SICR10650CT
SICRB10650CT
SICRD10650CT
SICRF10650CT
Technical Data
Data Sheet N1871, Draft 1
SICR10650CT / SICRB10650CT / SICRD10650CT / SICRF10650CT
650V SIC POWER SCHOTTKY RECTIFIER
Description
Features
SICR10650CT/ SICRB10650CT/ SICRD10650CT/
SICRF10650CT are all common cathode SiC Schottky
rectifiers packaged in TO-220AB, D2PAK, DPAK and
ITO-220AB case.The device is a high voltage Schottky
rectifier pair that has very low total conduction losses
and very stable switching characteristics over
temperature extremes. The SICR10650CT/
SICRB10650CT/ SICRD10650CT/ SICRF10650CT are
ideal for energy sensitive, high frequency applications
in challenging environments.
Applications
175°C TJ operation
Center tap configuration
Ultra-low switching loss
Switching speeds independent of operating
temperature
Low total conduction losses
High forward surge current capability
High package isolation voltage
Guard ring for enhanced ruggedness and long term
reliability
Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional electrical and life testing can be performed
upon request
Alternative energy inverters
Power Factor Correction (PFC)
Free-Wheeling diodes
Switching supply output rectification
Reverse polarity protection
SICR10650CT
SICRB10650CT
SICRD10650CT
SICRF10650CT
TO-220AB
D2PAK
DPAK
ITO-220AB
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
SICR10650CT
SICRB10650CT
SICRD10650CT
SICRF10650CT
Technical Data
Maximum Ratings:
Characteristics
Symbol
Condition
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRRM
VRWM
VR
Average Rectified Forward Current
IF (AV)
Peak One Cycle Non-Repetitive Surge
Current(Per Leg)
50% duty cycle @Tc=105°C,
rectangular wave form
IFSM
8.3ms, Half Sine pulse
Max.
Units
650
V
5(Per Leg)
10(Per Device)
A
60
A
Electrical Characteristics:
Characteristics
Forward Voltage Drop(Per Leg)*
Reverse Current at DC condition
(Per Leg)*
Reverse Current (Per Leg)*
Junction Capacitance
(Per Leg)
Series Inductance
(Per Leg)
Voltage Rate of Change
RSM Isolation Voltage
(t = 1.0 second, R. H. < =30%,
TA = 25 C)
Symbol
Condition
Typ.
Max.
Units
VF1
@ 5A, Pulse, TJ = 25 C
1.5
1.7
V
VF2
@ 5A, Pulse, TJ = 150 C
@VR = rated VR
TJ = 25 C
@VR = rated VR
TJ = 125 C
@VR = 5V, TC = 25 C
fSIG = 1MHz
Measured lead to lead 5 mm from
package body
Clip mounting, the epoxy body away
from the heatsink edge by more than
0.110" along the lead direction.
Clip mounting, the epoxy body is inside
the heatsink.
Screw mounting, the epoxy body is
inside the heatsink.
1.98
2.5
V
5
60
A
70
250
A
TBD
pF
TBD
nH
10,000
V/s
4500
3500
1500
IR1
IR2
CT
LS
dv/dt
VISO
* Pulse width < 300 µs, duty cycle < 2%
V
Thermal-Mechanical Specifications:
Characteristics
Junction Temperature
Storage Temperature
Maximum Thermal Resistance Junction
to Case
Symbol
TJ
Tstg
RJC
SICR
10650CT
2.4
SICRB
SICRD
10650CT
10650CT
-55 to +175
-55 to +175
2.4
2.4
SICRF
10650CT
Units
4.2
C/W
C
C
SICR10650CT
SICRB10650CT
SICRD10650CT
SICRF10650CT
Technical Data
Ordering Information
Tube Specification(TO-220AB/ITO-220AB)
Device
Package
Weight
Shipping
SICR10650CT
TO-220AB
1.8g
50pcs / tube
SICRB10650CT
D²PAK
1.85g
800pcs / reel
SICRD10650CT
DPAK
0.39g
2500pcs / reel
SICRF10650CT
ITO-220AB
1.8g
50pcs / tube
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
Marking Diagram
Where XXXXX is YYWWL
SICR
B/D/F
10
650
CT
SSG
YY
WW
L
= Device Type
= Package type
= Forward Current (10A)
= Reverse Voltage (650V)
= Configuration
= SSG
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
Carrier Tape Specification DPAK
SYMBOL
Millimeters
Min.
Max.
A
6.80
7.00
B
10.40
10.60
C
2.60
2.80
d
Φ1.45
Φ1.65
E
1.65
1.85
F
7.40
7.60
P0
3.90
4.10
P
7.90
8.10
P1
1.90
2.10
W
15.90
16.30
SICR10650CT
SICRB10650CT
SICRD10650CT
SICRF10650CT
Technical Data
Carrier Tape Specification D2PAK
SYMBOL
Millimeters
Min.
Max.
A
10.70
10.90
B
16.03
16.23
C
5.11
5.31
d
1.45
1.65
E
1.65
1.85
F
11.40
11.60
P0
3.90
4.10
P
15.90
16.10
P1
1.90
2.10
W
23.90
24.30
Mechanical Dimensions TO-220AB
Symbol
A
A1
A2
b
b1
c
D
D1
E
e
e1
H1
L
L1
ΦP
Q
Θ1
Θ2
Θ3
Dimensions in
millimeters
Min
Typical
4.42
4.57
1.17
1.27
2.52
2.69
0.71
0.81
1.17
1.27
0.31
0.38
14.94
15.24
8.85
9.00
10.01
10.16
2.54
4.98
5.06
6.04
6.24
12.7
13.56
3.56
3.5
3.74
3.84
2.54
2.74
7°
3°
4°
Max
4.72
1.37
2.89
0.96
1.37
0.61
15.54
9.15
10.31
5.18
6.44
13.80
3.96
4.04
2.94
SICR10650CT
SICRB10650CT
SICRD10650CT
SICRF10650CT
Technical Data
Mechanical Dimensions DPAK
SYMBOL
A
A1
b
c
D
D1
D2
E
e
L
L1
L2
L3
L4
Φ
Θ
h
V
Millimeters
Inches
Min.
Max.
2.20
2.40
0.00
0.127
0.66
0.86
0.46
0.60
6.50
6.70
5.13
5.46
4.83 REF.
6.00
6.20
2.186
2.386
9.70
10.40
2.90 REF.
1.40
1.70
1.60 REF.
0.60
1.00
1.10
1.30
0°
8°
0.00
0.30
5.35 REF.
Min.
Max.
0.087
0.094
0.000
0.005
0.026
0.034
0.018
0.024
0.256
0.264
0.202
0.215
0.190 REF.
0.236
0.244
0.086
0.094
0.381
0.409
0.144 REF.
0.055
0.067
0.063 REF.
0.024
0.039
0.043
0.051
0°
8°
0.000
0.012
0.211 REF.
Mechanical Dimensions D2PAK
Symbol
A
A1
A2
b
b1
c
c1
D
D1
E
E1
E2
e
H
L
L1
L2
L3
e
e1
e2
e3
Dimensions in millimeters
Min.
4.55
0.71
0.36
1.17
8.55
6.40
10.01
7.6
9.98
14.6
2.00
1.17
Typical
4.70
0.10
2.69
0.81
1.27
0.38
1.27
8.70
Max.
4.85
0.25
2.89
0.96
10.16
10.31
10.08
2.54
15.1
2.30
1.27
10.18
0.25BSC
5°
4°
4°
0.61
1.37
8.85
15.6
2.70
1.40
2.20
8°
SICR10650CT
SICRB10650CT
SICRD10650CT
SICRF10650CT
Technical Data
Mechanical Dimensions ITO-220AB
SYMBOL
A
A1
A2
A3
b
b1
b2
b3
b4
c
D
E
e
e1
H1
L
L1
L2
L3
ΦP1(上口)
ΦP2(下口)
Q
Θ1
Θ2
Θ3
Θ4
Θ5
MIN.
4.30
1.10
2.50
2.50
0.50
1.10
1.50
1.20
1.60
0.50
14.80
9.96
6.50
12.70
1.60
0.80
0.60
3.30
2.99
2.50
Millimeters
TYP.
4.50
1.30
3.00
2.70
0.60
1.20
1.60
1.30
1.70
0.60
15.00
10.16
2.55
5.10
6.70
13.20
1.80
1.00
0.80
3.50
3.19
2.70
5°
4°
10°
5°
5°
MAX.
4.70
1.50
3.20
2.90
0.75
1.35
1.75
1.45
1.85
0.75
15.20
10.36
6.90
13.70
2.00
1.20
1.00
3.70
3.39
2.90
SICR10650CT
SICRB10650CT
SICRD10650CT
SICRF10650CT
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales
department for the latest version of the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or
any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd
assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information,
products or circuits described in the datasheets.
4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any
secondary damage resulting from use at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics
(Nanjing) Co., Ltd.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
- Sangdest Microelectronics (Nanjing) Co., Ltd.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“SICRF10650CT”相匹配的价格&库存,您可以联系我们找货
