Inductive sensor
NBN40-L2M-A2-V1
Sensor head bidirectional and rotatable
40 mm non-flush
4-wire DC
4-way LED indicator
Dimensions
LED gn
LED ye
7
M12 x 1
28
LED ye
67
LED gn
40
40
Release date: 2020-03-21 Date of issue: 2020-03-30 Filename: 132362_eng.pdf
8
ø 5.5
46
60
Technical Data
General specifications
Switching function
complementary
Output type
Rated operating distance
PNP
sn
Installation
40 mm
non-flush
Output polarity
DC
Assured operating distance
sa
0 ... 32.4 mm
Actual operating distance
sr
36 ... 44 mm
Reduction factor rAl
0.3
Refer to "General Notes Relating to Pepperl+Fuchs Product Information".
Pepperl+Fuchs Group
USA: +1 330 486 0001
Germany: +49 621 776 1111
fa-info@de.pepperl-fuchs.com
www.pepperl-fuchs.com
fa-info@us.pepperl-fuchs.com
Singapore: +65 6779 9091
fa-info@sg.pepperl-fuchs.com
1
Inductive sensor
NBN40-L2M-A2-V1
Technical Data
Reduction factor rCu
0.28
Reduction factor r304
0.75
Reduction factor rBrass
0.38
Output type
4-wire
Nominal ratings
Operating voltage
UB
10 ... 30 V DC
Switching frequency
f
0 ... 180 Hz
Hysteresis
H
typ. 5 %
Reverse polarity protection
reverse polarity protected
Short-circuit protection
pulsing
Voltage drop
Ud
≤2V
Operating current
IL
0 ... 200 mA
Off-state current
Ir
0 ... 0.5 mA
No-load supply current
I0
≤ 20 mA
Time delay before availability
tv
80 ms
Operating voltage indicator
LED, green
Switching state indicator
LED, yellow
Functional safety related parameters
MTTFd
1230 a
Mission Time (TM)
20 a
Diagnostic Coverage (DC)
0%
Compliance with standards and directives
Standard conformity
Standards
EN 60947-5-2:2007
EN 60947-5-2/A1:2012
IEC 60947-5-2:2007
IEC 60947-5-2 AMD 1:2012
Approvals and certificates
EAC conformity
TR CU 020/2011
Protection class
II
Rated insulation voltage
Ui
253 V
Rated impulse withstand voltage
Uimp
4000 V
UL approval
cULus Listed, General Purpose
CCC approval
CCC approval / marking not required for products rated ≤36 V
Ambient conditions
Ambient temperature
-25 ... 85 °C (-13 ... 185 °F)
Storage temperature
-40 ... 85 °C (-40 ... 185 °F)
Mechanical specifications
Connection type
Connector plug M12 x 1 , 4-pin
Housing material
PA-GF35
metal base Xylan coated
metal mounting flange Xylan coated.
Sensing face
PA-GF35
Degree of protection
IP69K
Cable
Cable diameter
3.3 mm ± 0.15 mm
Pepperl+Fuchs Group
2
Inductive sensor
NBN40-L2M-A2-V1
Connection
1
L+
4
2
3
L-
Connection Assignment
1
4
2
3
Wire colors in accordance with EN 60947-5-2
1
2
3
4
BN
WH
BU
BK
(brown)
(white)
(blue)
(black)
Accessories
Female cordset, M12, 4-pin, PUR cable
V1-W-2M-PUR
MHW 01
Modular mounting bracket
MH 02-L
Mounting aid
V1-G-2M-PUR
Pepperl+Fuchs Group
3
很抱歉,暂时无法提供与“NBN40-L2M-A2-V1”相匹配的价格&库存,您可以联系我们找货
