MUSES8920E
MUSES8920E
    NJR(新日本无线)
    SOP8_150MIL
    IC OPAMP JFET 2 CIRCUIT 8SOP
MUSES8920E 数据手册
MUSES8920 High Quality Audio J-FET Input Dual Operational Amplifier ■ GENERAL DESCRIPTION The MUSES8920 is a high quality audio J-FET input dual operational amplifier, which is optimized for high-end audio, professional audio and portable audio applications. It is suitable for audio preamplifiers, active filters, and line amplifiers. In addition, J-FET input type has advantage of the low input bias current, it is suitable for transimpedance amplifier (I/V converter). ■ FEATURES ●Operating Voltage ●Low Noise ●THD ●Slew Rate ●GBW ●High Output Current ●J-FET Input ●Bipolar Technology ●Package Outline ■ PACKAGE OUTLINE MUSES8920D (DIP8) MUSES8920E (SOP8 JEDEC 150mil (EMP8)) MUSES8920KX7 (DFN8-X7 (ESON8-X7)) ±3.5V to ±17V 8nV/√Hz typ. 0.0004% typ. (Av=1) 25V/µs typ. 11MHz typ. 100mA typ.(short-circuit current) ■ PIN CONFIGLATION DIP8, SOP8 JEDEC 150mil 1 2 7 A 3 DIP8, SOP8 JEDEC 150mil DFN8-X7 (ESON8-X7)(3.5mm x 4.0mm) 1. A OUTPUT 2. A -INPUT 3. A +INPUT 4. V5. B +INPUT 6. B -INPUT 7. B OUTPUT 8.V+ 8 B 4 6 5 DFN8-X7 (ESON8-X7) Bottom View Top View ■ APPLICATIONS ● Portable Audio ● Home Audio ● Professional Audio ● Car Audio 1 2 3 4 A B 8 8 1 7 7 2 6 6 5 5 Exposed Pad 3 4 About Exposed Pad Connect the Exposed Pad on the GND. I/V Digital Input DA Converter Analog Output I/V LPF Buff DAC Output I/V converter + LPF circuit MUSES and this logo are trademarks of New Japan Radio Co., Ltd. Ver.10 -1- MUSES8920 ■ ABSOLUTE MAXIMUM RATING (Ta=25ºC unless otherwise specified) PARAMETER Supply Voltage Differential Input Voltage Range Common Mode Input Voltage Range Power Dissipation Operating Temperature Range Storage Temperature Range SYMBOL RATING UNIT V /V ±18 V VID ±30 V + - (Note1) VICM ±15 DIP8:870 SOP8:900 (Note2) DFN8-X7: 690 (Note2) 2900 (Note3) -40 to +125 -50 to +150 PD Topr Tstg V mW ºC ºC (Note1) For supply Voltages less than ±15 V, the maximum input voltage is equal to the Supply Voltage. (Note2) Mounted on the EIA/JEDEC standard board (114.3×76.2×1.6mm, two layer, FR-4). DFN8 is connecting to GND in the center part on the back. (Note3) EIA/JEDEC STANDARD Test board (76.2 x 114.3 x 1.6mm, 4layers, FR-4, Applying a thermal via hole to a board based on JEDEC standard JESD51-5) mounting. The PAD connecting to GND in the center part on the back. (Note4) NJM8920 is ESD (electrostatic discharge) sensitive device. Therefore, proper ESD precautions are recommended to avoid permanent damage or loss of functionality. ■ RECOMMENDED OPERATING VOLTAGE (Ta=25ºC) PARAMETER Supply Voltage SYMBOL TEST CONDITION V+/V- MIN. TYP. MAX. UNIT ±3.5 - ±17 V MIN. TYP. MAX. UNIT 106 105 105 80 80 ±13 ±12.8 ±12.5 ±12.5 9 0.8 5 2 135 133 130 110 110 ±14 ±13.8 ±13.5 ±14 12 5 250 220 - mA mV pA pA dB dB dB dB dB V V V V MIN. TYP. MAX. UNIT - 11 10 70 8 1.1 1.1 0.0004 150 25 3.5 - MHz MHz Deg nV/√Hz μVrms μVrms % dB V/us ■ ELECTRICAL CHARACTERISTICS ● DC CHARACTERISTICS (V+/V-=±15V, Ta=25ºC, unless otherwise specified) PARAMETER Supply Current Input Offset Voltage Input Bias Current Input Offset Current Voltage Gain1 Voltage Gain2 Voltage Gain3 Common Mode Rejection Ratio Supply Voltage Rejection Ratio Maximum Output Voltage1 Maximum Output Voltage2 Maximum Output Voltage3 Common Mode Input Voltage Range SYMBOL Icc VIO IB IIO AV1 AV2 AV3 CMR SVR VOM1 VOM2 VOM3 VICM TEST CONDITION RL=∞, No Signal RS=50Ω, RL=10kΩ, Vo=±13V RL=2kΩ, Vo=±12.8V RL=600Ω, Vo=12.5V VICM=±12.5V (Note5) V+/V-=±3.5 to ±17V (Note6) RL=10kΩ RL=2kΩ RL=600Ω CMR≥80dB (Note5) CMR is calculated by specified change in offset voltage. (VICM=0V to +12.5V, VICM=0V to -12.5V) + (Note6) SVR is calculated by specified change in offset voltage. (V /V =±3.5 to ±17V) ● AC CHARACTERISTICS (V+/V-=±15V, Ta=25ºC, unless otherwise specified) PARAMETER Gain Bandwidth Product Unity Gain Frequency Phase Margin Equivalent Input Noise Voltage1 Equivalent Input Noise Voltage2 Equivalent Input Noise Voltage3 Total Harmonic Distortion Channel Separation Slew Rate SYMBOL GB fT ΦM VNI1 VNI2 VNI3 THD CS SR TEST CONDITION f=10kHz AV=+100, RS=100Ω, RL=2kΩ, CL=10pF AV=+100, RS=100Ω, RL=2kΩ, CL=10pF f=1kHz RIAA, RS=2.2kΩ, 30kHz, LPF (Note7) f=20 to 20kHz (Note8) f=1kHz , AV=+10, Vo=5Vrms, RL=2kΩ f=1kHz , AV=-100, RL=2kΩ AV=1, VIN=2Vp-p, RL=2kΩ, CL=10pF (Note7) DIP8 and SOP8 (Note8) DFN8-X7 -2- Ver.10 MUSES8920 ■ POWER DISSIPATION vs. AMBIENT TEMPERATURE IC is heated by own operation and possibly gets damage when the junction power exceeds the acceptable value called Power Dissipation PD. The dependence of the MUSES8920 PD on ambient temperature is shown in Fig 1. The plots are depended on following two points. The first is PD on ambient temperature 25ºC, which is the maximum power dissipation. The second is 0W, which means that the IC cannot radiate any more. Conforming the maximum junction temperature Tjmax to the storage temperature Tstg derives this point. Fig.1 is drawn by connecting those points and conforming the PD lower than 25ºC to it on 25ºC. The PD is shown following formula as a function of the ambient temperature between those points. Dissipation Power PD = Tjmax - Ta ja [W] (Ta=25ºC to Ta=150ºC) Where, ja is heat thermal resistance which depends on parameters such as package material, frame material and so on. Therefore, PD is different in each package. While, the actual measurement of dissipation power on MUSES8920 is obtained using following equation. (Actual Dissipation Power) = (Supply Current Icc) X (Supply Voltage V+– V-) – (Output Power Po) The MUSES8920 should be operated in lower than PD of the actual dissipation power. To sustain the steady state operation, take account of the Dissipation Power and thermal design. Fig 1 3000 DFN8-X7 4layers Power Dissipation Pd [mW] 2500 2000 1500 1000 SOP8 DIP8 500 DFN8-X7 2layers 0 0 Ver.10 50 100 Ambient Temperature Ta [˚C] 150 -3- MUSES8920 ■ PACKAGE OUTLINE (DFN8-X7) -4- Ver.10 MUSES8920 ■ TYPICAL CARACTERISTICS THD+N vs. Output Voltage (Frequency) THD+N vs. Output Voltage (Frequency) V+/V-=±15V, AV=+10, RL=2k, Ta=25ºC 10 V+/V-=±3.5V, AV=+10, RL=2k, Ta=25ºC 10 1 1 THD+N [%] THD+N [%] f=20Hz 0.1 f=20kHz 0.01 0.1 f=1kHz 0.01 f=1kHz f=20kHz 0.001 f=20kHz 0.001 0.0001 0.01 0.1 1 10 Output Voltage [Vrms] 0.0001 0.01 100 Voltage Noise vs. Frequency Channel Separation [dB] 60 40 20 -130 -135 -140 -145 -150 -155 -160 10 60 10k 100 1k 10k Frequency [Hz] 100k Phase Margin vs. Temperature (Supply Voltage) V+/V-=±15V, AV=+100, RS=100Ω, RL=2kΩ, CL=10pF, VIN=-30dBm 90 Ta=+85ºC Phase Ta=-40ºC 0 -45 -90 Ta=+85ºC Ta=+25ºC Ta=-40ºC -40 Phase [deg] Ta=+25ºC 0 -60 10k 10 V+/V-=±15V, AV=+100, RL=2kΩ, CL=10pF Gain -20 100k Gain vs. Frequency (Temperature) 40 20 100 1k Frequency [Hz] Phase Margin [deg] Equivalent Input Noise Voltage [nV/Hz] -125 80 1 Voltage Gain [dB] V+/V-=±15V, AV=-100, RL=2kΩ, Ta=25ºC -120 0 Ver.10 100 Channel Separation vs. Frequency V+/V-=±15V, AV=+100, RS=100Ω, RL=, Ta=25ºC 100 0.1 1 10 Output Voltage [Vrms] V+/V-=±15V 80 70 V+/V-=±3.5V -135 100k 1M 10M Frequency [Hz] -180 100M 60 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -5- MUSES8920 ■ TYPICAL CARACTERISTICS Pulse Response Slew Rate vs. Temperature V+/V-=±15V, Gv=0dB, CL=10pF, RL=2kΩ, Ta=25ºC V+/V-=±15V, VIN=2VP-P, f=100kHz, Gv=0dB, CL=10pF, RL=2kΩ 80 Input 70 Voltage [1V/div] Slew Rate [V/μs] 60 Fall 50 40 30 20 Rise 10 Output 0 Time [1μs/div] -50 Supply Current vs. Supply Voltage (Temperature) -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] Supply Current vs. Temperature (Supply Voltage) AV=0dB AV=0dB 12 12 Ta=+25ºC 8 Ta=+85ºC 6 Ta=-40ºC 4 2 V+/V-=±3.5V 6 4 0 ±0 ±4 ±8 ±12 + Supply Voltage V /V [V] ±16 -50 Input Offset Voltage vs. Supply Voltage (Temperature) -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] Input Offset Voltage vs. Temperature (Supply Voltage) VICM=0V, VIN=0V 2.0 VICM=0V, VIN=0V 2.0 1.5 1.0 Input Offset Voltage [mV] Input Offset Voltage [mV] 8 2 0 Ta=-40ºC 0.5 0.0 Ta=+85ºC Ta=+25ºC -0.5 -1.0 1.5 1.0 V+/V-=±15V 0.5 0.0 V+/V-=±3.5V -0.5 -1.0 0 -6- V+/V-=±15V 10 Supply Current [mA] Supply Current [mA] 10 ±4 ±8 ±12 Supply Voltage V+/V- [V] ±16 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] Ver.10 MUSES8920 ■ TYPICAL CARACTERISTICS Input Offset Voltage vs. Common Mode Input Voltage Input Offset Voltage vs. Common Mode Input Voltage (Temperature) + V /V =±15V (Temperature) + V /V =±3.5V Input Offset Voltage [mV] 1.5 1.0 Ta=-40ºC 0.5 0.0 Ta=+25ºC Ta=+85ºC -0.5 -1.0 -15 2.0 Input Offset Voltage [mV] 2.0 1.5 1.0 Ta=-40ºC 0.5 0.0 -1.0 -10 -5 0 5 10 15 Common Mode Input Voltage [V] + -4 -3 -2 -1 0 1 2 3 Common Mode Input Voltage [V] (Temperature) V+/V-=±15V, Ta=25ºC 10 9 Input Bias Current [pA] 100n 10n 1n 100p 10p 8 7 6 5 4 1p 3 -50 -25 -15 0 25 50 75 100 125 150 Ambient Temperature [ºC] -10 -5 0 5 10 Common Mode Input Voltage [V] V+/V-=±15V 130 VICM=0V+12.5V 120 110 100 VICM=-12.5V0V 90 80 VICM=0V, V+/V-=±3.5V±16V 140 Supply Voltage Rejection Ratio [dB] 140 15 SVR vs. Temperature CMR vs. Temperature Common Mode Rejection Ratio [dB] 4 Input Bias Current vs. Common Mode Input Voltage - VICM=0V, V /V =±15V 1000n 130 120 110 100 90 80 -50 Ver.10 Ta=+25ºC -0.5 Input Bias Current vs. Temperature (Supply Voltage) Input Bias Current [A] Ta=+85ºC -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -7- MUSES8920 ■ TYPICAL CARACTERISTICS Output Voltage vs. Output Current (Temperature) Output Voltage vs. Output Current (Temperature) V+/V-=±15V 15 V+/V-=±3.5V 4 Isource Output Voltage [V] 10 Ta=+85ºC 3 Ta=-40ºC Output Voltage [V] Isource Ta=+25ºC 5 0 Ta=+85ºC -5 Ta=+25ºC Ta=-40ºC -10 -15 Ta=+25ºC 1 Ta=-40ºC 0 -1 -2 Isink -4 1 10 100 Output Current [mA] 1 1k 10 100 Output Current [mA] 1k Maximum Output Voltage vs. Load Resistance Maximum Output Voltage vs. Load Resistance (Temperature) V /V =±15V, Gv=open, RL to 0V (Temperature) V+/V-=±3.5V, Gv=open, RL to 0V 15 10 - 4 Maximum Output Voltage [V] + Maximum Output Voltage [V] 2 -3 Isink Ta=-40ºC Ta=+25ºC 5 Ta=+85ºC 0 -5 -10 -15 3 2 1 0 Ta=+85ºC -1 Ta=+25ºC Ta=-40ºC -2 -3 -4 10 -8- Ta=+125ºC 100 1k 10k Load Resistance [Ω] 100k 10 100 1k 10k Load Resistance [Ω] 100k Ver.10 MUSES8920 ■ APPLICATION CIRCUIT Gain Stage Analog Input I/V Att AD Converter Buff Digital Output Digital Input DA Converter I/V (Fig.1: ADC Input) L-ch. Analog Intput Analog Output LPF Buff (Fig.2:DAC Output) L-ch. Analog Output R-ch. Analog Intput R-ch. Analog Output HPF DAC Vcc 1/2Vcc 1/2Vcc (Fig.3: Half Vcc Buffer on Single Supply Application) (Fig.4:DAC LPF Circuit ) ■ NOTE Precaution for counterfeit semiconductor products We have recently detected many counterfeit semiconductor products that have very similar appearances to our operational amplifier “MUSES” in the world-wide market.In most cases, it is hard to distinguish them from our regular products by their appearance, and some of them have very poor quality and performance. They can not provide equivalent quality of our regular product, and they may cause breakdowns or malfunctions if used in your systems or applications. We would like our customers to purchase “MUSES” through our official sales channels : our sales branches, sales subsidiaries and distributors. Please note that we hold no responsibilities for any malfunctions or damages caused by using counterfeit products. We would appreciate your understanding. The specifications on this data book are only given for information, without any guarantee as regards either mistakes or omissions. The application circuits in this data book are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.10 -9-
MUSES8920E 价格&库存
很抱歉,暂时无法提供与“MUSES8920E”相匹配的价格&库存,您可以联系我们找货
