1210M3200BMAM-CT
1210M3200BMAM-CT
    HKC(香港晶体)
    SMD-4
    无源晶振 100Ω 32MHz 5pF ±10ppm -30℃~+85℃ SMD-4
1210M3200BMAM-CT 数据手册
0.29 0.29 #4 #3 #1 0.39 #1 #2 #4 #3 #4 #2 #1 0.3 0.39 0.3 https://www.hongkongcrystal.com Email: inquiry@hongkongcrystal.com Item 32.00MHz to 80.00MHz ±10ppm, ±20ppm (or specify) ±10ppm ±20ppm -20°C to +70°C -40°C to +85°C -40°C to +90°C 50uW Typ (100uW Max) 8pF (or specify) ESR Table Frequency Range (MHz) Standard ESR (Ohm) 32.00 ~ 32.99 33.00 ~ 36.99 37.00 ~ 80.00 100 80 60 Dimension 1.20 ±0.1 GND #3 GND #2 Soldering Pattern 0.5 Note : 1. Manufacturer reserves the right to change the specification and content of this product for improvement without notification. 2. Custom specification is welcome. Please contact our sales representative for further details. 3. If the crystal is intended for applications which have direct impact on human life and properties, and require a high degree of reliability and safety concerns, customers must provide full information such as but not limit to the application, electrical and reliability specification at the inquiry beginning stage. 4. Customers have to agree to the "Guideline for handling crystal units" and "Standard Terms and Condition of Sales" which is printed this catalog before placing orders to our company or our distributes. There are also unpredictable factors such as applied condition, oscillation margin and etc and customers must check them beforehand. In case of queries, please do not fail to send inquiry to our company before ordering. 0.4 1.0 ±0.1 Frequency Range Frequency Tolerance Frequency Tolerance over Temperature range Operating Temperature Range Operable Temperature Range Drive Level Load Capacitance 0.3 0.33 Max Model CU 0.3 QUARTZ CRYSTALS Hong Kong X'tals Limited Ceramic SMD Crystals 1210SX Series 4 PADS 1.2 X 1.0 Frequency Range : 32.00MHz to 80.00MHz Features : • High reliability & low cost unit • Tight stability & extended temperature available • Lead-free type Standard Specifications Value Ver 1.1
1210M3200BMAM-CT 价格&库存
很抱歉,暂时无法提供与“1210M3200BMAM-CT”相匹配的价格&库存,您可以联系我们找货
