MB1F THRU MB10F
0.8A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER
FEATURES:
Glass Passivated Chip Juntion
3
Reverse Voltage - 100 to 1000 V
4
2
Forward Current - 0.8A
1
High Surge Current Capability
MBF Package
Designed for Surface Mount Application
PINNING
MECHANICAL DATA
• Case: MBF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 75mg 0.0024oz
PIN
DESCRIPTION
1
Input Pin(~)
2
Input Pin(~)
3
Output Anode(+)
4
Output Cathode(-)
Maximum Ratin g s and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load,
f or capacitive load current derate by 20 %.
Symbols
M B1F
MB2F
MB4F
MB6F
MB8F
MB10F
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
100
200
400
600
800
1000
V
Parameter
Average Rectified Output Current
at Ta = 40 °C
0.8
A
I FSM
25
A
VF
1.0
1.1
V
IR
5.0
100
500
μA
Cj
13
pF
RθJA
RθJL
60
16
°C/W
T j , T stg
-55 ~ +150
°C
IO
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
Maximum Forward Voltage at 1 A
@ I F =0.4A
Maximum DC Reverse Current
at Rated DC Blocking Voltage
@ T A =100℃
@ I F =0.8A
@ T A =25 °C
@ T A =125 °C
Typical Junction Capacitance(Note1)
Typical Thermal Resistance(Note2)
Operating and Storage Temperature Range
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with 1.3mm 2 copper pad.
REV.08
1 of 3
MB1F THRU MB10F
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
1.0
0.8
Al. Substrate PC Board
0.6
0.4
Glass Epoxy PC Board
0.2
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
1.0
T J =25°C
0.1
00
10
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
1.0
1.5
2.0
Peak Forward Surage Current (A)
100
120
140
10
T J =25°C
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
10
1.0
10
Reverse Voltage (V)
100
Number of Cycles
REV.08
80
100
0.1
Fig.5 Maximum Non-Repetitive Peak
1
60
1
0.5
Instaneous Forward Voltage (V)
30
40
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
0.01
0.0
percent of Rated Peak Reverse Voltage (%)
Ambient Temperature (°C)
2 of 3
100
MB1F THRU MB10F
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
MBF
∠ALL ROUND
C
A
a
L1
L
d
HE
e
D
e
E
MBF mechanical data
A
C
D
E
HE
d
e
L
L1
a
max
1.6
0.22
5.0
4.1
7.0
2.7
0.7
1.7
1.1
0.2
min
1.2
0.15
4.5
3.6
6.4
2.3
0.5
1.3
0.5
max
63
8.7
197
161
276
106
28
67
43
min
47
5.9
177
142
252
91
UNIT
mm
7°
8
mil
Marking
The recommended mounting pad size
Type number
3.4
130
1.7
67
0.8
31
2.4
94
Marking code
MB1F
MB1F
MB2F
MB2F
MB4F
MB4F
MB6F
MB6F
MB8F
MB8F
MB10F
MB10F
Unit: mm
(mil)
MBxx F
REV.08
3 of 3
很抱歉,暂时无法提供与“MB10F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.12575
- 200+0.10124
- 600+0.08762
- 5000+0.07236
- 10000+0.06528
- 20000+0.06148
- 国内价格
- 1+0.09300
- 100+0.08680
- 300+0.08060
- 500+0.07440
- 2000+0.07130
- 5000+0.06944
