C4D15120H
VRRM
Silicon Carbide Schottky Diode
Z-Rec Rectifier
Features
IF (TC=135˚C) =
19 A
Q c
1.2kV Schottky Rectifier
Zero Reverse Recovery Current
High-Frequency Operation
Temperature-Independent Switching
Extremely Fast Switching
Positive Temperature Coefficient on VF
Increased Creepage/Clearance Distance
77.5 nC
TO-247-2
PIN 1
Replace Bipolar with Unipolar Rectifiers
Essentially No Switching Losses
Higher Efficiency
Reduction of Heat Sink Requirements
Parallel Devices Without Thermal Runaway
CASE
PIN 2
Applications
1200 V
Package
Benefits
Part Number
Package
Marking
C4D15120H
TO-247-2
C4D15120
Switch Mode Power Supplies (SMPS)
Boost diodes in PFC or DC/DC stages
Free Wheeling Diodes in Inverter stages
AC/DC converters
Maximum Ratings (TC=25°C unless otherwise specified)
Symbol
Parameter
Unit
Test Conditions
Note
VRRM
Repetitive Peak Reverse Voltage
1200
V
VRSM
Surge Peak Reverse Voltage
1300
V
VR
DC Peak Reverse Voltage
1200
V
IF
Continuous Forward Current
39
19
15
A
TC=25˚C
TC=135˚C
TC=147˚C
IFRM
Repetitive Peak Forward Surge Current
64
42
A
TC=25˚C, tP=10 ms, Half Sine Pulse
TC=110˚C, tP=10 ms, Half Sine Pulse
IFSM
Non-Repetitive Forward Surge Current
87
72
A
Fig. 8
IF,Max
Non-Repetitive Peak Forward Current
900
750
A
TC=25˚C, tP=10 ms, Pulse
TC=110˚C, tP=10 ms, Pulse
Fig. 8
174.5
75.5
W
TC=25˚C
TC=110˚C
Fig. 4
200
V/ns
VR=0-960V
38
26
A2s
-55 to
+175
˚C
1
8.8
Nm
lbf-in
Ptot
Power Dissipation
dV/dt
Diode dV/dt ruggedness
∫i2dt
i2t value
TJ , Tstg
Operating Junction and Storage Temperature
TO-247 Mounting Torque
1
Value
C4D15120H Rev. -, 02-2018
TC=25˚C, tP=10 ms
TC=110˚C, tP=10 ms
M3 Screw
6-32 Screw
Fig. 3
Electrical Characteristics
Symbol
Parameter
Typ.
Max.
Unit
VF
Forward Voltage
1.5
2.3
1.8
3
V
IR
Reverse Current
35
120
200
300
QC
Total Capacitive Charge
C
Total Capacitance
EC
Capacitance Stored Energy
Test Conditions
Note
IF = 15 A TJ=25°C
IF = 15 A TJ=175°C
Fig. 1
μA
VR = 1200 V TJ=25°C
VR = 1200 V TJ=175°C
Fig. 2
77.5
nC
VR = 800 V, IF = 15A
di/dt = 200 A/μs
TJ = 25°C
Fig. 5
1200
70
50
pF
VR = 0 V, TJ = 25°C, f = 1 MHz
VR = 400 V, TJ = 25˚C, f = 1 MHz
VR = 800 V, TJ = 25˚C, f = 1 MHz
Fig. 6
22
μJ
VR = 800 V
Fig. 7
Note:This is a majority carrier diode, so there is no reverse recovery charge.
Thermal Characteristics
Symbol
RθJC
Parameter
Thermal Resistance from Junction to Case
Typ.
Unit
Note
0.86
°C/W
Fig. 9
Typical Performance
2
30
TJ=-55°C
T = 25°C
TJ= 75°C
J
T =125°C
TJ =175°C
J
25
1.8
1.6
1.4
IR (mA)
IF (A)
1.2
1
0.8
TJ=-55°C
TJ= 25°C
T = 75°C
J
T =125°C
TJ =175°C
J
10
0.6
0.4
5
0.2
1
1.5
2
2.5
3
VF (V)
Figure 1. Forward Characteristics
2
3.5
4
200
400
600
800
1000
1200
1400
VR (V)
Figure 2. Reverse Characteristics
1600
1800
Typical Performance
140
200
120
IF(peak) (A)
100
80
Duty
Duty
Duty
Duty
Duty
160
PTot (W)
10%
20%
30%
50%
70%
DC
60
120
80
40
40
50
75
100
125
150
175
25
50
75
TC ˚C
100
125
150
175
TC ˚C
Figure 4. Power Derating
Figure 3. Current Derating
1400
90
80
1200
70
1000
50
C (pF)
Qc (nC)
60
40
30
800
600
400
10
400
600
800
0.1
1000
VR (V)
Figure 5. Recovery Charge vs. Reverse Voltage
3
1
10
100
VR (V)
Figure 6. Capacitance vs. Reverse Voltage
1000
Typical Performance
40
40.0
1000
1000
35
35.0
EC Capacitive
Energy (uJ)
C
30
30.0
(A)
IFSMIFSM
(A)
E (mJ)
25
25.0
15
15.0
100
100
TJ_initial = 25°C
T
= 110°C
J_initial
10.0
10
5.05
10
10
1E-05 1E-04 1E-03 1E-02
1.E-05
1.E-04
1.E-03
1.E-02
0.00
0 200 400 600 800 1000
400
600
800
1000
tp(s)
tp (s)
VR Reverse Voltage (V)
VR (V)
Junction
To Case
Impedance,(˚C/W)
ZthJC (oC/W)
Thermal
Resistance
Figure 7. Typical Capacitance Stored Energy
Figure 8. Non-repetitive peak forward surge current
versus pulse duration (sinusoidal waveform)
1
0.5
0.3
100E-3
0.1
0.05
10E-3
0.02
0.01
SinglePulse
1E-3
1E-6
10E-6
100E-6
1E-3
Time,
tp (s)
T (Sec)
10E-3
Figure 9. Transient Thermal Impedance
4
100E-3
1
Package Dimensions
Package TO-247-2
POS
A
Inches
Millimeters
Min
Max
Min
Max
.190
.205
4.70
5.31
A1
.087
.102
2.21
2.59
A2
.059
.098
1.50
2.49
1.40
b
.039
.055
0.99
b2
.065
.094
1.65
2.39
c
.015
.035
0.38
0.89
21.46
D
.819
.845
20.80
D1
.515
13.08
D2
.020
.053
0.51
1.35
16.26
E
.620
.640
15.49
E1
.530
13.46
E2
.135
.157
3.43
3.99
e
.214
ØK
.010
L
5.44
0.25
.780
.800
19.81
20.32
L1
ØP
.140
.177
4.50
.144
3.56
3.66
ØP1
.278
.291
7.06
7.39
Q
.212
.244
5.38
6.20
S
W
.243
6.17
.006
0.15
PIN 1
TECHNOLOGIES, INC.
CASE
PIN 2
Recommended Solder Pad Layout
all units are in inches
.4
Part Number
Package
Marking
C4D15120H
TO-247-2
C4D15120
TO-247-2
Note: Recommended soldering profiles can be found in the applications note here:
http://www.wolfspeed.com/power_app_notes/soldering
5
Diode Model
Diode Model CSD04060
Vf T = V
T + If*R
Vf
= VT
T
T
+ If * RT
VT= 0.965 + (Tj * -1.3*10-3)
RT= 0.096 + (Tj * 1.06*10-3)
VT = 0.97 + (Tj * -2.12*10-3)
RT = 0.031 + (Tj * 3.92*10-4)
VT
RT
Note: Tj = Diode Junction Temperature In Degrees Celsius,
valid from 25°C to 175°C
Notes
• RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred
to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance
with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can
be obtained from your Wolfspeed representative or from the Product Ecology section of our website at http://
www.wolfspeed.com/power/tools-and-support/product-ecology.
• REACh Compliance
REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable
future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration.
REACh banned substance information (REACh Article 67) is also available upon request.
This product has not been designed or tested for use in, and is not intended for use in, applications implanted into
the human body nor in applications in which failure of the product could lead to death, personal injury or property
damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines,
cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control
systems, or air traffic control systems.
Related Links
Cree SiC Schottky diode portfolio: http://www.wolfspeed.com/Power/Products#SiCSchottkyDiodes
Schottky diode Spice models: http://www.wolfspeed.com/power/tools-and-support/DIODE-model-request2
SiC MOSFET and diode reference designs: http://go.pardot.com/l/101562/2015-07-31/349i
Copyright © 2018 Cree, Inc. All rights reserved.
The information in this document is subject to change without notice.
Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc.
6
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
Fax: +1.919.313.5451
www.cree.com/power
