IS31BL3230-QFLS2-TR
IS31BL3230-QFLS2-TR
    LUMISSIL
    WFQFN16
    IC LED DRIVER 8CH CC 90MA 16QFN
IS31BL3230-QFLS2-TR 数据手册
IS31BL3230 8 CHANNELS CONSTANT CURRENT LED DRIVER WITH PWM BRIGHTNESS CONTROL March 2015 GENERAL DESCRIPTION FEATURES The IS31BL3230 provides eight regulated current sources, each delivers up to 90mA of load current with careful selection of external sense resistors, all outputs at the IS31BL3230 may be connected in parallel to enable the current through the LED to be as high as 720mA.         The IS31BL3230 does not include a charge pump and therefore has no noise and significantly improved the efficiency. The external resistor, RSET1, determines the constant current output of ports LED1 thru LED4, while resistor RSET2 determines the constant current output of ports LED5 thru LED8. Brightness can be controlled with PWM techniques. The constant current source is set with two external sense resistors. Ultra low headroom voltage Total output current can be 720mA Cost effective LED driver Current adjustable via external resistors Best noise and efficiency performance Highly integrated design, minimal component 1.6μA (Typ.) shutdown current Small package QFN-16 (3mm×3mm) APPLICATIONS   Flash LED driver Backlight LED driver Alternatively, a PWM signal applied to the PWM pin can vary the perceived brightness of the LED. The device is in shut down mode when the PWM Input is logic low. TYPICAL APPLICATION CIRCUIT Figure 1 Typical Application Circuit for Flash LED Driving Lumissil Microsystems – www.lumissil.com Rev. B, 02/09/2015 1 IS31BL3230 Figure 2 Lumissil Microsystems – www.lumissil.com Rev. B, 02/09/2015 Typical Application Circuit for 8 LEDs Driving 2 IS31BL3230 PIN CONFIGURATION 16 LED3 15 LED4 14 LED5 13 LED6 ISET1 6 VCC 7 PWM 8 Pin Configurations (Top View) 5 Package PWM QFN-16 PIN DESCRIPTION No. Name Description 1 LED2 Current source outputs 2. 2 LED1 Current source outputs 1. 3, 7 VCC Input voltage. 4, 10 GND Ground. 5, 8 PWM PWM brightness control. 6 ISET1 Current set 1 input. 9 ISET2 Current set 2 input. 11~16 LED8~LED3 Current source outputs 8~3. Thermal Pad Connect to GND. Lumissil Microsystems – www.lumissil.com Rev. B, 02/09/2015 3 IS31BL3230 ORDERING INFORMATION Industrial Range: -40°C to +85°C Order Part No. Package QTY/Reel IS31BL3230-QFLS2-TR QFN-16, Lead-free 2500 Copyright  ©  2015  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use  in such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. B, 02/09/2015 4 IS31BL3230 ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC PWM Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA ESD (HBM) ESD (CDM) -0.3V ~ +6.0V -0.3V ~ VCC+0.3V +150°C -65°C ~ +150°C -40°C ~ +85°C ±3kV ±1kV Note: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS Unless otherwise specified or noted, VCC = 3.6V, RSET=7.5kΩ, VLEDX=0.5V. Limits apply for TA=25°C. (Note 1) Symbol Parameter Condition Min Typ. Units 5.5 V VCC Supply voltage ILEDX Output current regulation VLEDX =0.4V~2.0V, RSET = 7.5kΩ 16 mA VHR Minimum headroom voltage (LEDX) RSET= 7.5kΩ, ILEDX=20mA 44 mV VSET ISET pin voltage 1.2 V ILEDX/ISET Output current to current set ratio 100 mA/mA ICC Quiescent supply current ILEDX = 0mA, ISET= Float 244 μA IPWM Shutdown supply current VPWM=0V 1.6 μA VPWM_H PWM input logic high VCC = 3.0V~5.5V VPWM_L PWM input logic low VCC = 3.0V~5.5V PWM pin current VPWM = 1.5V IPWM 2.7 Max 1.4 V 0.4 5.6 V μA Note 1: Production testing of the device is performed at 25°C. Functional operation of the device and parameters specified over other temperature range, are guaranteed by design, characterization and process control. Lumissil Microsystems – www.lumissil.com Rev. B, 02/09/2015 5 IS31BL3230 FUNCTIONAL BLOCK DIAGRAM Lumissil Microsystems – www.lumissil.com Rev. B, 02/09/2015 6 IS31BL3230 TYPICAL PERFORMANCE CHARACTERISTICS 45 RSET = 3.0kΩ IN = 3.3V VVCC =3.3V 40 RSET = 4.0kΩ 30 25 RSET = 6.0kΩ 20 RSET=6.0k LED Current (mA) LED Current(mA) 35 RSET = 7.5kΩ 15 RSET=7.5k RSET=12.0k RSET = 12.0kΩ 10 V =3.3V VCCIN=3.3V VLEDX=0.2V 5 0 0 50 100 150 200 Output Voltage(VLEDX)(mV) Figure 3 Power Supply(V) Output Voltage vs. LED Current Figure 4 290 45 RSET = 7.5kΩ IN = 3.3V VVCC =3.3V 40 280 35 270 LED Current(mA) Quiescent Current(µA) Power Supply vs. LED Current 260 250 240 30 25 20 15 10 230 220 5 3 3.5 4 4.5 5 0 3 8 Power Supply(V) Figure 5 Power Supply vs. Quiescent Current Lumissil Microsystems – www.lumissil.com Rev. B, 02/09/2015 13 18 23 28 30 RSET(kΩ) Figure 6 RSET vs. LED Current 7 IS31BL3230 APPLICATION INFORMATION CIRCUIT DESCRIPTION PWM BRIGHTNESS CONTROL The IS31BL3230 is a white-LED driver with eight matched current outputs. The matched current regulators each has a 100:1 current ratio between the LEDX outputs and the ISET currents. The mirror controls the current through the LEDs without the use of external ballast resistors. With a total of 720mA of total output current available, the IS31BL3230 is capable of providing 90mA to each of the eight outputs through the proper selection of the RSET1 & RSET2 resistor. LED brightness control can be achieved on the IS31BL3230 with PWM signal. Brightness control can be implemented by pulsing a signal at the PWM pin. SHUTDOWN When the voltage on the active-high-logic PWM pin is low, the IS31BL3230 will be in shutdown mode. While disabled, the IS31BL3230 typically draws 1.6μA form the power supply. There is no internal pull-up or pull-down on the PWM pin of the IS31BL3230. OUTPUT CURRENT CAPABILITY The IS31BL3230 can provide up to 40mA of current to each of the eight outputs given an input voltage of 2.7V to 5.5V. An external resistor can be used to set the output current, as approximated with the following the equation: RSET1, 2=100 × (VISET1, 2 / ILEDX) RSET1 determines the constant current output of ports LED1 thru LED4, RSET2 determines the constant current output of ports LED5 thru LED8, VISET is the voltage of RSET resistance, it is 1.20V typically. In order for the output currents to be regulated properly, sufficient headroom voltage (VHR) is required. The headroom voltage refers to the minimum amount of voltage that must be present across the current source in order to ensure the desired current is realizable. To ensure the desired current is obtained, using the following equations to find the minimum input voltage required: VCC - VLEDX ≥ VHR VLEDX is the diode forward voltage; VHR is typically as shown in table1. Table 1 ILED, RSET and VHR-MIN, VCC=3.6V ILED RSET VHEADROOM 10.0mA 16.0mA 20.0mA 30.0mA 40.0mA 43.8mA 62.5mA 87.5mA 12.0kΩ 7.5kΩ 6.0kΩ 4.0kΩ 3.0kΩ 2.7kΩ 2kΩ 1.4kΩ 27mV(typ.) 44mV(typ.) 53mV(typ.) 66mV(typ.) 75mV(typ.) 100mV(typ.) 150mV(typ.) 210mV(typ.) Lumissil Microsystems – www.lumissil.com Rev. B, 02/09/2015 The RSET value should be selected using the RSET equation. The LED brightness is proportional to the duty cycle (D) of the PWM signal. The PWM frequency (f) should be limited to accommodate the turn-on time (tON=50μs) of the device. D × (1/f) > tON fMAX = DMIN / tON If the PWM frequency is much less than 100Hz, flicker may be seen in the LEDs. For the IS31BL3230, zero duty cycle will turn off the LEDs and a 50% duty cycle will result in an average ILED being half of the programmed LED current. For example, if RSET is set to program 16mA, a 50% duty cycle will result in an average ILED of 8mA, ILED being half the programmed LED current. RSET should be chosen not to exceed the maximum current delivery capability of the device. LED SELECTION The IS31BL3230 has ultra low headroom voltage and it is designed to drive white-LEDs with a typical forward voltage up to 3.5V. As the voltage drop below the recommend VHR, the drive current will automatically scale down to reduce the LED current consumption. POWER DISSIPATION The maximum allowable power dissipation that this package can handle is determined by the following: PDMAX = (TJMAX - TA)/θJA Where TJMAX is the maximum junction temperature, TA is the ambient temperature and θJA is the junction-to-ambient thermal resistance of the specified package. The IS31BL3230 come in the QFN-16 3mm×3mm package, and it has a junction-to-ambient thermal resistance (θJA) equal to 34.5°C/W. This value of θJA is highly dependant upon the layout of the PC board. The actual power dissipated by the IS31BL3230 follows the equation: PDISS = (VCC ×ICC) - N(VLEDX × ILEDX) Where N equals the number of active outputs, VLEDX is the LED forward voltage, and ILEDX is the current supplied to the LED. INPUT CAPACITOR SELECTION The IS31BL3230 is designed to run off of a fixed input voltage. Depending on the stability and condition of this voltage rail, it may be necessary to add some small input capacitors to help filter out any noise that may be present on the line. In the event that filtering is 8 IS31BL3230 needed, surface-mount multi-layer ceramic capacitors are recommended. These capacitors are small and inexpensive. Two capacitances, a 0.1μF and a 1μF are typically sufficient. Lumissil Microsystems – www.lumissil.com Rev. B, 02/09/2015 9 IS31BL3230 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 7 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. B, 02/09/2015 10 IS31BL3230 PACKAGE INFORMATION QFN-16 Note: All dimensions in millimeters unless otherwise stated. Lumissil Microsystems – www.lumissil.com Rev. B, 02/09/2015 11 IS31BL3230 LAND PATTERN Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. Lumissil Microsystems – www.lumissil.com Rev. B, 02/09/2015 12
IS31BL3230-QFLS2-TR 价格&库存
很抱歉,暂时无法提供与“IS31BL3230-QFLS2-TR”相匹配的价格&库存,您可以联系我们找货
