MBRS1545CT-Y – MBRS15200CT-Y
Taiwan Semiconductor
15A, 45V - 200V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for overvoltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
15
A
VRRM
45 - 200
V
IFSM
150
A
TJ MAX
150
°C
2
Package
TO-263AB (D PAK)
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
2
Case: TO-263AB (D PAK)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: As marked
Weight: 1.37g (approximately)
2
TO-263AB (D PAK)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
Repetitive peak reverse voltage
Reverse voltage, total rms value
Forward current
Surge peak forward current, 8.3ms single
half sine wave superimposed on rated load
(1)
Peak repetitive reverse surge current
Peak repetitive forward current
(Rated VR, Square wave, 20KHz)
Critical rate of rise of off-state voltage
MBRS MBRS MBRS MBRS MBRS
1560
15100 15150 15200 UNIT
SYMBOL 1545
CT-Y
CT-Y
CT-Y
CT-Y
CT-Y
MBRS
MBRS
MBRS
MBRS
MBRS
1545CT 1560CT 15100CT 15150CT 15200CT
VRRM
45
60
100
150
200
V
VR(RMS)
31
42
70
105
140
V
IF
15
A
IFSM
150
A
IRRM
1
0.5
A
IFRM
15
A
dv/dt
10,000
V/μs
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Notes:
1. tp = 2.0μs, 1.0KHz
1
Version: D2103
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
50
°C/W
Junction-to-case thermal resistance
RӨJC
2
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MBRS1545CT-Y
MBRS1560CT-Y
MBRS15100CT-Y
MBRS15150CT-Y
MBRS15200CT-Y
MBRS1545CT-Y
IF = 7.5A, TJ = 25°C
MBRS1560CT-Y
Forward voltage per
(1)
diode
MBRS15100CT-Y
MBRS15150CT-Y
MBRS15200CT-Y
MBRS1545CT-Y
IF = 15.0A, TJ = 25°C
VF
MBRS1560CT-Y
MBRS15100CT-Y
MBRS15150CT-Y
MBRS15200CT-Y
MBRS1545CT-Y
IF = 7.5A, TJ = 125°C
MBRS1560CT-Y
IF = 15.0A, TJ = 125°C
Reverse current @
(2)
rated VR per diode
MBRS15100CT-Y
MBRS15150CT-Y
MBRS15200CT-Y
MBRS1545CT-Y
MBRS1560CT-Y
MBRS15100CT-Y TJ = 25°C
MBRS15150CT-Y
MBRS15200CT-Y
MBRS1545CT-Y
IR
MBRS1560CT-Y
T = 125°C
MBRS15100CT-Y J
MBRS15150CT-Y
MBRS15200CT-Y
TYP
MAX
UNIT
V
0.75
V
0.92
V
0.95
V
0.84
V
V
V
V
0.57
V
0.65
V
0.82
V
0.92
V
0.72
V
V
V
V
100
µA
15
mA
10
mA
5
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
MBRS15xCT-Y
PACKAGE
2
TO-263AB (D PAK)
PACKING
800 / Tape & Reel
Notes:
1. “x” defines voltage from 45V(MBRS1545CT-Y) to 200V(MBRS15200CT-Y)
2
Version: D2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
15
CAPACITANCE (pF)
10
5
100
45CT-Y
60CT-Y
100CT-Y - 200CT-Y
10
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
45CT-Y
60CT-Y - 200CT-Y
1
TJ=125°C
0.1
TJ=75°C
0.01
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
100
Fig.4 Typical Forward Characteristics
100
10
10
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
90 100
100 10
10
1
45CT-Y
60CT-Y
100CT-Y
- 200CT-Y
UF1DLW
TJ=125°C
TJ=125°C
TJ=25°C
0.1
1
TJ=25°C
0.01
0.1
0.001
0.1
Pulse width 300μs
1% duty cycle
Pulse width
0.2 0.3 0.4
0.3
0.4
0.5
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.5 0.6 0.7 0.8 0.9
0.6
0.7
0.8
0.9
1.0
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
180
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
f=1.0MHz
Vsig=50mVp-p
(A)
AVERAGE FORWARD CURRENT (A)
8.3ms single half sine wave
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: D2103
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: D2103
PACKAGE OUTLINE DIMENSIONS
2
TO-263AB (D PAK)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: D2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: D2103
很抱歉,暂时无法提供与“MBRS15100CT-Y MNG”相匹配的价格&库存,您可以联系我们找货
