UM1750S-00
UM1750S-00
    UNION(英联)
    SOT23-5
    5V Input 350mA LDO
UM1750S-00 数据手册
UM1650 UM1750 350mA, Micropower, Very Low Dropout Linear Regulator UM1650S-xx SOT23-3 UM1750S-xx SOT23-5 UM1750Y-xx SOT89-5 UM1750DA-xx DFN6 2.0×2.0 General Description The UM1650/UM1750 series are very low dropout linear regulators designed for low power portable applications. Typical output noise is only 195μVRMS and maximum dropout is just 110mV(Typ) at the load current of 150mA.The internal P-channel MOSFET pass transistor requires no base current, allowing the device to draw only 190μA during normal operation at the maximum load current of 350mA.With a shutdown control pin, the UM1750 consumes less than 1μA current in shutdown mode. Other features include high output voltage accuracy, excellent transient response, under voltage lockout, stability with ultralow ESR ceramic capacitors as small as 1μF, short-circuit and thermal overload protection and output current limiting. The UM1650 series are available in a low profile SOT23-3 package. The UM1750 series are available in low profile SOT23-5, SOT89-5 and DFN6 2.0×2.0 packages. Applications Features z z z z z z z Bluetooth/802.11 Cards PDAs and Notebook Computers Portable Instruments and Battery-Powered Systems Cellular Phones z z z z z z z z Very Low Dropout: 150mV (Max) at 150mA Maximum Input Voltage: 6.0V ±2% Voltage Accuracy at VOUT>1.5V ±30mV Voltage Accuracy at VOUT≤1.5V Fast Transient Response Under Voltage Lockout Fixed Output Voltage of UM1650S-xx and UM1750S/Y/DA-xx from 1.0V to 4.0V with 0.1V Interval Adjustable Output Voltage of UM1750S/Y/DA-00 from 1.0V to 5.0V Output Current Limit Stable with 1μF Output Capacitor Short-Circuit and Thermal Overload Protection Low Profile SOT23-3, SOT23-5, SOT89-5 and DFN6 2.0×2.0 Packages ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 1/18 UM1650 UM1750 Pin Configurations Top View 3 GND 1 6XX 3 IN Marking Pin 1 OUT 2 1 2 M M: Month Code UM1650S-xx SOT23-3 M M: Month Code UM1750S-xx SOT23-5 M: Month Code UM1750S-00 SOT23-5 XX: Week Code UM1750Y-xx SOT89-5 ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 2/18 UM1650 UM1750 Pin Configurations (Continued) Top View XX: Week Code UM1750Y-00 SOT89-5 (Top View) M: Month Code UM1750DA-xx DFN6 2.0×2.0 (Top View) M: Month Code UM1750DA-00 DFN6 2.0×2.0 * The tab on the bottom of the package enhances thermal performance and is electrically connected to GND (substrate level). It is recommended that the tab be connected to the ground plane on the board. If not, the tab can be left open. Pin Description UM1650S-xx 3 1 Pin Number UM1750S-xx UM1750S-00 (Fixed VOUT) (Adjustable VOUT) 1 1 2 2 Symbol IN GND ___________ - 3 3 SHDN 2 - 4 5 - 5 4 NC OUT FB Function Power Supply Ground Shutdown Input: High=Activate LDO, Low=Shutdown LDO Not Connected Voltage Regulated Output Output Voltage Feedback ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 3/18 UM1650 UM1750 Pin Description (Continued) Pin Number UM1750Y-00 UM1750DA-00 Symbol Function UM1750DA-xx UM1750Y-xx (Adjustable (Adjustable (Fixed VOUT) (Fixed VOUT) VOUT) VOUT) 4 4 3 3 IN Power Supply 2 2 2 2 GND Ground Shutdown Input: High=Activate ___________ 3 3 1 1 SHDN LDO, Low=Shutdown LDO 1 5,6 5 NC Not Connected Voltage 5 5 4 4 OUT Regulated Output Output Voltage 1 6 FB Feedback Naming Information ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 4/18 UM1650 UM1750 Ordering Information Part Number UM1650S-10 UM1650S-11 UM1650S-12 UM1650S-13 UM1650S-14 UM1650S-15 UM1650S-16 UM1650S-17 UM1650S-18 UM1650S-19 UM1650S-20 UM1650S-21 UM1650S-22 UM1650S-23 UM1650S-24 UM1650S-25 UM1650S-26 UM1650S-27 UM1650S-28 UM1650S-29 UM1650S-30 UM1650S-31 UM1650S-32 UM1650S-33 UM1650S-34 UM1650S-35 UM1650S-36 UM1650S-37 UM1650S-38 UM1650S-39 UM1650S-40 Output Voltage 1.0V 1.1V 1.2V 1.3V 1.4V 1.5V 1.6V 1.7V 1.8V 1.9V 2.0V 2.1V 2.2V 2.3V 2.4V 2.5V 2.6V 2.7V 2.8V 2.9V 3.0V 3.1V 3.2V 3.3V 3.4V 3.5V 3.6V 3.7V 3.8V 3.9V 4.0V Packaging Type SOT23-3 Marking Code 6AA 6AB 6A2 6A3 6A4 6A5 6A6 6A7 6A8 6A9 6BA 6BB 6B2 6B3 6B4 6B5 6B6 6B7 6B8 6B9 6CA 6CB 6C2 6C3 6C4 6C5 6C6 6C7 6C8 6C9 6CC Shipping Qty 3000pcs/7Inch Tape & Reel ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 5/18 UM1650 UM1750 Ordering Information (Continued) Part Number UM1750S-00 UM1750S-10 UM1750S-11 UM1750S-12 UM1750S-13 UM1750S-14 UM1750S-15 UM1750S-16 UM1750S-17 UM1750S-18 UM1750S-19 UM1750S-20 UM1750S-21 UM1750S-22 UM1750S-23 UM1750S-24 UM1750S-25 UM1750S-26 UM1750S-27 UM1750S-28 UM1750S-29 UM1750S-30 UM1750S-31 UM1750S-32 UM1750S-33 UM1750S-34 UM1750S-35 UM1750S-36 UM1750S-37 UM1750S-38 UM1750S-39 UM1750S-40 Output Voltage ADJ 1.0V 1.1V 1.2V 1.3V 1.4V 1.5V 1.6V 1.7V 1.8V 1.9V 2.0V 2.1V 2.2V 2.3V 2.4V 2.5V 2.6V 2.7V 2.8V 2.9V 3.0V 3.1V 3.2V 3.3V 3.4V 3.5V 3.6V 3.7V 3.8V 3.9V 4.0V Packaging Type SOT23-5 Marking Code 5CT 5JA 5JB 5J2 5J3 5J4 5J5 5J6 5J7 5J8 5J9 5NA 5NB 5N2 5N3 5N4 5N5 5N6 5N7 5N8 5N9 5PA 5PB 5HP 5CU 5P4 5P5 5P6 5P7 5P8 5P9 5PC Shipping Qty 3000pcs/7Inch Tape & Reel ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 6/18 UM1650 UM1750 Ordering Information (Continued) Part Number UM1750Y-00 UM1750Y-10 UM1750Y-11 UM1750Y-12 UM1750Y-13 UM1750Y-14 UM1750Y-15 UM1750Y-16 UM1750Y-17 UM1750Y-18 UM1750Y-19 UM1750Y-20 UM1750Y-21 UM1750Y-22 UM1750Y-23 UM1750Y-24 UM1750Y-25 UM1750Y-26 UM1750Y-27 UM1750Y-28 UM1750Y-29 UM1750Y-30 UM1750Y-31 UM1750Y-32 UM1750Y-33 UM1750Y-34 UM1750Y-35 UM1750Y-36 UM1750Y-37 UM1750Y-38 UM1750Y-39 UM1750Y-40 Output Voltage ADJ 1.0V 1.1V 1.2V 1.3V 1.4V 1.5V 1.6V 1.7V 1.8V 1.9V 2.0V 2.1V 2.2V 2.3V 2.4V 2.5V 2.6V 2.7V 2.8V 2.9V 3.0V 3.1V 3.2V 3.3V 3.4V 3.5V 3.6V 3.7V 3.8V 3.9V 4.0V Packaging Type SOT89-5 Marking Code 1750-00 1750-10 1750-11 1750-12 1750-13 1750-14 1750-15 1750-16 1750-17 1750-18 1750-19 1750-20 1750-21 1750-22 1750-23 1750-24 1750-25 1750-26 1750-27 1750-28 1750-29 1750-30 1750-31 1750-32 1750-33 1750-34 1750-35 1750-36 1750-37 1750-38 1750-39 1750-40 Shipping Qty 1000pcs/7Inch Tape & Reel ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 7/18 UM1650 UM1750 Ordering Information (Continued) Part Number UM1750DA-00 UM1750DA-10 UM1750DA-11 UM1750DA-12 UM1750DA-13 UM1750DA-14 UM1750DA-15 UM1750DA-16 UM1750DA-17 UM1750DA-18 UM1750DA-19 UM1750DA-20 UM1750DA-21 UM1750DA-22 UM1750DA-23 UM1750DA-24 UM1750DA-25 UM1750DA-26 UM1750DA-27 UM1750DA-28 UM1750DA-29 UM1750DA-30 UM1750DA-31 UM1750DA-32 UM1750DA-33 UM1750DA-34 UM1750DA-35 UM1750DA-36 UM1750DA-37 UM1750DA-38 UM1750DA-39 UM1750DA-40 Output Voltage ADJ 1.0V 1.1V 1.2V 1.3V 1.4V 1.5V 1.6V 1.7V 1.8V 1.9V 2.0V 2.1V 2.2V 2.3V 2.4V 2.5V 2.6V 2.7V 2.8V 2.9V 3.0V 3.1V 3.2V 3.3V 3.4V 3.5V 3.6V 3.7V 3.8V 3.9V 4.0V Packaging Type DFN6 2.0×2.0 Marking Code BFJ BFE BFF BH2 BH3 BH4 BH5 BH6 BH7 BH8 BH9 BHA BHB BJ2 BJ3 BJ4 BJ5 BJ6 BJ7 BJ8 BJ9 BJA BJB BK2 BK3 BK4 BK5 BK6 BK7 BK8 BK9 BKA Shipping Qty 3000pcs/7Inch Tape & Reel ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 8/18 UM1650 UM1750 Absolute Maximum Ratings (Note 1) Symbol VIN Parameter Supply Voltage on IN Pin ___________ Value Unit -0.3 to +7.5 V VSHDN VFB Voltage on SHDN Pin Voltage on FB Pin -0.3 to +7.5 V -0.3 to +7.5 V VOUT Voltage on OUT Pin -0.3 to +7.5 V ___________ Output Short-Circuit Duration θJA Indefinite SOT23-3 +225 Junction Thermal Resistance SOT23-5 (Note 2) SOT89-5 +215 DFN6 2.0×2.0 TJ TSTG TL +66 °C/W +110 Operating Junction Temperature (Note 3, 4) -40 to +125 °C Storage Temperature Range -65 to +150 °C +300 °C Lead Temperature for Soldering 10 Seconds Note 1: Absolute Maximum Ratings are those values beyond which the life of a device may be impaired. Note 2: The maximum allowable power dissipation of any TA (ambient temperature) is PD(max)= (TJ(max)–TA)/θJA. Exceeding the maximum allowable power dissipation will result in excessive die temperature, and the regulator will go into thermal shutdown. Note 3: The UM1650/UM1750 is tested and specified under pulse load conditions such that TJ≈TA. Specifications over the -40°C to 125°C operating junction temperature range are assured by design, characterization and correlation with statistical process controls. Note 4: This IC includes overtemperature protection that is intended to protect the device during momentary overload conditions. Junction temperature will exceed 125°C when overtemperature protection is active. Continuous operation above the specified maximum operating junction temperature may impair device reliability. ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 9/18 UM1650 UM1750 Electrical Characteristics ____________ VSHDN=VIN=VOUT+1V, CIN=COUT=1.0μF, TA=25°C, unless noted. Symbol VIN VUVLO IQ ___________ ISHDN IOUT VFB Parameter Input Voltage Range Input Under Voltage Lockout Test Conditions Min 2.5 VIN Falling 1.8 Operating Quiescent Current VIN=4.3V, IOUT=0mA 90 130 VIN=4.3V, IOUT=350mA 190 300 Shutdown Leakage Current Output Current Feedback Reference Voltage Output Voltage Accuracy VIN=2.5V to 6.0V 0mA≤IOUT≤350mA VIH SHDN Input High Voltage ___________ ΔTSHDN SHDN Input Current Thermal-Shutdown Temperature Thermal-Shutdown Hysteresis Line Regulation Load Regulation Output Voltage Noise PSRR Power Supply Ripple Rejection μA mA 1.00 1.02 V % VOUT≤1.5V -30 +30 mV 150 mV VIN≥2.5V SHDN Input Low Voltage 0.98 μA +2 RL=68Ω, COUT=1μF ___________ V -2 Output Current Limit VIL 2.4 VOUT>1.5V Startup Time Response ___________ Unit V 350 t Dropout Voltage Max 6.0 1 ΔVDO (Note 5) ILIMIT TSHDN Typ IOUT=150mA 110 550 mA 44 VIN=6.0V VIN=6.0V ___________ SHDN=VIN or GND VOUT+1V≤VIN≤VOUT+2V, VIN≥2.5V IOUT=10mA VIN=VOUT+1V, VIN≥2.5V 1mA≤IOUT≤150mA 10Hz to 100kHz CIN=1μF, VOUT=3.3V, IOUT=150mA f=100Hz VIN=VOUT+1V f=1kHz IOUT=100mA f=10kHz μs 0.4 2.0 V V -1 +1 μA 160 °C 20 °C 0.09 %/V 0.2 % 195 μVRMS 63 55 dB 40 Note 5: ΔVDO just defined for device with VOUT≥2.5V. ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 10/18 UM1650 UM1750 Typical Application Circuit Figure 1. UM1650S-xx Typical Application Circuit Figure 2. UM1750S-xx/UM1750Y-xx/UM1750DA-xx (Fixed VOUT) Typical Application Circuit Figure 3. UM1750S-00/UM1750Y-00/UM1750DA-00 (Adjustable VOUT) Typical Application Circuit UM1750S-00/UM1750Y-00/UM1750DA-00 Output Voltage Setting The output voltage of the UM1750 adjustable regulator is programmed using an external resistor divider as shown in Figure 3. The output voltage is calculated using: R1 ⎞ ⎛ VOUT = VFB ⎜1 + ⎟ ⎝ R2 ⎠ Where: VFB=1.00V (Typ) (the internal reference voltage) Resistors R1 and R2 should be chosen for approximately 3-5μA divider current. Lower value resistors can be used but offer no inherent advantage and waste more power. Higher values should be avoided, as leakage currents at FB increase the output voltage error. The recommended design procedure is to choose R2=200kΩ to set the divider current at 5μA and then calculate R1 using: ⎞ ⎛V R1 = ⎜⎜ OUT − 1⎟⎟ × R 2 ⎠ ⎝ VFB Where: VFB=1.00V (Typ). ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 11/18 UM1650 UM1750 Typical Performance Characteristics (Shown for 3.3V Output Option) Quiescent Current vs. Input Voltage IOUT=0mA GND Current vs. Output Current VIN=4.3V Output Voltage vs. Output Current VIN=4.3V Quiescent Current vs. Temperature VIN=4.3V, IOUT=0mA Output Voltage vs. Input Voltage IOUT=350mA Output Voltage vs. Temperature VIN=4.3V, IOUT=10mA ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 12/18 UM1650 UM1750 Typical Performance Characteristics (Continued) (Shown for 3.3V Output Option) PSRR vs. Frequency Dropout Voltage vs. Output Current IOUT=10mA IOUT=100mA Load Transient Response Noise UM1750S-33, VIN=4.3V, IOUT=20mA to 200mA UM1750S-33, VIN=4.3V, IOUT=150mA, CIN=COUT=1μF 195μVRMS IOUT 100mA/div 500μV/div VOUT 100mV/div 20ms/div 100μs/div f=10Hz to 100kHz Line Transient Response Startup Waveform UM1750S-33, VIN=4.3V, RL=33Ω UM1750S-33, VIN=4.3V to 5.3V, IOUT=100mA VIN VEN 1V/div 2V/div VOUT VOUT 100mV/div 1V/div 100μs/div 10μs/div ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 13/18 UM1650 UM1750 Package Information UM1650S-xx: SOT23-3 Outline Drawing DIMENSIONS Symbol A A1 A2 b c D E E1 e e1 L θ MILLIMETERS Min Typ Max 1.013 1.15 1.40 0.00 0.05 0.10 1.00 1.10 1.30 0.30 0.50 0.10 0.15 0.20 2.82 3.10 1.50 1.60 1.70 2.60 2.80 3.00 0.95REF 1.90REF 0.30 0.60 0° 8° INCHES Min Typ Max 0.040 0.045 0.055 0.000 0.002 0.004 0.039 0.043 0.051 0.012 0.020 0.004 0.006 0.008 0.111 0.122 0.059 0.063 0.067 0.102 0.110 0.118 0.037REF 0.075REF 0.012 0.024 0° 8° 1.20 2.35 Land Pattern NOTES: 1. Compound dimension: 2.92×1.60; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 14/18 UM1650 UM1750 UM1750S-xx: SOT23-5 Outline Drawing Symbol A A1 A2 b c D E E1 e e1 L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 1.013 1.15 1.40 0.040 0.045 0.055 0.00 0.05 0.10 0.000 0.002 0.004 1.00 1.10 1.30 0.039 0.043 0.051 0.30 0.50 0.012 0.020 0.10 0.15 0.20 0.004 0.006 0.008 2.82 3.10 0.111 0.122 1.50 1.60 1.70 0.059 0.063 0.067 2.60 2.80 3.00 0.102 0.110 0.118 0.95REF 0.037REF 1.90REF 0.075REF 0.30 0.60 0.012 0.024 0° 8° 0° 8° Land Pattern NOTES: 1. Compound dimension: 2.92×1.60; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 15/18 UM1650 UM1750 UM1750Y-xx: SOT89-5 20 0 Outline Drawing L R 0. DIMENSIONS A L E Symbol MILLIMETERS INCHES Min Typ Max Min Typ Max A 1.40 1.50 1.60 0.055 0.059 0.063 b 0.32 - 0.54 0.013 - 0.021 b1 0.38 - 0.62 0.015 - 0.024 c 0.35 - 0.44 0.014 - 0.017 D 4.40 4.50 4.60 0.173 0.177 0.181 D1 1.40 - 1.83 0.055 - 0.072 E 2.30 2.50 2.60 0.091 0.098 0.102 e L 1.50TYP 0.65 - 0.059TYP 1.20 0.026 - 0.047 1.60 1.60 4.55 5.35 3.10 Land Pattern NOTES: 1. Compound dimension: 4.50×2.50; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 16/18 UM1650 UM1750 UM1750DA-xx: DFN6 2.0×2.0 Outline Drawing E2 A 0.55 - 0.80 0.022 - 0.031 A1 0.00 - 0.05 0.000 - 0.002 A3 A1 A A3 E L Symbol DIMENSIONS INCHES MILLIMETERS Typ Max Min Typ Max Min 0.20REF 0.008REF b 0.25 0.30 0.35 0.010 0.012 0.014 D 1.924 2.00 2.076 0.076 0.079 0.082 D2 1.35 - 1.75 0.053 - 0.069 E 1.924 2.00 2.076 0.076 0.079 0.082 E2 0.65 - 1.06 0.026 - 0.042 e L 0.65BSC 0.224 - 0.026BSC 0.45 0.009 - 0.018 Land Pattern 0.20 2.00 0.70 0.45 2.00 2.40 1.65 0.65 0.35 NOTES: 1. Compound dimension: 2.00×2.00; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 17/18 UM1650 UM1750 GREEN COMPLIANCE Union Semiconductor is committed to environmental excellence in all aspects of its operations including meeting or exceeding regulatory requirements with respect to the use of hazardous substances. Numerous successful programs have been implemented to reduce the use of hazardous substances and/or emissions. All Union components are compliant with the RoHS directive, which helps to support customers in their compliance with environmental directives. For more green compliance information, please visit: http://www.union-ic.com/index.aspx?cat_code=RoHSDeclaration IMPORTANT NOTICE The information in this document has been carefully reviewed and is believed to be accurate. Nonetheless, this document is subject to change without notice. Union assumes no responsibility for any inaccuracies that may be contained in this document, and makes no commitment to update or to keep current the contained information, or to notify a person or organization of any update. Union reserves the right to make changes, at any time, in order to improve reliability, function or design and to attempt to supply the best product possible. Union Semiconductor, Inc Add: Unit 606, No.570 Shengxia Road, Shanghai 201210 Tel: 021-51093966 Fax: 021-51026018 Website: www.union-ic.com ________________________________________________________________________ http://www.union-ic.com Rev.04 Sep.2017 18/18
UM1750S-00 价格&库存
很抱歉,暂时无法提供与“UM1750S-00”相匹配的价格&库存,您可以联系我们找货
