TS358
Single Supply Dual Operational Amplifiers
SOP-8
DIP-8
Pin assignment:
1. Output A
8. Vcc
2. Input A (-)
7. Output B
3. Input A (+)
6. Input B (-)
4. Gnd
5. Input B (+)
General Description
Utilizing the circuit designs perfected for recently introduced Quad Operational Amplifiers, these dual operational
amplifiers have several distinct advantages over standard operational amplifier types in single supply applications.
They can operate at supply voltages as low as 3.0 Volts or as high as 32 Volts with quiescent currents about one fifth
of those associated with the LM741 (on a pet amplifier basis). The common mode input range includes the negative
supply, thereby eliminating the necessity for external biasing components in many applications. The TS358 is
equivalent to one half of TS324, and output voltage range also includes the negative supply voltage.
Features
Block Diagram
Short circuit protected outputs
True differential input stage
Single supply operation: 3V to 32V
Low input bias currents
Internally compensated
Common mode range extends to negative supply
Single and split supply operation
Similar performance to the popular MC1558
Ordering Information
Part No.
TS358CD C3G
TS358CS RLG
Package
Packing
DIP-8
SOP-8
50pcs / Tube
2,500pcs / 13” Reel
“G” denotes for Halogen free products
Absolute Maximum Rating
Parameter
Symbol
Limit
Unit
Supply Voltage
VCC
+32 or ±16
V
Differential Input Voltage (Split Power Supplies)
VIDR
32
V
Input Common Mode Voltage Range (note 1)
VICR
-0.3 to 32
V
Input Forward Current (note 2)
IIF
50
mA
Output Short Circuit Duration
tsc
Continuous
Operating Junction Temperature Range
TJ
0 ~ +70
o
C
o
Storage Temperature Range
TSTG
-65 ~ +150
C
Note 1: For supply, voltages less than 32V for the TS358 the absolute maximum input voltage is equal to the supply
voltage.
Note 2: This input current will only exist when the voltage is negative at any of the input leads. Normal output states
will reestablish when the input voltage returns to a voltage greater than -0.3V.
Document Number: DS_P0000184
1
Version: B15
TS358
Electrical Characteristics (VCC = 5V, Ta=25oC; unless otherwise specified.)
Characteristics
Input Offset Voltage
VCC= 5.0V to 30V, VIC= 0V to Vcc -1.7 V, Vo= 1.4V, RS= 0Ω
TLOW ≤ Ta ≤THIGH
Average Temperature Coefficient of Input Offset Voltage
Input Offset Current
TLOW ≤ Ta ≤THIGH
Average Temperature Coefficient of input Offset Current
Input Bias Current
TLOW ≤ Ta ≤THIGH
Input Common-Mode Voltage Range)
VCC = 30 V (Note1)
VCC = 30 V, TLOW ≤ Ta ≤THIGH
Differential Input Voltage Range
Large Signal Open-Loop Voltage Gain
RL = 2.0K, VCC =15V, For Large VO Swing,
TLOW ≤ Ta ≤THIGH
Channel Separation
1.0 KHz to 20KHz
Common Mode Rejection Ratio
RS ≤ 10 kΩ
Power Supply Rejection Ratio
Output Voltage Range, RL = 2KΩ
Output Voltage -- High Limit
VCC = 30 V, RL = 2 kΩ
VCC = 30 V, RL = 10 kΩ
Output Voltage -- Low Limit
VCC = 5.0 V, RL = 10 kΩ
Output Source Current VID=+1.0V,VCC=15V
Output Sink Current
VID = -1.0 V, VCC = 15 V
VID = -1.0 V, VO = 200 mV
Output Short Circuit to Ground (Note 2)
Power Supply Current ,
VCC = 30 VVO = 0 V, RL = ∞
VCC = 5.0 V, VO = 0 V, RL = ∞
Notes :
Symbol
Min
Typ
Max
Unit
Vio
2.0
-7.0
5.0
-10
-45
-50
7.0
9.0
-50
150
--250
-500
mV
28
VCC
V
AVOL
25
15
100
V/mV
-120
dB
CMRR
65
70
dB
PSRR
VOR
65
-3.3
dB
V
VOH
26
27
-28
V
VOL
5.0
mV
IO+
mA
IO-
10
12
40
--60
mA
uA
mA
1.5
0.7
3.0
1.2
mA
∆Iio/∆T
Iio
∆Iio/∆T
IIB
VICR
VIDR
IOS
ICC
o
uV/ C
nA
o
pA/ C
nA
V
1. The input common mode voltage or either input signal voltage should not be allowed to go negative by more than
0.3 V. The upper end of the common mode voltage range is VCC 17V, but either or both inputs can go to +32V.
2. Short circuits from the output to VCC can cause excessive heating and eventual destruction. Destructive dissipation
can recruit from simultaneous shorts on all amplifiers.
2
Version: B15
TS358
Electrical Characteristics Curve (Ta=25oC; unless otherwise specified.)
Figure 1. Large Signal Voltage Follower
Response
Figure 2. Input Voltage Range
Figure 3. Open Loop Frequency
Figure 4. Large Signal Frequency Response
Figure 5. Small-Signal Voltage Follower Pulse
Response (Noninverting)
Figure 6. Power Supply Current vs. Supply
Voltage
3
Version: B15
TS358
Application Description
The TS358 made using two internally compensated, two-stage operational amplifiers. The first stage performs not only
the first stage gain function but also performs the level shifting and transconductance reduction functions. By reducing
the transconductance, a smaller compensation capacitor (only 5.0pF) can be employed, thus saving chip area. Another
feature of this input stage is that the input common mode range can include the negative supply or ground, in single
supply operation, without saturating either the input devices or the differential to single-ended converter. The second
stage consists of a standard current source load amplifier stage.
Each amplifier is biased from an internal-voltage regulator, and which has a low temperature coefficient thus giving
each amplifier good temperature characteristics as well as excellent power supply rejection.
Figure 7. Voltage Reference
Figure 8. Wien Bridge Oscillator
Figure 9. Bi-Quad Filter
4
Version: B15
TS358
Application Description (Continue)
Figure 10. High Impedance Differential Amplifier
Figure 11. Comparator with Hysteresis
Figure 12. Function Generator
Figure 13. Multiple Feedback Bandpass Filter
5
Version: B15
TS358
SOP-8 Mechanical Drawing
DIM
A
B
C
D
F
G
K
M
P
R
SOP-8 DIMENSION
MILLIMETERS
INCHES
MIN
MAX
MIN
MAX.
4.80
5.00
0.189
0.196
3.80
4.00
0.150
0.157
1.35
1.75
0.054
0.068
0.35
0.49
0.014
0.019
0.40
1.25
0.016
0.049
1.27BSC
0.05BSC
0.10
0.25
0.004
0.009
0º
7º
0º
7º
5.80
6.20
0.229
0.244
0.25
0.50
0.010
0.019
Marking Diagram
Y = Year Code
M = Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
S =May T =Jun U =Jul
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code
6
Version: B15
TS358
DIP-8 Mechanical Drawing
DIM
A
B
C
D
G
J
K
L
M
DIP-8 DIMENSION
MILLIMETERS
INCHES
MIN
MAX
MIN
MAX
9.07
9.32
0.357
0.367
6.22
6.48
0.245
0.255
3.18
4.45
0.125
0.135
0.35
0.55
0.019
0.020
2.54 (typ)
0.10 (typ)
0.29
0.31
0.011
0.012
3.25
3.35
0.128
0.132
7.75
8.00
0.305
0.315
o
o
10
10
Marking Diagram
Y = Year Code
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code
7
Version: B15
TS358
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to any
intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for
such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale
and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability,
or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers
using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for
any damages resulting from such improper use or sale.
8
Version: B15
很抱歉,暂时无法提供与“TS358CS RLG”相匹配的价格&库存,您可以联系我们找货
