PL9212
PL9212
    INRCORE
    非标准
    固定电感器 Nonstandard 22µH ±20% 2.6A 67mΩ
PL9212 数据手册
SMT POWER INDUCTORS Shielded Drum Core - PL92XX Series Ruggedized Height: 0.201 inches (5.1mm) Max Footprint: 0.413 inches x 0.413 inches (10.5mm x 10.5mm) Max Inductance Range: 0.95µH to 890µH Current Rating: up to 8.7A Moisture Sensitivity Level: 1 Electrical Specifications @ 25 °C — Operating Temperature - 5 5 °C to +130 °C Part Numbers PL9201 PL9202 PL9203 PL9204 PL9205 PL9206 PL9207 PL9208 PL9209 PL9210 PL9211 PL9212 PL9213 PL9214 PL9215 PL9216 PL9217 PL9218 PL9219 PL9220 PL9221 PL9222 PL9223 PL9224 PL9225 PL9226 PL9227 PL9228 PL9229 PL9230 PL9231 PL9232 Inductance @Irated (µH TYP) 0.95 1.55 2.32 3.24 4.26 5.64 7.17 9.3 10.8 13.4 17.5 19.4 24.2 30.6 38.5 46.1 53.2 63.1 76.6 88 112 135 132 198 237 296 355 445 495 610 702 890 Irated 2 (A) 8.7 7.4 6.6 5.5 5.1 4.4 4.2 3.6 3.3 3.0 2.7 2.6 2.2 2.1 1.8 1.7 1.6 1.45 1.36 1.29 1.07 1.02 0.87 0.82 0.78 0.66 0.58 0.54 0.53 0.49 0.43 0.40 Inductance@0ADC DCR (mΩ) TYP 4.0 5.5 6.9 10.0 11.7 15.6 17.5 23 27 34 40 43 61 69 93 104 119 147 165 184 264 294 328 450 502 691 916 1037 1095 1220 1656 1885 MAX 5.7 7.9 10.0 14.5 16.5 22 25 35 37 47 58 67 79 94 126 140 157 202 232 270 316 456 497 681 775 955 1087 1403 1623 1824 2355 2850 (µH) 1.0* 1.6* 2.7* 3.6* 4.5* 6.0* 7.6* 10 12 15 18 22 27 33 39 47 56 68.0 82.0 100.0 120.0 150.0 180.0 220.0 270 330 390 470 560 680 820 1000 Saturation 3Current (A) @25°C 11 8.8 7.3 6.3 5.5 4.9 4.4 4.0 3.7 3.4 2.9 2.8 2.4 2.2 2.0 1.8 1.7 1.6 1.4 1.3 1.2 1.05 0.96 0.86 0.79 0.71 0.66 0.59 0.54 0.49 0.45 0.41 Heating 4 Current (A) 8.7 7.4 6.6 5.5 5.1 4.4 4.2 3.6 3.3 3.0 2.7 2.6 2.2 2.1 1.8 1.7 1.6 1.45 1.36 1.29 1.07 1.02 0.87 0.82 0.78 0.66 0.58 0.54 0.53 0.50 0.43 0.40 *Inductance at 0ADC tolerance on indicated part numbers is ±30%; tolerance is ±20% on all other parts. Optional Tape & Reel packaging can be ordered by adding a "T" suffix to the part number (i.e. PL9201 becomes PL9201T). Notes from Tables 1. Temperature of the component (ambient plus temperature rise) must be within specified operating temperature range. 2. The rated current as listed is either the saturation current or the heating current depending on which value is lower. 3. The saturation current is the current which causes the inductance to drop to 75% of its initial inductance at zero bias. This current is determined by placing the component at room ambient (25°C), and applying a short duration pulse current (to eliminate self-heating effects) to the component. 1 www.inrcore.com 4. The heating current is the DC current, which causes the temperature of the part to increase by approximately 40°C. This current is determined by extending the terminals of the component with 30mm length 28 gauge buss wires and applying the current to the device for 30 minutes. The temperature is measured by placing the thermo-couple between the winding and the shield. 5. In high volt*time applications, additional heating in the component can occur due to core losses in the inductor which may necessitate derating the current in order to limit the temperature rise of the compo-nent. In order to determine the approximate total loss (or temperature rise) for a given application, both copper losses and core losses should be taken into account. M122.E(07/20) SMT POWER INDUCTORS Shielded Drum Core - PL92XX Series Ruggedized Electrical Schematic Mechanical TAPE & REEL LAYOUT Schematic 1 1 .161 Ø4,10 2 .421 10,70 3 Percentage of the intitial inductance� .209 5,30 1 1 4 PL92XX 3 PL92XX 3 4 PL92XX Date Code Countr y of Or igin Date Code Countr y of Or igin Date Code Countr y of Or igin 2 2 2 .421 10,70 .630 16,00 .945 ± .012 24.00 ± 0,30 4 USER DIRECTION OF FEED Inductance vs. Current Characteristics 120% 100% 80% 60% 40% 20% 0% 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 Normalized Isat 2 www.inrcore.com M122.E(07/20) SMT POWER INDUCTORS Shielded Drum Core - PL92XX Series Ruggedized For More Information Global Sales Representatives and Lo cations: http://www.inrcore.com iNRCORE,LLC 311 Sinclair Road Bristol, PA 19007-6812 U.S.A Tel: + 1.215.781.6400 Fax: +1.215.7816430 Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved. 3 www.inrcore.com M122.E(07/20)
PL9212 价格&库存
很抱歉,暂时无法提供与“PL9212”相匹配的价格&库存,您可以联系我们找货
