山东晶导微电子股份有限公司
MB1F THRU MB10F
Jingdao Microelectronics co.LTD
0.8A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER
FEATURES:
PINNING
Glass Passivated Chip Junction
Reverse Voltage - 100 to 1000 V
PIN
DESCRIPTION
1
Input Pin(~)
2
Input Pin(~)
Forward Current - 0.8 A
High Surge Current Capability
3
Output Anode(+)
Designed for Surface Mount Application
4
Output Cathode(-)
MECHANICAL DATA
• Case: MBF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 75mg 0.0026oz
3
4
2
1
MBF Package
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
MB1F
MB2F
Maximum Repetitive Peak Reverse Voltage
V RRM
100
200
400
Maximum RMS voltage
V RMS
70
140
Maximum DC Blocking Voltage
V DC
100
200
Parameter
Average Rectified Output Current
at T c = 125 °C
MB4F
MB6F
Units
MB8F
MB10F
600
800
1000
V
280
420
560
700
V
400
600
800
1000
V
IO
0.8
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
I FSM
30
A
Maximum Forward Voltage at 0.8 A
VF
1.1
V
IR
5
40
μA
Cj
13
pF
RθJA
RθJC
90
30
°C/W
T j , T stg
-55 ~ +150
°C
Maximum DC Reverse Current
at Rated DC Blocking Voltage
@ T A =25 °C
@ T A =125 °C
Typical Junction Capacitance(Note1)
Typical Thermal Resistance(Note2)
Operating and Storage Temperature Range
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad.
2016.01
MBF-A-MB1F~MB10F-0.8A1KV
Page 1 of 3
山东晶导微电子股份有限公司
MB1F THRU MB10F
Fig.2 Typical Reverse Characteristics
1.2
1.0
0.8
0.6
0.4
0.2
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
60
80
100
120
140
100
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
10
T J =25°C
1
0.5
1.0
1.5
2.0
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2016.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
MB1F THRU MB10F
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
MBF
∠ALL ROUND
C
A
a
L1
L
d
HE
e
D
e
E
MBF mechanical data
A
C
D
E
HE
d
e
L
L1
a
max
1.6
0.22
5.0
4.1
7.0
2.7
0.8
1.7
1.1
0.2
min
1.2
0.15
4.5
3.6
6.4
2.3
0.5
1.3
0.5
max
63
8.7
197
161
276
106
31
67
43
min
47
5.9
177
142
252
91
UNIT
mm
7°
8
mil
Marking
6.0
236
2.5
100
0.9
35
2.4
94
mm
Unit :
(mil)
Type number
Marking code
MB1F
MB1F
MB2F
MB2F
MB4F
MB4F
MB6F
MB6F
MB8F
MB8F
MB10F
MB10F
MBxxF
2016.01
JD512284B2
Page 3 of 3
很抱歉,暂时无法提供与“MB10F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.07212
- 100+0.06731
- 300+0.06251
- 500+0.05770
- 2000+0.05529
- 5000+0.05385
