KINGSTON.COM
Kingston DDR3/3L DRAM
for embedded applications
Kingston DDR3/3L
Kingston on-board DRAM is designed to meet the needs of embedded applications and offers a
low-voltage option for lower power consumption.
DDR3/3L Part Numbers and Specifications
30nm DDR3/3L
Part Number
Capacity
Description
Package
Size
Configuration
(words x bits)
Speed
VDD,
VDDQ
Operating
Temperature
D1216ECMDXGJD
2Gb
96 ball FBGA
DDR3/3L
I-Temp
7.5x13.5x1.2
128Mx16
1866
Mbps
1.35V
0°C ~ +95°C
D2568ECMDPGJD
2Gb
78 ball FBGA
DDR3/3L
I-Temp
7.5x13.5x1.2
256Mx8
1866
Mbps
1.35V
0°C ~ +95°C
D2516ECMDXGJD
4Gb
96 ball FBGA
DDR3L
7.5x13.5x1.2
256Mx16
1866
Mbps
1.35V*
0°C ~ +95°C
D5128ECMDPGJD
4Gb
78 ball FBGA
DDR3L
7.5x10.6x1.2
512Mx8
1866
Mbps
1.35V*
0°C ~ +95°C
D2516ECMDXGME
4Gb
96 ball FBGA
DDR3L
7.5x13.5x1.2
256Mx16
2133
Mbps
1.35V*
0°C ~ +95°C
*Backward compatible to 1.5V VDD, VDDQ
Key Features
• Double-data-rate architecture: two data transfers per clock cycle
• The high-speed data transfer is realized by the 8 bits prefetch pipelined architecture
• Bi-directional differential data strobe (DOS and /DQS) is transmitted/received with data for
capturing data at the receiver
• DOS is edge-aligned with data for READS; center-aligned with data for WRITES
• Differential clock inputs (CK and /CK)
• DLL aligns DQ and DOS transitions with CK transitions
• Commands entered on each positive CK edge; data and data mask referenced to both
edges of DQS
• Data mask (DM) for write data
• Posted /CAS by programmable additive latency for better command and data bus efficiency
• On-Die Termination (ODD for better signal quality
— Synchronous ODT
— Dynamic CDT
— Asynchronous ODT
• Multi Purpose Register (MPR) for pre-defined pattern read out
• ZQ calibration for DO drive and ODT
• Programmable Partial Array Self-Refresh (PASR)
• RESET pin for Power-up sequence and reset function
• SRT range: Normal/extended
• Programmable Output driver impedance control
THIS DOCUMENT SUBJECT TO CHANGE WITHOUT NOTICE
©2020 Kingston Technology Corporation, 17600 Newhope Street, Fountain Valley, CA 92708 USA.
All rights reserved. All trademarks and registered trademarks are the property of their respective owners. MKF-585.2US
很抱歉,暂时无法提供与“D1216ECMDXGJD-U”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+18.183085+2.20551
- 25+18.0981225+2.19521
- 75+18.0977175+2.19516
- 200+18.09731200+2.19511
- 500+18.09691500+2.19506
