NBN3-8GM45-E2-V3
NBN3-8GM45-E2-V3
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M8
    INDUCTIVE SEN 3MM PNP
NBN3-8GM45-E2-V3 数据手册
Inductive sensor NBN3-8GM45-E2-V3 46 Dimensions Model Number NBN3-8GM45-E2-V3 Features • 3 mm non-flush Connection Technical Data 1 L+ 4 3 L- Pinout 4 1 3 Release date: 2012-05-11 09:52 Date of issue: 2012-05-11 088651_eng.xml Wire colors in accordance with EN 60947-5-2 1 3 4 BN BU BK (brown) (blue) (black) General specifications Switching element function Rated operating distance sn Installation Output polarity Assured operating distance sa Reduction factor rAl Reduction factor rCu Reduction factor r304 Nominal ratings Operating voltage UB Switching frequency f Reverse polarity protected Short-circuit protection Voltage drop Ud Operating current IL Off-state current Ir No-load supply current I0 Indication of the switching state Functional safety related parameters MTTFd Mission Time (TM) Diagnostic Coverage (DC) Ambient conditions Ambient temperature Mechanical specifications Connection type Housing material Sensing face Protection degree Compliance with standards and directives Standard conformity Standards PNP NO 3 mm non-flush DC 0 ... 2.43 mm 0.5 0.5 0.7 10 ... 30 V 0 ... 2000 Hz reverse polarity protected pulsing ≤3V 0 ... 100 mA 0 ... 0.5 mA typ. 0.1 µA at 25 °C ≤ 15 mA Multihole-LED, yellow 2790 a 20 a 0% -25 ... 70 °C (-13 ... 158 °F) Device connector M8 x 1 , 3-pin brass, nickel-plated PBT IP67 EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval CSA approval CCC approval cULus Listed, General Purpose cCSAus Listed, General Purpose Products with a maximum operating voltage of ≤36 V do not bear a CCC marking because they do not require approval. Accessories BF 8 Mounting flange, 8 mm V3-WM Female connector, M8, 3-pin, field attachable V3-GM Female connector, M8, 3-pin, field attachable V3-WM-2M-PUR Cable socket, M8, 3-pin, PUR cable V3-GM-2M-PUR Cable socket, M8, 3-pin, PUR cable Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1
NBN3-8GM45-E2-V3 价格&库存
很抱歉,暂时无法提供与“NBN3-8GM45-E2-V3”相匹配的价格&库存,您可以联系我们找货
