产品承认书
SPECIFICATION FOR APPROVAL
CUSTOMER:
CUSTOMER P/N:
CND-TEK P/N. :
G2419S
1000 BASE-T POE+ MAGNETICS MODULES
DESCRIPTION:
REF NO:
QTC-001
REV/NO:
V1.02
DATE:
2015/03/02
■ SPECIFICATION
■ SAMPLE
Q’TY OF SAMPLES
PCS
FULL APPROVED
CONDITIONAL APPROVED
REJECTED
CUSTOMER'S SIGNATURE
REMARK
G2419S
1000 BASE-T MAGNETICS MODULES
V1.0.2
Feb 2, 2015
␡ൣ⻱㚄䗮⭥ᆀᴹ䲀ޜਨ
6KHQ]KHQ&1'7(.Electronics&R/WG
ޜਨൠ൰␡ൣᐲইኡ४㾯ѭ䭷街道百旺社区牛城村牛城路221号505
7(/ )$;86-
(PDLOsales2#FGWHNFRP
+WWSZZZFGWHNFRP
1. FEATURES:
1.1 Designed for long haul Gigabit Ethernet 100/1000 Base-T, full duplex applications.
1.2 Supports four pairs of category 5 UTP cable,Cable interface for isolation and low common mode emissions.
1.3 Low profile Surface Mount Packaging designed for Hi-Temp Reflow Process
1.4 Compliant with IEEE 802.3af standard for 1000 Base-T,Designed to support 1:1 Turns Ratio Transceivers.
1.5
Suitable For End-apan and Mid-span POE+ Applications 720mA Current Capadility Per POE Port
1.6 Operating Temperature range: -45℃TO +85℃
1.7 Storage temperature range: -25℃TO +125℃
2. DIMENSIONS & MARKING
3. SCHEMATICS:
4.ELECTRICAL SPECIFICATIONS @25℃
4.1 OCL :
350 μH Min. @ 100 KHz, 100mV with 8mA DC Bias
4.2 Leakage Inductance:
0.5 μH Max. @ 100KHz, 0.2V
4.3 Cw/w:
30pF Max. @ 100KHz, 0.2V
4.4 DCR:
1.20Ω Max.
4.5 Turns Ratio(±5%):
1CT:1CT(TX), 1CT:1CT(RX)
4.6 Polarity
2-23, 5-20, 8-17, 11-14 In-Phase
4.7 Insertion Loss:
-1.0 dB Max. @ 1-100MHz
4.8 Return Loss:
-16 dB Min. @ 1-30MHz
-12 dB Min. @ 30-60 MHz
-10 dB Min.@ 60-80 MHz
4.9 Cross Talk:
-42 dB Min.@ 1-60 MHz
-35 dB Min.@ 60-100 MHz
4.10 Common Mode Rejection : -40 dB Min.@ 1-30 MHz
-35dB Min.@ 60 MHz
-30dB Min.@ 80-100 MHz
4.11 Isolation HI-POT:
1500Vrms 1mA 1Second
5. Recommended Lead Free IR Reflow Soldering Curve:
Item
Soldertechnique
simulation
Temperature
Time(s)
1
Solder iron
350±10
(solder irno temp)
4~5
2
Vapor phase reflow
215±5
(vapor temp)
60±5
3
IR/convection reflow
255±5
(component temp)
30±5
Temperature ramp/immersion
and emersion rate
1℃/s~4℃/s time above 183℃
90s~120s
Note:The curve includes recommended value only, please adjust your equipment to make sure the solder
process.Details please refers to the standard J-STD-020.
6. Reliability Test Criteria:
6.1 Terminal strength: Pull test withstand 9.8N 60+/-0.5S no looseness or movement.
6.2 Solderbility: Dipped in 245℃+/-5℃ molten solder for 3+/-0.5 seconds,95% min shall be smooth any and
bright.
6.3 Resistance to soldering heat : Convection reflow condition setting: peak temperature at 260℃+0/-5℃
above 217℃ for 90-180 seconds, ramp-up rate 2-3℃/s. Ramp-down rate 6℃/s Max. No mechanical problem
found. No electrical failure found per our specification.
6.4 Vibration: 1.5mm amplitude total excursion 10-55-10 Hz traversed in 1minute, x.y.z, axis for 2 hours. Shall
not be any abnormality.
6.5 Random drop (Packing condition): Height 60cm, 3 times on the wood floorboard ,shall not be any
abnormality.
6.6 Dry heat: 100+/-2℃ 96 hours.
6.7 Cold: -20+/-2℃ 96 hours.
6.8 Damp Heat: 60+/-2℃, 93+/-3% RH 96 hours.
6.9 Change of temperature: exposed 5 cycle; each consisting of 30 minutes at -20+/-2℃,2-3minutes at 20+/2℃,30 minutes at 85+/-2℃, 2-3 minutes at 20+/-2℃.
Packing
Specification
Packing Specification
1ȻEach Reel Qty漡850pcs/pkg
2ȻTotal unit transformer in carton:
850 灤�5 (Total Reel in Carton) = 4250 PCS
很抱歉,暂时无法提供与“G2419S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.42920
- 10+2.23820
- 30+2.20000
