SY6281
Low Loss Power Distribution Switch
TARGET DESIGN SPECIFICATION
Preliminary Spec
General Description
Features
The SY6281 develops ultra-low Rds(on) switch with
programmable current limiting to protect the power
source from over current and short circuit conditions. It
integrates the over temperature protection and
discharges the output capacitor during the shutdown. In
case the output is pulled higher than the input voltage
under the shutdown, the SY6281 can block the current
flowing from the output to the input.
Distribution voltages: 2.4V to 5.5V
Programmable current limit
Enable polarity: active low
Over temperature shutdown and automatic retry
Reverse blocking (no body diode)
At shutdown, OUT can be forced higher than IN
Automatic output discharge at shutdown
Compact SOT23 packages minimize the board
space.
Ordering Information
SY6281 □(□□)□
Temperature Code
Package Code
Optional Spec Code
Temperature Range: -40°C to 85°C
Ordering Number
Package type
SY6281AAC
SOT23-5
Applications
Note
• USB 3G Datacard
• USB Dongle
• MiniPCI Accessories
Typical Applications
Figure 1. Schematic Diagram
SY6281 Rev. 0.1
Silergy Corp. Confidential- Prepared for Customer Use Only
1
SY6281
Pinout (top view)
(SOT23-5)
Top mark: FHxyz (Device code: FH, x=year code, y=week code, z= lot number code)
Pin Name
IN
GND
OUT
ENB
ISET
Pin number
5
2
1
4
3
Pin Description
Input pin
Ground pin
Output pin
ON/OFF control. Pull low to enable IC. Do not float.
Current limit programming pin. Connect a resistor Rset from this pin
to GND to program the current limit: Ilim (A)=6800/Rset (ohm)
Absolute Maximum Ratings (Note 1)
All pins-------------------------- ---------------------------------------------------------------------------------- 6V
Power Dissipation, PD @ TA = 25°C SOT23-5, -------------------------------------------------------------- 0.6W
Package Thermal Resistance (Note 2)
θ JA ------------------------------------------------------------------------------------------------------- 200°C/W
θ JC ------------------------------------------------------------------------------------------------------- 130°C/W
Junction Temperature Range ------------------------------------------------------------------------------------ 150°C
Lead Temperature (Soldering, 10 sec.) ------------------------------------------------------------------------ 260°C
Storage Temperature Range ------------------------------------------------------------------------------------- -65°C to 150°C
Recommended Operating Conditions (Note 3)
IN--------------------------------------------------------------------------------------------------------------------- 2.4V to 5.5V
All other pins ------------------------------------------------------------------------------------------------------- 0-5.5V
Junction Temperature Range ------------------------------------------------------------------------------------ -40°C to 125°C
Ambient Temperature Range ------------------------------------------------------------------------------------ -40°C to 85°C
SY6281 Rev. 0.1
2
SY6281
Electrical Characteristics
(VIN = 5V, CL=1uF, per channel, TA = 25°C unless otherwise specified)
Parameter
Input Voltage Range
Shutdown Input Current
Quiescent Supply Current
FET RON
ENB Rising Threshold
ENB Falling Threshold
ENB Leakage
IN UVLO Threshold
IN UVLO Hysteresis
Over Current Limit
Turn-ON Time
Turn-OFF Time
OUT Shutdown Discharge Resistance
Thermal Shutdown Temperature
Thermal Shutdown Hysteresis
Symbol
VIN
ISHDN
IQ
RDS(ON)1
VENB(H)
VENB(L)
IENB
VIN,UVLO
VIN,HYS
ILIM
ILIM(min)
ILIM(max)
TON
TOFF
RDIS
TSD
Test Conditions
Min
2.4
Open load, IC Disabled.
Open load, IC Enabled.
Typ
0.1
25
80
Max
5.5
1
2
0.8
1
2.3
VENB=5.5V
RSET=6.8kΩ
RL=10Ω
RL=10Ω, CL=1uF
0.75
0.1
1
0.4
2
120
10
150
130
Unit
V
µA
µA
mΩ
V
V
µA
V
V
A
A
A
us
us
Ω
Note 1: Stresses listed as the above “Absolute Maximum Ratings” may cause permanent damage to the device.
These are for stress ratings. Functional operation of the device at these or any other conditions beyond those
indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating
conditions for extended periods may remain possibility to affect device reliability.
Note 2: θ JA is measured in the natural convection at TA = 25°C on a low effective single layer thermal
conductivity test board of JEDEC 51-3 thermal measurement standard. Pin 2 of SOT23-5 packages is the case
position for θ JC measurement.
Note 3: The device is not guaranteed to function outside its operating conditions
SY6281 Rev. 0.1
3
SY6281
SOT23-5 Package outline & PCB layout design
0.55
1.50 - 1.70
0.80
2.70 - 3.00
2.40
2.80 - 3.10
0.95 TYP
0.30 - 0.50
0.01 - 0.1
0.1 - 0.15
0.25 REF
Recommended Pad Layout
1.0 - 1.3
0.95 TYP
0.3 - 0.6
1.90 TYP
Notes: All dimensions are in millimeters.
All dimensions don’t include mold flash & metal burr.
SY6281 Rev. 0.1
4
很抱歉,暂时无法提供与“SY6281AAC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.09500
- 10+1.05600
- 100+0.96240
- 500+0.91560
- 国内价格
- 1+1.24300
- 1000+1.24300
- 3000+1.24300
