S8050
S8050
TRANSISTOR (NPN)
FEATURES
Complimentary to S8550
SOT-23
Collector Current: IC=0.5A
1.BASE
2.EMITTER
3.COLLECTOR
MARKING: J3Y
MAXIMUM RATINGS (TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Units
VCBO
Collector-Base Voltage
40
V
VCEO
Collector-Emitter Voltage
25
V
VEBO
Emitter-Base Voltage
5
V
IC
Collector Current -Continuous
0.5
A
PC
Collector Dissipation
0.3
W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55-150
ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified)
Parameter
Symbol
Test
conditions
Collector-base breakdown voltage
V(BR)CBO
IC= 100µA,
Collector-emitter breakdown voltage
V(BR)CEO
IC=1mA,
Emitter-base breakdown voltage
V(BR)EBO
IE=100µA,
IE=0
IB=0
IC=0
MIN
TYP
MAX
UNIT
40
V
25
V
5
V
Collector cut-off current
ICBO
VCB=40 V, IE=0
0.1
µA
ICEO
VCB=20V,
IE=0
0.1
µA
Emitter cut-off current
IEBO
VEB= 5V,
IC=0
0.1
µA
HFE(1)
VCE=1V,
IC= 50mA
200
HFE(2)
VCE=1V,
IC= 500mA
50
350
DC current gain
Collector-emitter saturation voltage
VCE(sat)
IC=500 mA, IB= 50mA
0.6
V
Base-emitter saturation voltage
VBE(sat)
IC=500 mA, IB= 50mA
1.2
V
VCE=6V,
Transition frequency
www.tw-gmc.com
fT
f=30MHz
1
IC= 20mA
150
MHz
S8050
Typical Characteristics
IC
-90
VCE
-360uA
-240uA
-200uA
-40
-160uA
-120uA
-80uA
-20
-0
-2
-4
-6
-8
COLLECTOR-EMITTER VOLTAGE
VBEsat ——
-10
COMMON EMITTER
VCE=-1V
-12
1
T a=
00 ℃
-100
IC
-500
(mA)
IC
IC
-100
0℃
10
T a=
25
T a=
-10
-500
β=10
-1
-10
(mA)
—— VBE
fT
IC
(mA)
IC
(MHz)
(mA)
400
-500
-100
COLLECTOR CURRENT
Ta=100℃
Ta=25℃
TRANSITION FREQUENCY
fT
-100
-10
COMMON EMITTER
VCE=-1V
-1
-0
-300
-600
-900
100
10
-1200
COMMON EMITTER
VCE=-6V
Ta=25℃
-1
-10
Cob/Cib
VCB/VEB
COLLECTOR POWER
DISSIPATION PC (mW)
(pF)
Cib
Cob
CAPACITANCE
PC
400
50
10
-100
COLLECTOR CURRENT
BASE-EMMITER VO
LTAGE VBE (mV)
C
IC
-500
-10
-500
-100
VCEsat
IC
COLLECTOR CURRENT
-10
COLLECTOR CURRENT
β=10
-1
-1
VCE (V)
25℃
T a=
-800
-400
IC
100
10
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
-1200
COLLECTOR CURRENT
Ta=25℃
IB=-40uA
-10
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
DC CURRENT GAIN
-280uA
-30
-0
Ta=100℃
-320uA
-50
IC
500
COMMON
EMITTER
Ta=25℃
hFE
(mA)
-60
COLLECTOR CURRENT
IC
-80
-70
hFE
-400uA
IC
(mA)
Ta
300
200
100
f=1MHz
IE=0/IC=0
Ta=25 ℃
1
-0.1
-1
REVERSE VOLTAGE
www.tw-gmc.com
-10
V
(V)
50
75
100
AMBIENT TEMPERATURE
2
Ta
125
150
S8050
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
www.tw-gmc.com
SOT-23
3
很抱歉,暂时无法提供与“S8050 SOT23”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.04896
- 100+0.04570
- 300+0.04243
- 500+0.03917
- 2000+0.03754
- 5000+0.03656
