Teensy-LC Without Pins
PRODUCT ID: 2419
Description
Teensy‐LC (Low Cost) is a powerful 32 bit microcontroller board, with a rich set of hardware
peripherals, at a very affordable price!
Teensy‐LC delivers an impressive collection of capabilities to make modern electronic projects simpler.
It features an ARM Cortex‐M0+ processor at 48 MHz, 62K Flash, 8K RAM, 12 bit analog input & output,
hardware Serial, SPI & I2C, USB, and a total of 27 I/O pins. See the technical specifications and pinouts
for details. Teensy‐LC maintains the same form‐factor as Teensy 3.1, with most pins offering similar
peripheral features.
Real Hardware Serial
Most modern projects involve serial communication with sensors, other chips, other systems, or even
the internet. Hardware serial ports greatly simplify projects and enable excellent performance. Teensy‐
LC provide plenty of serial connectivity: 2 SPI ports, 2 I2C, and 3 Serial ports. All 3 serial ports are
supported by high quality drivers in Teensyduino, with both transmit and receive buffering, and even
support for RS485 transmitter enable. Teensy‐LC will be ideal for inexpensive "Internet Of Things"
projects when paired with a ESP8266 Wifi module, which requires a fast hardware serial or SPI port.
Efficient USB Communication
Teensy‐LC has the same powerful USB hardware as Teensy 3.1. All USB data transfer is done directly to
memory with minimal CPU overhead. Teensy‐LC supports USB Serial, MIDI, Keyboard (international
layouts), Mouse, Joystick, and RawHID protocols. A full set of 16 bidirectional USB endpoints are
supported by the hardware, allowing any type of USB device. As more USB protocols are added to
Teensyduino, despite its low cost, Teensy‐LC will be up the task.
Hardware Timers
Many Arduino libraries require a hardware timer. Traditional Arduino products have 3 or 4 timers, with
only 1 or 2 providing more than 8 bit resolution. Teensy‐LC has a total of 7 timers, all of them with 16
or more bits of resolution, to allow excellent compatibility with easy‐to‐use libraries. Many
combinations of popular libraries, which would normally conflict, can seamlessly run together on
Teensy LC and Teensy 3.1.
Analog Input & Output at 12 Bit Resolution
Analog signals are critically important to many projects. Teensy‐LC has 13 pins than can function as
analog inputs. The effective analog resolution is 12 bits. It also has a true 12 bit digital to analog
converter, for an analog output signal.
32 bit ARM Cortex M0+ Processor
The Cortex‐M0+ processor is a powerful, full 32 bit CPU, designed for lower power, lower cost devices.
Cortex‐M0+ has fewer instructions and a simpler bus structure than the more powerful Cortex‐M4 on
Teensy 3.1. For simple code, M0+ often runs at similar speed, when running at the same clock
frequency. For math‐intensive applications, Cortex‐M4 can be significantly faster, and of course it
supports higher clock rates. Cortex‐M0+ at 48 MHz is much faster than 8 bit AVR processors at 16 MHz,
especially when manipulating 16 and 32 bit variables!
5 Volt Buffer For WS2812/NeoPixel LED Projects
Teensy‐LC provides a 5V output to directly drive WS2812/NeoPixel LEDs. A 74LV1T125 buffer is
connected to pin 17, with the increased output voltage available on another pin.
Check out the Teensy‐LC forum for more information and for any further questions!
Technical Details
o
o
o
o
o
o
o
o
o
o
o
o
Dimensions: 18mm x 37mm x 4mm / 0.7" x 1.5" x 0.2"
Weight: 2.6g
Processor: MKL26Z64VFT4
Core: Coretx‐M0+
Rated Speed: 48 MHz
Flash Memory: 62 KB
Bandwidth: 96 MB/sec
Cache: 64 bytes
RAM: 8 KB
EEPROM: 1/8 (emu) KB
Direct Memory Access: 4 channels
Digital I/O: 27 Pins
Voltage Output: 3.3V + one 5V
Current Output: 5mA + four 20mA
Voltage Input: 3.3V
Analog Input: 13 pins
Converters: 1
Resolution: 16 bits
Usable: 12 bits
Prog Gain Amp: 0
Touch Sensing: 11 pins
Analog Output: 1 pins
DAC Resolution: 12 bits
Timers: 7 total
FTM Type: 3
PWM Outputs: 10 pins
PDB Type: 0
CMT (infrared) Type: 0
LPTMR Type: 1
PIT (interval) Type: 2
Systick: 1
RTC (date/time): 0
Communication
USB: 1
Serial: 3
With FIFOs: 0
High Res Baud: 0
Fast Clock: 1
SPI: 2
With FIFOs: 1
I2C: 2
CAN Bus: 0
I2S Audio: 1
FIFO Size: 4
https://www.adafruit.com/product/2419 7‐25‐17
很抱歉,暂时无法提供与“2419”相匹配的价格&库存,您可以联系我们找货
