
