NBN2-8GM50-E0
NBN2-8GM50-E0
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M8
    INDUCTIVE SEN 2MM NPN
NBN2-8GM50-E0 数据手册
Inductive sensor NBN2-8GM50-E0 Technical Data Model Number NBN2-8GM50-E0 Features • • Basic series 2 mm non-flush Accessories BF 8 Mounting flange, 8 mm General specifications Switching element function NPN NO 2 mm Rated operating distance sn Installation non-flush Output polarity DC Assured operating distance sa 0 ... 1.62 mm 0.45 Reduction factor rAl Reduction factor rCu 0.35 0.75 Reduction factor r304 Nominal ratings Operating voltage UB 10 ... 30 V Switching frequency f 0 ... 1500 Hz Reverse polarity protection reverse polarity protected Short-circuit protection pulsing ≤3V Voltage drop Ud Operating current IL 0 ... 100 mA 0 ... 0.5 mA typ. 0.1 µA at 25 °C Off-state current Ir No-load supply current I0 ≤ 15 mA Switching state indicator LED, yellow Functional safety related parameters MTTFd 2740 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type cable PVC , 2 m Core cross-section 0.14 mm2 Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval CSA approval CCC approval cULus Listed, General Purpose cCSAus Listed, General Purpose CCC approval / marking not required for products rated ≤36 V Dimensions 50 4 4 M8x1 13 Release date: 2016-09-13 13:59 Date of issue: 2016-09-13 801376_eng.xml LED Electrical Connection Refer to “General Notes Relating to Pepperl+Fuchs Product Information”. Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 4411 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com BN L+ BK BU L- Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1
NBN2-8GM50-E0 价格&库存
很抱歉,暂时无法提供与“NBN2-8GM50-E0”相匹配的价格&库存,您可以联系我们找货
