CSD08060–Silicon Carbide Schottky Diode
Zero R
ecovery®
VRRM = 600 V
Rectifier
IF(AVG) = 8 A
Qc
Features
= 22 nC
Package
600-Volt Schottky Rectifier
Zero Reverse Recovery Current
Zero Forward Recovery Voltage
High-Frequency Operation
Temperature-Independent Switching Behavior
Extremely Fast Switching
Positive Temperature Coefficient on VF
TO-220-2
Benefits
Replace Bipolar with Unipolar Rectifiers
Essentially No Switching Losses
Higher Efficiency
Reduction of Heat Sink Requirements
Parallel Devices Without Thermal Runaway
PIN 1
CASE
PIN 2
Applications
Switch Mode Power Supplies
Power Factor Correction
- Typical PFC Pout : 800W-1600W
Motor Drives
- Typical Power : 3HP-4HP
Part Number
Package
Marking
CSD08060A
TO-220-2
CSD08060
Maximum Ratings
B
D08060 Rev.
Datasheet: CS
Symbol
Parameter
Value
Unit
Test Conditions
VRRM
Repetitive Peak Reverse Voltage
600
V
VRSM
Surge Peak Reverse Voltage
600
V
VDC
DC Blocking Voltage
600
V
IF(AVG)
Average Forward Current
8
12.5
A
TC=150˚C, DC
TC=125˚C, DC
IF(PEAK)
Peak Forward Current
17.5
A
TC=125˚C, TREP 1KHz
DC
10
10.00
VR Reverse Voltage (V)
10% Duty
Figure 3. Current Derating
Figure 4. Capacitance vs. Reverse Voltage
CSD08060
1.E+01
Zth (°C/W)
1.E+00
1.E-01
1.E-02
1.E-03
1.E-07
1.E-06
1.E-05
1.E-04
1.E-03
Time (s)
Figure 5. Transient Thermal Impedance
CSD08060 Rev. B
1.E-02
1.E-01
1.E+00
Typical Performance
CSD08060 Power Derating
110110
100100
80 80
70 70
60 60
Power
Power Dissipation (W)
90 90
50 50
40 40
30 30
20 20
10 10
0 0
25
50
25
75
50
75
100
125
100
Case Temperature
150
125
175
150
175
TC Case Temperature (°C)
Figure 6. Power Derating
Package Dimensions
POS
Package TO-220-2
A
F
J
C
B
D
X
S
E
Y
1 2
G
T
Z
U
H
V
L
M
W
N
CASE
PIN 2
Max
.381
.410
9.677
10.414
.235
.255
5.969
6.477
C
.100
.120
2.540
3.048
FA
.223
Inc hes
.590
M in
M ax
.395.143 .410
GB
.235
1.105 .255
HC
D
J
E
L
F
MG
.102.500 .112
2.591
.550
.337
.337
8.560
R 0.197
.590
.610
14.986
.025
.036
.149
.153
3.785
1.127.045 1.147 .055
28.626
NH
J
P
L
Q
M
SN
.530.195 .550
R 0.010
.165
.028
.036
.048
.045
.055
.195 3° .205
TP
.170 3°
.180
4.318
6°
UQ
S
V
T
WU
.048 3° .054
1.219
6°
3°
.110
3°
.025
3°
1.371
3°
5°
2.388
5°
.356
5°
5.5°
2.54
3°
2.794
.356
.410
3°
.150
10.033
.533
9.779
5°
3.302
10.414
XV
PIN 1
Min
A
EP OS
Q
Millimeters
Max
B
D
P
Inches
Min
YW
X
z
Y
3°
5°
.094
3°
5°
3°.014 5°
.100 3° .110
.014.385 .021
3°
5°
.130
.395
.410
.337
5.664
M illim eters
.615
14.986
M in
M ax
.153
3.632
10.033 10.414
5.969
1.147
6.477
28.067
8.560
15.621
3.886
29.134
2.845
12.700
13.970
8.560
R 0.197
15.494
.635
.914
3.886
1.143
1.397
29.134
13.462 13.970
.205
4.953
R 0.254
.185
4.191
.711
.914
.054
1.219
1.143
1.397
6°
3°
4.953
5.207
4.572
3°
5.207
4.699
1.372
6°
6°
6°
2.794
.635
5.5°
10.414
3.810
NOTE:Z
.130
.150
3.302
3.810
1. Dimension L, M, W apply for Solder Dip
Finish
CSD08060 Rev. B
Recommended Solder Pad Layout
TO-220-2
Part Number
Package
Marking
CSD08060A
TO-220-2
CSD08060
Diode Model
Diode Model CSD06060
VfTT== VVTT+If*R
Vf
+ If*RT T
-3
V
0.93+(Tj*(-.93*10-3
VT=
T= 0.975 + (Tj * -1.0*10 -3)
RT= 0.058+(Tj*(.57*10-3 ))
RT= 0.09 + (Tj * 0.51*10 )
Note: Tj = Diode Junction Temperature In Degrees Celcius
VT
RT
“The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the
maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive
2002/95/EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as amended through April 21, 2006. This part number was
released previously with Sn/Pb solder plating as a standard industry finish. For more information please contact power_sales@cree.com “
This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body
nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited
to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical
equipment, aircraft navigation or communication or control systems, air traffic control systems, or weapons systems.
Copyright © 2006-2008 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree,
the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc.
CSD08060 Rev. B
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
Fax: +1.919.313.5451
www.cree.com/power
很抱歉,暂时无法提供与“CSD08060A”相匹配的价格&库存,您可以联系我们找货
