GTVA104001FA
Thermally-Enhanced High Power RF GaN on SiC HEMT
400 W, 50 V, DC - 1.4 GHz
Description
The GTVA104001FA is a 400-watt GaN on SiC high electron mobility transistor
(HEMT) for use in the DC - 1.4 GHz frequecy band. It features input matching,
high efficiency, and a thermally-enhanced surface-mount package with
earless flange.
Performance at 1% Duty Cycle
VDS = 50 V, IDQ = 100 mA,
128 µs–1%, Tflange = 25°C
Features
• GaN on SiC HEMT technology
• Input matched
21
• Typical pulsed CW performance: pulse width = 128 μs,
duty cycle = 10%, DC - 1.4 GHz, VDS = 50 V, IDQ = 100
mA
- Output power = 400 W
- Drain Efficiency = 70 %
- Gain = 19 dB
• Human Body Model Class 2 (per ANSI/ESDA/JEDEC
JS-001)
23
ergoqhgorgn'
22
qpjgfq4po5g
Gain (dB)
GTVA104001FA
Package H-37265J-2
18
17
• Capable of handling 10:1 VSWR (all phase angles) at
VDS = 50 V, IDQ = 100 mA, ƒ = 1090 MHz, POUT = 400 W
peak
960 MHz
1030 MHz
1150 MHz
1215 MHz
1090 MHz
19
• Pb-free and RoHS compliant
g104001fa-gr1
50 100 150 200 250 300 350 400 450 500
Output Power (W)
RF Characteristics
Pulsed RF Performance Specifications (tested in Wolfspeed production Doherty test fixture)
VDD = 50 V, IDQ = 100 mA, POUT = 390 W peak, ƒ = 1030 MHz, 128 μs pulse width, 10% duty cycle
Characteristic
Symbol Min Typ Max Unit
Gain
Gps
Drain Efficiency
hD
18.5 19.5 21.5 dB
73 77 — %
All published data at TCASE = 25°C unless otherwise indicated
ESD: Electrostatic discharge sensitive device—observe handling precautions!
Rev. P03.1-A, 2019-02-21
4600 Silicon Drive | Durham, NC 27703 | www.wolfspeed.com
GTVA104001FA
DC Characteristics
Characteristic
Conditions
Drain-source Breakdown Voltage
VGS = –8 V, ID = 10 mA V(BR)DSS 150 —
Drain-source Leakage Current
VGS = –8 V, VDS = 10 V
IDSS
5.8
mA
Gate Threshold Voltage
VDS = 10 V, ID = 42 mA
VGS(th)
–3.8
–3.0
–2.3
V
V
Recommended Operating Conditions
Parameter
Conditions
Drain Operating Voltage
Gate Quiescent Voltage
VDD 0 — 50 V
VDS = 48 V, ID = 0.11 A
VGS(Q)
–2.8
V
Absolute Maximum Ratings
Parameter
Symbol Value Unit
Drain-source Voltage
VDSS 125
V
Gate-source Voltage
VGS
V
–10 to +2
Gate Current
IG 20 mA
Drain Current
ID 4.6 A
Junction Temperature
TJ 225 °C
Storage Temperature Range
TSTG
–65 to +150
°C
Operation above the maximum values listed here may cause permanent damage. Maximum ratings are absolute ratings;
exceeding only one of these values may cause irreversible damage to the component. Exposure to absolute maximum rating conditions for
extended periods may affect device reliability. For reliable continuous operation, the device should be operated within the operating voltage
range (VDD) specified above.
Thermal Chracteristics
TFLANGE = 70°C, PDISS = 100 W, VDD = 50 V, IDQ = 100 mA, 400 W (peak), 1030 MHz, 128 µs pulse width, 10% duty cycle
Parameter
Symbol Value Unit
Thermal Resistance, Junction to Case
RqJC 0.14 °C/W
Ordering Information
Device:
Type and Version
Order Code
Package
Shipping
GTVA104001FA V1 R0
GTVA104001FA-V1-R0
H-37265J-2, earless flange
Tape & Reel, 50 pcs
GTVA104001FA V1 R2
GTVA104001FA-V1-R2
Tape & Reel, 250 pcs
Evaluation Board:
Type and Version
Frequency
Description
LTN/GTVA104001FA-V1
DC - 1.4 GHz
Class AB, Rogers 3010, 0.64 mm [0.025"] thick, 2 oz. copper, εr = 10.2
GTVA104001FA
Typical Performance (data taken in Wolfspeed production test fixture)
Input Return Loss
Performance at 10% Duty Cycle
VDS = 50 V, IDQ= 100 mA,
POUT = 400 WPEAK,128 µs–10%
128 µs–10%, Tflange = 25°C
23
Infput Return Loss (dB)
Gain (dB)
22
21
960 MHz
1030 MHz
1150 MHz
1215 MHz
1090 MHz
19
18
17
100
200
300
400
500
Output Power (W)
Drain Efficiency
80
Drain Efficiency (%)
78
76
74
72
70
68
66
64
62
g104001fa-gr4
950
1000
1050
1100
12
10
8
6
4
1150
Frequency (MHz)
g104001fa-gr3
950
1000
1050
1100
1150
Frequency (MHz)
60
14
2
g104001fa-gr2
1200
1250
1200
1250
GTVA104001FA
Load Pull Performance
Pulsed CW signal: 16 µsec, 10% duty cycle, 50 V, 100 mA, class AB
P3dB
Max Output Power
Freq
[MHz]
Zs
[W]
Zl
[W]
Gain
[dB]
PAE
POUT
960
0.38 – j2.87
3.22 – j1.38
18.89
70.9
56.99
1030
0.61 – j3.12
2.08 + j0.09
18.88
64.7
1090
0.74 – j3.26
2.32 – j0.15
18.71
1150
1.29 – j4.30
2.79 – j0.45
1215
1.89 – j4.87
2.65 – j0.76
Max PAE
Z Optimum
Zl
[W]
Gain
[dB]
PAE
Zl
[W]
Gain
[dB]
PAE
500
4.11 – j0.9
19.60
73.5
56.40
437
5.19 – j0.35
19.72
74.6
55.61
364
56.75
473
3.35 + j0.1
19.30
72.6
56.00
398
4.31 + j0.38
19.75
72.4
55.61
364
65.7
56.78
476
3.21 + j0.07
19.35
71.7
56.40
437
3.94 + j0.32
19.46
72.9
55.98
396
18.51
68.4
56.83
482
3.56 + j0.17
19.00
73.4
56.50
447
4.44 + j0.47
19.27
73.2
55.75
376
18.47
65.1
56.79
478
3.60 – j0.51
18.95
69.5
56.40
437
4.80 + j0.11
19.02
72.2
55.65
367
GTVA104001FA
Reference Circuit tuned for 960 to 1215 MHz
Reference Circuit Assembly
DUT
GTVA104001FA V1
Test Fixture Part No.
LTN/GTVA104001FA-V1
PCB
Find Gerber files for this test fixture on the Wolfspeed Web site at http://www.wolfspeed.com/RF
C206
RO3010, 25 MIL
(61)
RO3010, 25 MIL
(105)
C203
VGG
C105
VDD
R102 C103
C205
C104
R101
C204
C202
R103
C201
RF_IN
C102
RF_OUT
C101
960-1215 MHz
GTVA104001FA_IN_01A
960-1215 MHz
GTVA104001FA_OUT_01A
gtv a1 040 01f a_ CD _ 11- 16 - 18 _b n
Assembly diagram (not to scale)
GTVA104001FA
Reference Circuit (cont.)
Components Information
Component
Description
Manufacturer
P/N
C101, C102
Capacitor, 56 pF
ATC
ATC100A560JW150XB
C103
Capacitor, 56 pF
ATC
ATC100B560JW500XB
C104
Capacitor, 1 µF
TDK Corporation
C4532X7R2A105M230KA
C105
Capacitor, 10 µF
TDK Corporation
C5750X5R1H106K230KA
R101, R103
Resistor, 10 ohms
Panasonic – ECG
ERJ-3GEYJ100V
R102
Resistor, 5.6 ohms
Panasonic – ECG
ERJ-8RQJ5R6V
C201, C202
Capacitor, 10 pF
ATC
ATC100B560JW500XB
C203, C204
Capacitor, 10 µF
TDK Corporation
C5750X5R1H106K230KA
C205
Capacitor, 220 µF
Panasonic Electronic Components
ECA-2AHG221
C206
Capacitor, 3300 µF
Nichicon
UVR2A332MRD
Input
Output
Pinout Diagram (top view)
D
S
Pin Description
D Drain
G Gate
S
Source (flange)
G
H-37265J-2_03_pd_20 16-12-01-bn
GTVA104001FA
Package Outline Specifications
Package H-37265J-2
2X 6.35
[.250]
45° X .64
[.025]
D
FLANGE
10.16
[.400]
FLANGE
4X R0.63
[R.025] MAX
SPH 1.57
[.062]
2X 2.59±.51
[.102±.020]
LID
(15.34
10.16±.25 [.604])
[.400±.010]
CL
G
CL
10.16±.25
[.400±.010]
3.61±.38
[.142±.015]
H-37265J-2_02_po_05-29-2015
1.02
[.040]
10.16
[.400]
S
Diagram Notes—unless otherwise specified:
1. Interpret dimensions and tolerances per ASME Y14.5M-1994.
2. Primary dimensions are mm. Alternate dimensions are inches.
3. All tolerances ± 0.127 [.005] unless specified otherwise.
4. Pins: D – drain; G – gate; S – source.
5. Lead thickness: 0.10 + 0.051/-0.025 mm [.004 +0.002/-0.001 inch].
6. Gold plating thickness: 1.14 ± 0.38 micron [45 ± 15 microinch].
8
GTVA104001FA
Revision History
Revision
Date
Data Sheet
Page
Subjects (major changes at each revision)
01
2016-05-03
Advance
All
Proposed specifications for new product development
02
2018-05-08
Advance
All
Converted to Wolfspeed Data Sheet, updated DC and thermal characteristics
03
2018-11-14
Production
All
Showing released product specifications, including updated characteristics
tables, performance graphs, reference circuit information
03.1
2019-02-21
Production
3
Added "Wolfspeed" to Performance heading.
For more information, please contact:
4600 Silicon Drive
Durham, North Carolina, USA 27703
Sales Contact
RFSales@wolfspeed.com
RF Product Marketing Contact
RFMarketing@wolfspeed.com
919.407.7816
Notes
Disclaimer
Specifications are subject to change without notice. Cree, Inc. believes the information contained within this data sheet
to be accurate and reliable. However, no responsibility is assumed by Cree for any infringement of patents or other rights
of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Cree. Cree makes no warranty, representation or guarantee regarding the suitability of its products for any
particular purpose. “Typical” parameters are the average values expected by Cree in large quantities and are provided for
information purposes only. These values can and do vary in different applications and actual performance can vary over
time. All operating parameters should be validated by customer’s technical experts for each application. Cree products
are not designed, intended or authorized for use as components in applications intended for surgical implant into the
body or to support or sustain life, in applications in which the failure of the Cree product could result in personal injury or
death or in applications for planning, construction, maintenance or direct operation of a nuclear facility.
Copyright © 2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Wolfspeed™ and the Wolfspeed logo are trademarks of Cree, Inc.
www.wolfspeed.com
