ASNT5117-KMC
ASNT5117-KMC
    ADSANTEC(先进科技)
    CQFlatpack-24
    40G DIFF. D FLIP-FLOP, AMP. CTRL
ASNT5117-KMC 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT5117-KMC DC-40 Gbps D-Type Flip-Flop with Amplitude Adjust  High speed broadband D-Type Flip-Flop for data retiming with full rate clock  Input data common mode control  Exhibits low jitter and limited temperature variation over industrial temperature range  4ps set-up/hold time capability  88% clock phase margin for retiming of data input eye  Fully differential CML input interfaces  Fully differential CML output interface with adjustable 0 to 900mV single-ended swing  Single +3.3V or -3.3V power supply  Power consumption: 726mW  Fabricated in SiGe for high performance, yield, and reliability  Custom CQFP 24-pin package Rev. 1.3.2 1 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION ampadj vcc vcc dccd 50 50 dp DFF core dn outp outn 50 50 vcc 50 50 vcc vcc vcc cp cn Fig. 1. Functional Block Diagram The temperature stable ASNT5117-KMC SiGe IC provides broadband data retiming functionality and is intended for use in high-speed measurement / test equipment. The IC shown in Fig. 1 can sample a highspeed data signal dp/dn with a full-rate external clock cp/cn to create a full-rate retimed NRZ data output qp/qn. The internal DC common mode voltage levels on data inputs dp/dn can be adjusted by applying analog voltage to the control input dccd. The output amplitude of the DFF is adjustable by using the control voltage ampadj. The part’s I/O’s support the CML logic interface with on chip equivalent 50Ohm termination and may be used differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY CONFIGURATION). HS Clock Input Buffer The buffer can accept high-speed signals at its differential CML input port cp/cn. It can also accept a single-ended signal with a threshold voltage applied to the unused pin. It can handle a wide range of input signal amplitudes. The buffer utilizes on-chip single-ended 50Ohm termination to vcc for each input line. HS Data Input Buffer The buffer can accept high-speed signals at its differential CML input port dp/dn. It can also accept a single-ended signal with a threshold voltage applied to the unused pin. It can handle a wide range of input signal amplitudes. The buffer utilizes on-chip single-ended 50Ohm termination to vcc for each input line. The buffer allows for adjustment of its input DC common-mode voltage by changing the control voltage dccd following the diagram shown in Fig. 2. Here the x-axis presents the dccd values, the y-axis presents the common-mode voltage values, the red lines correspond to the dp input, the blue lines correspond to Rev. 1.3.2 2 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com the dn input, and the solid lines represent typical conditions while dotted and dashed lines represent slow and fast conditions respectively. Fig. 2. Duty Cycle Control Diagram HS Data Output Buffer The buffer receives high-speed serial data from the DFF core and converts it into a differential CML output signal qp/qn. Each buffer utilizes internal single-ended 50Ohm loads to vcc and requires singleended 50Ohm external termination. The termination resistors can be connected from each output directly to vcc, or through DC blocks to vee. The amplitude of the output signals can be adjusted from 0V to its maximum value using the external control voltage ampadj. POWER SUPPLY CONFIGURATION The part can operate with either a negative supply (vcc = 0.0V = ground and vee = −3.3V), or a positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of a positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V. ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 1 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vcc). Rev. 1.3.2 3 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Parameter Min Max Supply Voltage (vee) -3.6 Power Consumption 0.80 Input Data Voltage Swing (SE) 1.0 Input Clk Voltage Swing (SE) 1.0 Case Temperature +90 Storage Temperature -40 +100 Operational Humidity 10 98 Storage Humidity 10 98 Table 1. Absolute Maximum Ratings Units V W V V ºC ºC % % TERMINAL FUNCTIONS TERMINAL Name No. Type dp dn cp cn qp qn 21 23 3 5 11 9 ampadj dccd Name vcc vee Rev. 1.3.2 Pin Default function state High-Speed I/Os Input data CML Input CML Input clock Input CML Output data. Output Termination SE 50Ohm to vcc SE 50Ohm to vcc SE 50Ohm to vcc. Require external SE 50Ohm to vcc DC Controls 15 Analog Output data amplitude 2.3KOhm to vcc, 9.3KOhm voltage control to vee 17 Input data common 5.6KOhm to vcc, 22.2KOhm mode voltage control to vee Supply and Termination Voltages Description Pin Number Positive power supply 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24 (+3.3V or 0V) Negative power supply 1, 7, 13, 19 (0V or -3.3V) 4 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER vcc vee Ivcc Power consumption Junction temperature Data rate Swing CM Voltage Level Frequency Swing CM Voltage Level Duty Cycle Clock phase margin Data rate Logic “1” level Logic “0” level Jitter Max level Min level MIN TYP MAX UNIT COMMENTS General Parameters 0.0 V External ground -3.1 -3.3 -3.5 V ±6% 220 233 mA 726 770 mW -25 50 125 °C HS Input Data (dp/dn) DC 32 40 Gbps 0.05 0.8 V Differential or SE, p-p vcc-0.7+sw/2 vcc+0.6-sw/2 V Must match for both inputs HS Input Clock (cp/cn) DC 32 40 GHz 0.05 0.8 V Differential or SE, p-p vcc-0.7 vcc+0.6-sw/2 V Must match for both inputs 40 50 60 % 86 88 90 % For reliable data latching HS Output Data (qp/qn) DC 32 40 Gbps vcc-0.05 vcc-0.03 vcc-0.01 V Equal to logic “1” V With ampadj set at minimum vcc-0.42 vcc-0.40 vcc-0.38 V With ampadj set at default vcc-0.90 vcc-0.80 vcc-0.78 V With ampadj set at maximum 1.5 ps Peak-to-peak at 32Gbps DC Input Controls (dccd, ampadj) V vcc vcc - 1.3 V PACKAGE INFORMATION The chip die is housed in a custom 24-pin CQFP package shown in Fig. 3. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. The part’s identification label is ASNT5117-KMC. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. Rev. 1.3.2 5 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 3. CQFP 24-Pin Package Drawing (All Dimensions in mm) Rev. 1.3.2 6 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision 1.3.2 1.2.2 1.2.1 Date 02-2020 07-2019 10-2015 1.1.1 04-2015 1.0.1 04-2015 Rev. 1.3.2 Changes Updated Package Information Updated Letterhead Corrected electrical characteristics section Updated package information section Updated maximum frequency of operation Updated maximum output amplitude First release 7 February 2020
ASNT5117-KMC 价格&库存
很抱歉,暂时无法提供与“ASNT5117-KMC”相匹配的价格&库存,您可以联系我们找货
