MMBT3904L
Taiwan Semiconductor
Small Signal Product
300mW, NPN Small Signal Transistor
FEATURES
- Epitaxial planar die construction
- Surface device type mounting
- Moisture sensitivity level 1
- Matte Tin (Sn) lead finish with Nickel (Ni) underplate
- Pb free version and RoHS compliant
- Packing code with suffix "G" means
green compound (halogen-free)
SOT-23
MECHANICAL DATA
- Case: SOT- 23, molded plastic
- Terminal: Matte tin plated, lead free,
solderable per MIL-STD-202, Method 208 guaranteed
- High temperature soldering guaranteed: 260oC/10s
- Weight: 8 mg (approximately)
- Marking Code: 1E.
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
PD
300
mW
Collector-Base Voltage
VCBO
60
V
Collector-Emitter Voltage
VCEO
40
V
Emitter-Base Voltage
VEBO
6
V
IC
200
mA
TJ , TSTG
-55 to +150
Power Dissipation
Collector Current
Junction and Storage Temperature Range
o
C
Notes: Valid provided that electrodes are kept at ambient temperature
PARAMETER
SYMBOL
MIN
MAX
UNIT
Collector-Base Breakdown Voltage
IC = 10 μA
IE = 0
V(BR)CBO
60
V
Collector-Emitter Breakdown Voltage
IC = 1 mA
IB = 0
V(BR)CEO
40
V
Emitter-Base Breakdown Voltage
IE = 10 μA
IC = 0
V(BR)EBO
6
V
Collector Cut-off Current
VCB = 60 V
IE = 0
ICBO
0.1
μA
VCE = 30 V
VBE(OFF) = 3 V
ICEO
50
nA
Emitter Cut-off Current
VEB = 5 V
IC = 0
IEBO
0.1
μA
100
400
60
30
0.3
V
DC Current Gain
Collector-Emitter Saturation Voltage
VCE = 1 V
IC = 10 mA
VCE = 1 V
IC = 50 mA
VCE = 1 V
IC = 100 mA
IC = 50 mA
IB = 5 mA
VCE(sat)
hFE
IC = 50 mA
IB = 5 mA
VBE(sat)
0.95
V
Transition frequency
VCE = 20 V
IC = 10 mA
f= 100MHz
fT
250
MHz
Delay time
VCC = 3 V
VBE = 0.5 V
IC = 10 mA
td
35
ns
IB1 = 1.0 mA
tr
35
ns
IC = 10 mA
ts
200
ns
tf
50
ns
Base-Emitter Saturation Voltage
Rise time
Storage time
VCC = 3 V
Fall time
IB1 = IB2 = 1.0 mA
Document Number: DS_S1501029
Version: A15
MMBT3904L
RATINGS AND CHARACTERISTICS CURVES
(TA=25°C unless otherwise noted)
Fig.1 Typical Pulsed Current Gain
vs. Collector Current
Fig. 2 Collector-Emitter Saturation Voltage
0.20
VCE = 5V
125 °C
400
300
V CESAT- Collector-Emitter Voltage (V)
hFE - Typical Pulsed Current Gain
500
25 °C
200
100
- 40 °C
1.0
10.0
100.0
β = 10
0.15
125 °C
0.10
25 °C
0.05
- 40 °C
0.00
IC - Collector Current (mA)
100
Fig. 3 Base-Emitter Saturation Voltage
Fig. 4 Base-Emitter On Voltage
1.1
1
1
V BE(ON) - Base-Emitter On Voltage (V)
VBESAT - Base-Emitter Voltage (V)
10
β = 10
0.9
0.8
0.7
- 40 °C
0.6
25 °C
0.5
0.4
125 °C
0.3
0.1
1
10
100
VCE= 5V
0.8
- 40 °C
25 °C
0.6
0.4
125 °C
0.2
0.1
1
10
100
Fig. 5 Collector-Cutoff Current
vs. Ambient Temperature
Fig. 6 Capacitance vs.
Reverse Bias Voltage
1000
10
f = 1.0 MHz
VCB= 30V
Capacitance (pF)
ICBO-Collector Current (nA)
100
10
1
C
ibo
Cobo
0.1
0.01
25
50
75
100
125
TA - Ambient Temperature (OC)
150
1
0.1
1
10
100
Reverse Bias Voltage (V)
Version: A15
MMBT3904L
ORDER INFORMATION (EXAMPLE)
MMBT3904L RFG
Green compound code
Packing code
Part no.
PACKAGE OUTLINE DIMENSIONS
SOT-23
DIM.
Unit(mm)
Unit(inch)
Min
Max
Min
Max
A
2.70
3.10
0.106
0.122
B
1.10
1.50
0.043
0.059
C
0.30
0.51
0.012
0.020
D
1.78
2.04
0.070
0.080
E
2.10
2.64
0.083
0.104
F
0.89
1.30
0.035
0.051
G
0.55 REF
0.022 REF
H
0.10 REF
0.004 REF
Unit (mm)
Unit (inch)
TYP
TYP
Z
2.90
0.114
X
0.80
0.031
Y
0.90
0.035
C
2.00
0.079
E
1.35
0.053
SUGGEST PAD LAYOUT
DIM
Version: A15
MMBT3904L
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: A15
很抱歉,暂时无法提供与“MMBT3904L RFG”相匹配的价格&库存,您可以联系我们找货
