SRA2020 – SRA20150
Taiwan Semiconductor
20A, 20V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC/DC converters
PARAMETER
VALUE
UNIT
IF
A
VRRM
20 - 150
V
IFSM
300
A
TJ MAX
125, 150
°C
Package
TO-220AC
Configuration
Single die
MECHANICAL DATA
Case: TO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.90g (approximately)
TO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
SRA
2020
SRA
2020
Reverse voltage, total rms value
VR(RMS)
14
PARAMETER
SYMBOL
Marking code on the device
SRA
2030
SRA
2030
30
SRA
2040
SRA
2040
40
SRA
2050
SRA
2050
50
SRA
2060
SRA
2060
60
21
28
35
42
SRA SRA
SRA
UNIT
2090 20100 20150
SRA SRA
SRA
2090 20100 20150
90
100
150
V
63
70
105
V
Forward current
Surge peak forward current
8.3ms single half sine wave
superimposed on rated load
Junction temperature
IF
A
IFSM
300
A
Storage temperature
TSTG
TJ
-55 to +125
-55 to +150
-55 to +150
1
°C
°C
Version: K2103
SRA2020 – SRA20150
THERMAL PERFORMANCE
PARAMETER
Junction-to-case resistance
SYMBOL
TYP
UNIT
RӨJC
1.5
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
SRA2020
SRA2030
SRA2040
SRA2050
SRA2060
SRA2090
SRA20100
SRA20150
SRA2020
SRA2030
SRA2040
SRA2050
SRA2060
SRA2090
SRA20100
SRA20150
SRA2020
SRA2030
SRA2040
SRA2050
SRA2060
SRA2090
SRA20100
SRA20150
SRA2020
SRA2030
SRA2040
SRA2050
SRA2060
SRA2090
SRA20100
SRA20150
IF = 20A, TJ = 25°C
SYMBOL
VF
TYP
MAX
UNIT
0.55
V
0.70
V
0.92
V
1.02
V
500
µA
100
µA
15
mA
10
mA
mA
mA
5
mA
TJ = 25°C
TJ = 100°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SRA20x
TO-220AC
50 / Tube
SRA20xH
TO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 20V(SRA2020) to 150V(SRA20150)
2. “H” means AEC-Q101 qualified
2
Version: K2103
SRA2020 – SRA20150
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
SRA2050-SRA20150
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
24
16
12
SRA2020-SRA2040
8
1000
4
f=1.0MHz
Vsig=50mVp-p
100
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
1
TJ=75°C
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
100
10
SRA2050-SRA2060
1
UF1DLW
SRA2020-SRA2040
10
TJ=125°C
TJ=25°C
0.1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=100°C
1
0.01
SRA2090-SRA20150
0.001
0.1
0.5
0.20.3 0.30.4 0.4
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width
300μs
Pulse
width
1% duty cycle
0.6
0.5
0.7
0.6
0.8
0.7
0.9
0.8
10.9 1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
350
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
0.1
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
300
250
200
150
100
50
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: K2103
1.2
SRA2020 – SRA20150
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: K2103
SRA2020 – SRA20150
PACKAGE OUTLINE DIMENSIONS
TO-220AC
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2103
SRA2020 – SRA20150
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: K2103
很抱歉,暂时无法提供与“SRA20150 C0G”相匹配的价格&库存,您可以联系我们找货
