TIP112
TIP112
    L3HARRIS
    TO-220-3
    TRANSISTOR
TIP112 数据手册
TIP110 / TIP111 / TIP112 NPN Epitaxial Silicon Darlington Transistor Equivalent Circuit Features C • Monolithic Construction with Built-in Base-Emitter Shunt Resistors • Complementary to TIP115 / TIP116 / TIP117 • High DC Current Gain: hFE = 1000 @ VCE = 4 V, IC = 1 A (Minimum) • Low Collector-Emitter Saturation Voltage • Industrial Use B 1 TO-220 R1 1.Base 2.Collector 3.Emitter R2 R1 ≅ 10kΩ R2 ≅ 0.6kΩ E Ordering Information Part Number Top Mark Package Packing Method TIP110 TIP110 TO-220 3L (Single Gauge) Bulk TIP110TU TIP110 TO-220 3L (Single Gauge) Rail TIP111TU TIP111 TO-220 3L (Single Gauge) Rail TIP112 TIP112 TO-220 3L (Single Gauge) Bulk TIP112TU TIP112 TO-220 3L (Single Gauge) Rail Absolute Maximum Ratings Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Values are at TC = 25°C unless otherwise noted. Symbol Parameter Value TIP110 VCBO VCEO Collector-Base Voltage Collector-Emitter Voltage Unit 60 TIP111 80 TIP112 100 TIP110 60 TIP111 80 TIP112 100 VEBO Emitter-Base Voltage 5 V V V IC Collector Current (DC) 2 A ICP Collector Current (Pulse) 4 A IB Base Current (DC) 50 mA TJ Junction Temperature 150 °C -65 to 150 °C TSTG Storage Temperature Range © 2001 Fairchild Semiconductor Corporation TIP110 / TIP111 / TIP112 Rev. 1.1.0 www.fairchildsemi.com TIP110 / TIP111 / TIP112 — NPN Epitaxial Silicon Darlington Transistor November 2014 Values are at TC = 25°C unless otherwise noted. Symbol PC Parameter Value Collector Dissipation (TA = 25°C) 2 Collector Dissipation (TC = 25°C) 50 Unit W Electrical Characteristics(1) Values are at TC = 25°C unless otherwise noted. Symbol Parameter Conditions TIP110 VCEO(sus) Collector-Emitter Sustaining Voltage ICBO Collector Cut-Off Current Collector Cut-Off Current IEBO Emitter Cut-Off Current hFE DC Current Gain Max. Unit 60 TIP111 IC = 30 mA, IB = 0 TIP112 ICEO Min. 80 V 100 TIP110 VCE = 30 V, IB = 0 2 TIP111 VCE = 40 V, IB = 0 2 TIP112 VCE = 50 V, IB = 0 2 TIP110 VCB = 60 V, IE = 0 1 TIP111 VCB = 80 V, IE = 0 1 TIP112 VCB = 100 V, IE = 0 1 VEB = 5 V, IC = 0 2 mA IC = 2 A, IB = 8 mA 2.5 V VCE = 4 V, IC = 1 A 1000 VCE = 4 V, IC = 2 A 500 mA mA VCE(sat) Collector-Emitter Saturation Voltage VBE(on) Base-Emitter On Voltage VCE = 4 V, IC = 2 A 2.8 V Output Capacitance VCB = 10 V, IE = 0, f = 0.1 MHz 100 pF Cob Note: 1. Pulse test: pw ≤ 300 μs, duty cycle ≤ 2%. © 2001 Fairchild Semiconductor Corporation TIP110 / TIP111 / TIP112 Rev. 1.1.0 www.fairchildsemi.com 2 TIP110 / TIP111 / TIP112 — NPN Epitaxial Silicon Darlington Transistor Thermal Characteristics 10000 IB = 500μA 1.8 IB = 450μA 1.6 IB = 400μA μA 350 I B= 00μA IB = 3 VCE = 4V 0μA I B = 25 hFE, DC CURRENT GAIN IC[A], COLLECTOR CURRENT 2.0 1.4 1.2 IB = 200μA 1.0 0.8 0.6 IB = 150μA 0.4 1000 100 0.2 10 0.01 0.0 0 1 2 3 4 5 0.1 VCE[V], COLLECTOR-EMITTER VOLTAGE Figure 1. Static Characteristic 10 Figure 2. DC Current Gain 1000 100 IC = 500 IB f = 0.1 MHz Cob[pF], CAPACITANCE VBE(sat), VCE(sat)[V], SATURATION VOLTAGE 1 IC[A], COLLECTOR CURRENT 10 VBE(sat) 1 VCE(sat) 0.1 0.01 0.1 1 100 10 1 0.01 10 IC[A], COLLECTOR CURRENT 0.1 1 10 100 VCB[V], COLLECTOR-BASE VOLTAGE Figure 3. Base-Emitter Saturation Voltage and Collector-Emitter Saturation Voltage Figure 4. Collector Output Capacitance 80 10 PC[W], POWER DISSIPATION 1mS 5mS IC[A], COLLECTOR CURRENT 70 DC 1 TIP 110 TIP 111 TIP 112 0.1 1 10 50 40 30 20 10 0 0 100 VCE[V], COLLECTOR-EMITTER VOLTAGE 25 50 75 100 125 150 175 o TC[ C], CASE TEMPERATURE Figure 5. Safe Operating Area © 2001 Fairchild Semiconductor Corporation TIP110 / TIP111 / TIP112 Rev. 1.1.0 60 Figure 6. Power Derating www.fairchildsemi.com 3 TIP110 / TIP111 / TIP112 — NPN Epitaxial Silicon Darlington Transistor Typical Performance Characteristics TIP110 / TIP111 / TIP112 — NPN Epitaxial Silicon Darlington Transistor Physical Dimensions Figure 7. TO-220, MOLDED, 3LEAD, JEDEC VARIATION AB © 2001 Fairchild Semiconductor Corporation TIP110 / TIP111 / TIP112 Rev. 1.1.0 www.fairchildsemi.com 4 TRADEMARKS The following includes registered and unregistered trademarks and service marks, owned by Fairchild Semiconductor and/or its global subsidiaries, and is not intended to be an exhaustive list of all such trademarks. F-PFS¥ FRFET® SM Global Power Resource GreenBridge¥ Green FPS¥ Green FPS¥ e-Series¥ Gmax¥ GTO¥ IntelliMAX¥ ISOPLANAR¥ Making Small Speakers Sound Louder and Better™ MegaBuck¥ MICROCOUPLER¥ MicroFET¥ MicroPak¥ MicroPak2¥ MillerDrive¥ MotionMax¥ MotionGrid® MTi® MTx® MVN® mWSaver® OptoHiT¥ OPTOLOGIC® AccuPower¥ Awinda® AX-CAP®* BitSiC¥ Build it Now¥ CorePLUS¥ CorePOWER¥ CROSSVOLT¥ CTL¥ Current Transfer Logic¥ DEUXPEED® Dual Cool™ EcoSPARK® EfficientMax¥ ESBC¥ ® Fairchild® Fairchild Semiconductor® FACT Quiet Series¥ FACT® FAST® FastvCore¥ FETBench¥ FPS¥ OPTOPLANAR® ® PowerTrench® PowerXS™ Programmable Active Droop¥ QFET® QS¥ Quiet Series¥ RapidConfigure¥ ¥ Saving our world, 1mW/W/kW at a time™ SignalWise¥ SmartMax¥ SMART START¥ Solutions for Your Success¥ SPM® STEALTH¥ SuperFET® SuperSOT¥-3 SuperSOT¥-6 SuperSOT¥-8 SupreMOS® SyncFET¥ Sync-Lock™ ®* ® TinyBoost TinyBuck® TinyCalc¥ TinyLogic® TINYOPTO¥ TinyPower¥ TinyPWM¥ TinyWire¥ TranSiC¥ TriFault Detect¥ TRUECURRENT®* μSerDes¥ UHC® Ultra FRFET¥ UniFET¥ VCX¥ VisualMax¥ VoltagePlus¥ XS™ Xsens™ ௝❺™ * Trademarks of System General Corporation, used under license by Fairchild Semiconductor. DISCLAIMER FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION, OR DESIGN. TO OBTAIN THE LATEST, MOST UP-TO-DATE DATASHEET AND PRODUCT INFORMATION, VISIT OUR WEBSITE AT HTTP://WWW.FAIRCHILDSEMI.COM. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS. THESE SPECIFICATIONS DO NOT EXPAND THE TERMS OF FAIRCHILD’S WORLDWIDE TERMS AND CONDITIONS, SPECIFICALLY THE WARRANTY THEREIN, WHICH COVERS THESE PRODUCTS. LIFE SUPPORT POLICY FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems which, (a) are 2. A critical component in any component of a life support, device, or system whose failure to perform can be reasonably expected to intended for surgical implant into the body or (b) support or sustain life, and (c) whose failure to perform when properly used in cause the failure of the life support device or system, or to affect its accordance with instructions for use provided in the labeling, can be safety or effectiveness. reasonably expected to result in a significant injury of the user. ANTI-COUNTERFEITING POLICY Fairchild Semiconductor Corporation's Anti-Counterfeiting Policy. Fairchild's Anti-Counterfeiting Policy is also stated on our external website, www.fairchildsemi.com, under Sales Support. Counterfeiting of semiconductor parts is a growing problem in the industry. All manufacturers of semiconductor products are experiencing counterfeiting of their parts. Customers who inadvertently purchase counterfeit parts experience many problems such as loss of brand reputation, substandard performance, failed applications, and increased cost of production and manufacturing delays. Fairchild is taking strong measures to protect ourselves and our customers from the proliferation of counterfeit parts. Fairchild strongly encourages customers to purchase Fairchild parts either directly from Fairchild or from Authorized Fairchild Distributors who are listed by country on our web page cited above. Products customers buy either from Fairchild directly or from Authorized Fairchild Distributors are genuine parts, have full traceability, meet Fairchild's quality standards for handling and storage and provide access to Fairchild's full range of up-to-date technical and product information. Fairchild and our Authorized Distributors will stand behind all warranties and will appropriately address any warranty issues that may arise. Fairchild will not provide any warranty coverage or other assistance for parts bought from Unauthorized Sources. Fairchild is committed to combat this global problem and encourage our customers to do their part in stopping this practice by buying direct or from authorized distributors. PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Advance Information Formative / In Design Preliminary First Production No Identification Needed Full Production Obsolete Not In Production Definition Datasheet contains the design specifications for product development. Specifications may change in any manner without notice. Datasheet contains preliminary data; supplementary data will be published at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve design. Datasheet contains final specifications. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve the design. Datasheet contains specifications on a product that is discontinued by Fairchild Semiconductor. The datasheet is for reference information only. Rev. I72 © Fairchild Semiconductor Corporation www.fairchildsemi.com
TIP112 价格&库存
很抱歉,暂时无法提供与“TIP112”相匹配的价格&库存,您可以联系我们找货
