SiT9387
AEC-Q100, 220 to 725 MHz Ultra-low Jitter Differential Oscillator
Features
Applications
AEC-Q100 Grade 2 temperature range (-40°C to 105°C).
Grade 3 and Grade 4 also available
Any frequency between 220.000001 MHz and 725 MHz,
accurate to 6 decimal places. For HCSL output signaling,
maximum frequency is 500 MHz – contact SiTime for higher
frequency options. For frequency between 1 and 220 MHz,
see SiT9386
LVPECL, LVDS and HCSL output signaling
Frequency stability as low as ±10 ppm – contact SiTime
0.23 ps RMS (typ) phase jitter (random, 12 kHz to 20 MHz)
Industry-standard packages: 3.2 x 2.5, 7.0 x 5.0 mm.
Contact SiTime for 5.0 x 3.2 mm package
100 Gbps Ethernet, SONET, SATA, SAS,
Fibre Channel
Telecom, networking, instrumentation, storage, servers
Electrical Characteristics
Table 1. Electrical Characteristics – Common to LVPECL, LVDS and HCSL
All Min and Max limits in the Electrical Characteristics tables are specified over temperature and rated operating voltage wi th
standard output termination show in the termination diagrams. Typical values are at 25°C and nominal supply voltage.
Parameter
Symbol
Min.
Typ.
Max.
Unit
Condition
Frequency Range
Output Frequency Range
f
220.000001
725
MHz
Accurate to 6 decimal places
Frequency Stability
Frequency Stability
First Year Aging
F_aging1
-10
+10
ppm
Inclusive of initial tolerance, operating temperature, rated
power supply voltage and load variations.
Contact SiTime for ±10 ppm
-20
+20
ppm
-25
+25
ppm
-50
+50
ppm
±1
ppm
At 25°C
Temperature Range
Operating Temperature Range
T_use
-20
+70
°C
AEC-Q100 Grade 4
-40
+85
°C
AEC-Q100 Grade 3
-40
+105
°C
AEC-Q100 Grade 2
Supply Voltage
Supply Voltage
Vdd
2.97
3.30
3.63
V
2.70
3.00
3.30
V
2.52
2.80
3.08
V
2.25
2.50
2.75
V
Input Characteristics
Input Voltage High
VIH
70%
Vdd
Pin 1, OE
Input Voltage Low
VIL
30%
Vdd
Pin 1, OE
Input Pull-up Impedance
Z_in
100
kΩ
Pin 1, OE logic high or logic low
Output Characteristics
Duty Cycle
DC
45
55
Startup and OE Timing
Startup Time
OE Enable/Disable Time
Rev 1.01
T_start
T_oe
3.0
ms
Measured from the time Vdd reaches its rated minimum
value
3.8
µs
F = 322.265625 MHz. Measured from the time OE pin
reaches rated VIH and VIL to the time clock pins reach
90% of swing and high-Z. See Figure 6 and Figure 7
9 March 2021
www.sitime.com
SiT9387 AEC-Q100, 220 to 725 MHz Ultra-low Jitter Differential Oscillator
Table 2. Electrical Characteristics – LVPECL Specific
Parameter
Symbol
Min.
Typ.
Max.
Unit
Condition
Current Consumption
Idd
94
mA
Excluding Load Termination Current, Vdd = 3.3 V or 2.5 V
OE Disable Supply Current
I_OE
63
mA
OE = Low
Output Disable Leakage Current
I_leak
0.15
A
OE = Low
I_driver
33
mA
Maximum average current drawn from OUT+ or OUT-
Current Consumption
Maximum Output Current
Output High Voltage
VOH
Vdd-1.15
Vdd-0.7
V
See Figure 2
Output Low Voltage
VOL
Vdd-2.0
Vdd-1.5
V
See Figure 2
V_Swing
1.2
1.6
2.0
V
See Figure 3
Tr, Tf
225
330
ps
20% to 80%, see Figure 3
Output Differential Voltage Swing
Rise/Fall Time
Jitter – 7.0 x 5.0 mm package
RMS Period Jitter[1]
T_jitt
1.0
1.6
ps
f = 100, 156.25 or 212.5 MHz, Vdd = 3.3 V or 2.5 V
RMS Phase Jitter (random)
T_phj
0.220
0.270
ps
f = 322.265625 MHz, Integration bandwidth = 12 kHz to
20 MHz, all Vdd levels, includes spurs.
Temperature ranges -20 to 70ºC and -40 to 85ºC
0.220
0.300
ps
Temperature range -40 to 105ºC
0.1
ps
f = 156.25 or 322.265625 MHz, IEEE802.3-2005 10GbE
jitter mask integration bandwidth = 1.875 MHz to 20 MHz,
includes spurs, all Vdd levels
Jitter – 3.2 x 2.5 mm package
RMS Period Jitter
T_jitt
1.0
1.6
ps
T_phj
0.225
0.282
ps
0.225
0.315
ps
0.1
ps
f = 322.265625 MHz, IEEE802.3-2005 10GbE jitter mask
integration bandwidth = 1.875 MHz to 20 MHz, Includes
[1]
Notes:
1. Measured according to JESD65B.
Rev 1.01
Page 2 of 12
www.sitime.com
Table 3. Electrical Characteristics – LVDS Specific
Parameter
Symbol
Min.
Typ.
Max.
Unit
Condition
Current Consumption
Current Consumption
Idd
85
mA
I_OE
63
mA
OE = Low
I_leak
0.15
A
OE = Low
VOD
250
530
mV
See Figure 4
ΔVOD
50
mV
See Figure 4
VOS
1.125
1.375
V
See Figure 4
VOS Magnitude Change
ΔVOS
50
mV
See Figure 4
Rise/Fall Time
Tr, Tf
370
505
ps
Measured with 2 pF capacitive loading to GND,
20% to 80%, see Figure 5
RMS Period Jitter[2]
T_jitt
0.92
1.6
ps
T_phj
0.215
0.265
ps
0.215
0.280
ps
0.1
ps
Differential Output Voltage
VOD Magnitude Change
Offset Voltage
T_jitt
0.92
1.6
ps
T_phj
0.235
0.282
ps
20 MHz, all Vdd levels, includes spurs. Temperature
ranges -20 to 70ºC and -40 to 85ºC.
0.235
0.310
ps
0.1
ps
Notes:
2. Measured according to JESD65B.
Rev 1.01
Page 2 of 12
www.sitime.com
Table 4. Electrical Characteristics – HCSL Specific
Parameter
Symbol
Min.
Typ.
Max.
Unit
Condition
Current Consumption
Current Consumption
Idd
97
mA
I_OE
63
mA
OE = Low
I_leak
0.15
A
OE = Low
I_driver
35
mA
Output High Voltage
VOH
0.60
0.90
V
See Figure 2
Output Low Voltage
VOL
-0.05
0.08
V
See Figure 2
V_Swing
1.2
1.4
1.9
V
See Figure 3
Rise/Fall Time
Tr, Tf
360
505
ps
RMS Period Jitter[3]
T_jitt
1.0
1.6
ps
T_phj
0.215
0.265
ps
Temperature ranges -20 to 70ºC and -40-85ºC
0.215
0.282
ps
0.1
ps
T_jitt
1.0
1.6
T_phj
0.235
0.282
ps
ps
0.235
0.305
ps
0.1
ps
Temperature ranges -20 to 70ºC and -40 to 85ºC.
Notes:
3. Measured according to JESD65.
Rev 1.01
Page 3 of 12
www.sitime.com
Table 5. Pin Description
Pin
1
Map
Top View
Functionality
OE/NC
[4]
Output Enable
(OE)
H : specified frequency output
L: output is high impedance
Non Connect
(NC)
H or L or Open: No effect on output frequency or other device
functions
OE/NC
1
6
VDD
NC
2
5
OUT-
GND
3
4
OUT+
No Connect; Leave it floating or connect to GND for better
heat dissipation
2
NC
NA
3
GND
Power
Vdd Power Supply Ground
4
OUT+
Output
Oscillator output
5
OUT-
Output
Complementary oscillator output
6
Vdd
Power
Power supply voltage[5]
Figure 1. Pin Assignments
Notes:
4. In OE mode, a pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven.
5. A capacitor of value 0.1 µF or higher between Vdd and GND is required. An additional 10 µF capacitor between Vdd and GND is required for the
best phase jitter performance.
Table 6. Absolute Maximum Ratings
Attempted operation outside the absolute maximum ratings may cause permanent damage to the part.
Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings.
Parameter
Min.
Max.
Unit
-0.5
4.0
V
Vdd + 0.3V
V
150
ºC
Maximum Junction Temperature
130
ºC
Soldering Temperature (follow standard Pb-free soldering guidelines)
260
ºC
Vdd
VIH
VIL
-0.3
Storage Temperature
-65
V
Table 7. Thermal Considerations[6]
Package
JA, 4 Layer Board (°C/W)
JC, Bottom (°C/W)
3225, 6-pin
80
30
7050, 6-pin
52
19
Notes:
6. Refer to JESD51 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table.
Table 8. Maximum Operating Junction Temperature[7]
Max Operating Temperature (ambient)
70°C
95°C
85°C
110°C
105°C
130°C
Notes:
7. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature.
Table 9. Environmental Compliance
Test Conditions
Value
Unit
Mechanical Shock Resistance
Parameter
MIL-STD-883F, Method 2002
10,000
g
Mechanical Vibration Resistance
MIL-STD-883F, Method 2007
70
g
Soldering Temperature (follow standard Pb free soldering guidelines)
MIL-STD-883F, Method 2003
260
°C
Moisture Sensitivity Level
MSL1 @ 260°C
Electrostatic Discharge (HBM)
HBM, JESD22-A114
2,000
V
Charge-Device Model ESD Protection
JESD220C101
750
V
Latch-up Tolerance
Rev 1.01
JESD78 Compliant
Page 4 of 12
www.sitime.com
Waveform Diagrams
OUT-
VOH
OUT+
VOL
GND
Figure 2. LVPECL/HCSL Voltage Levels per Differential Pin (OUT+/OUT-)
V
80%
80%
V_ Swing
0V
t
20%
20%
Tr
Tf
Figure 3. LVPECL/HCSL Voltage Levels across Differential Pair
Rev 1.01
Page 5 of 12
www.sitime.com
Waveform Diagrams (continued)
OUT-
VOD
OUT+
VOS
GND
Figure 4. LVDS Voltage Levels per Differential Pin (OUT+/OUT-)
V
80%
80%
0V
t
20%
20%
Tr
Tf
Figure 5. LVDS Differential Waveform
Timing Diagrams
Vdd
OE Voltage
Vdd
VIH
VIL
T_oe_hw
OE Voltage
T_oe_hw
OUT-
OUT-
90%
HZ
HZ
OUT+
OUT+
GND
GND
Figure 6. Hardware OE Enable Timing
Rev 1.01
Figure 7. Hardware OE Disable Timing
Page 6 of 12
www.sitime.com
Termination Diagrams
LVPECL
OUT+
Shunt Bias Termination
network
0.1μF
Zo = 50Ω
D+
OUT-
Zo = 50Ω
D-
LVPECL
0.1μF
RB
RB
VDD
50 Ω
50 Ω
RB
3.3 V 100 Ω
VT
2.5 V 48.7 Ω
Figure 8. LVPECL with AC-coupled termination
VDD
Thevenin-equivalent
Termination network
R1
LVPECL
R1
OUT+
Zo = 50Ω
D+
OUT-
Zo = 50Ω
D-
VDD
R1
R2
R2
3.3 V 127 Ω
82.5 Ω
2.5 V 250 Ω
62.5 Ω
R2
Figure 9. LVPECL DC-coupled load termination with Thevenin equivalent network
Y-Bias Termination
network
LVPECL
OUT+
Zo = 50Ω
D+
OUT-
Zo = 50Ω
D-
R1
VDD
R1
R2
R3
3.3 V
50 Ω
50 Ω
50 Ω
2.5 V
50 Ω
50 Ω
18 Ω
C1
0.1μF
R2
R3
Figure 10. LVPECL with Y-Bias termination
OUT+
network
Zo = 50Ω
D+
OUT-
Zo = 50Ω
D-
LVPECL
50 Ω
50 Ω
VT=VDD-2V
Figure 11. LVPECL with DC-coupled parallel shunt load termination
Rev 1.01
Page 7 of 12
www.sitime.com
Termination Diagrams (continued)
LVDS
LVDS
Zo = 50Ω
OUT+
OUT+
100 Ω
Zo = 50Ω
OUT-
OUT-
Figure 12. LVDS single DC termination at the load
LVDS
0.1μF
Zo = 50Ω
OUT+
OUT+
100 Ω
100 Ω
0.1μF
Zo = 50Ω
OUT-
OUT-
Figure 13. LVDS double AC termination with capacitor close to the load
LVDS
Zo = 50Ω
OUT+
OUT+
100 Ω
100 Ω
Zo = 50Ω
OUT-
OUT-
Figure 14. LVDS double DC termination
HCSL
R1
OUT+
OUT-
Zo = 50Ω
D+
Zo = 50Ω
D-
R2
50Ω
50Ω
R1 = R2 = 33 Ω
Figure 15. HCSL interface termination
Rev 1.01
Page 8 of 12
www.sitime.com
Dimensions and Patterns
Package Size – Dimensions (Unit: mm)[8]
Recommended Land Pattern (Unit: mm)[9]
3.2 x 2.5 x 0.85 mm
3.2 x 2.5 x 0.85 mm
1.00
1.6
2.25
0.65
7.0 x 5.0 x 0.85 mm[10]
1.05
Notes:
8. Top Marking: Y denotes manufacturing origin and XXXX denotes manufacturing lot number. The value of “Y” will depend on the assembly location of
the device.
9. A capacitor of value 0.1 µF or higher between Vdd and GND is required. An additional 10 µF capacitor between Vdd and GND is required for the best
10. The center pad has no electrical function. Soldering down the center pad to the GND is recommended for best thermal dissipation, but is optional.
Rev 1.01
Page 9 of 12
www.sitime.com
Ordering Information
SiT9387AC - 1B1-33E 322.265625T
Packaging
Part Family
“T”, “Y”, “D” or “E”
Refer to table below for packing method
[13]
Leave Blank for Bulk
“SiT9387”
Revision Letter
“A” is the revision of Silicon
Frequency
220.000001 to 725 MHZ for LVDS and
LVPECL output drivers
Temperature Range
220.000001 to 500 MHz for HCSL driver
“C”: Extended Commercial, -20 to 70°C
“I”: Industrial, -40 to 85°C
“E”: Extended Industrial, -40 to 105°C
[14]
Feature Pin
“N”: No Connect
“E”: Output Enable
Signalling Type
“1”: LVPECL
“2”: LVDS
“4”: HCSL
Voltage Supply
Package Size
“25”: 2.5 V ±10%
“28”: 2.8 V ±10%
“30”: 3.0 V ±10%
“33”: 3.3 V ±10%
[11]
“B”: 3.2 x 2.5 mm
“E”: 7.0 x 5.0 mm with center pad
Frequency Stability
“F”:
“1”:
“2”:
“3”:
±10 ppm
±20 ppm
±25 ppm
±50 ppm
[12]
Notes:
11. Contact SiTime for 5.0 x 3.2 mm package.
12. Contact SiTime for ±10 ppm option.
13. Bulk is available for sampling only.
14. Contact SiTime for higher frequency HCSL options.
Table 10. Ordering Codes for Supported Tape & Reel Packing Method
Device Size
(mm x mm)
8 mm T&R
(3ku)
8 mm T&R
(1ku)
12 mm T&R
(3ku)
12 mm T&R
(1ku)
7.0 x 5.0
3.2 x 2.5
D
E
Rev 1.01
Page 10 of 12
16 mm T&R
(3ku)
16 mm T&R
(1ku)
T
Y
www.sitime.com
Table 11. Additional Information
Document
Description
Download Link
ECCN #: EAR99
Five character designation used on the
commerce Control List (CCL) to identify dual
use items for export control purposes.
Part number Generator
Tool used to create the part number based on
desired features.
https://www.sitime.com/part-number-generator
Manufacturing Notes
Tape & Reel dimension, reflow profile and
other manufacturing related info
https://www.sitime.com/sites/default/files/gated/Manufacturing-Notes-for-SiTimeProducts.pdf
Qualification Reports
RoHS report, reliability reports,
composition reports
http://www.sitime.com/support/quality-and-reliability
Performance Reports
Additional performance data such as phase
noise, current consumption and jitter for
selected frequencies
http://www.sitime.com/support/performance-measurement-report
Termination Techniques
Termination design recommendations
http://www.sitime.com/support/application-notes
Layout Techniques
Layout recommendations
Table 12 .Revision History
Revision
Release Date
Change Summary
0.1
11-Mar-2017
Initial draft
0.87
6-Nov-2017
Updated package drawings
Corrected tape/reel ordering information
Updated Electrical Characteristics based on characterization
Added additional information table
Corrected formatting issues
added temperature range to 105ºC
Changed ±10 ppm to “contact SiTime”
Updated termination diagrams
Lower mechanical shock from 20,000 to 10,000 g
0.90
24-Nov-2017
Ordering information updates and page layout changes
1.0
15-Mar-2019
Updated Electrical Characteristics tables
Updated waveform diagrams
Added OE enable/disable timing diagrams
Updated package dimensions
Added an AEC-Q100 Grade 4 temperature option
Updated the ordering information
1.01
9-Mar-2021
Updated L1 and Dimple Width package dimensions for 3.2 x 2.5 mm package
Updated hyperlinks and changed rev table date format
SiTime Corporation, 5451 Patrick Henry Drive, Santa Clara, CA 95054, USA | Phone: +1-408-328-4400 | Fax: +1-408-328-4439
© SiTime Corporation 2017-2021. The information contained herein is subject to change at any time without notice. SiTime assumes no responsibility or liability for any loss, damage
or defect of a Product which is caused in whole or in part by (i) use of any circuitry other than circuitry embodied in a SiTime product, (ii) misuse or abuse including static discharge, neglect
or accident, (iii) unauthorized modification or repairs which have been soldered or altered during assembly and are not capable of being tested by SiTime under its normal test conditions, or
(iv) improper installation, storage, handling, warehousing or transportation, or (v) being subjected to unusual physical, thermal, or electrical stress.
Disclaimer: SiTime makes no warranty of any kind, express or implied, with regard to this material, and specifically disclaims any and all express or implied warranties, either in fact or by
operation of law, statutory or otherwise, including the implied warranties of merchantability and fitness for use or a particular purpose, and any implied warranty arising from course of dealing or
usage of trade, as well as any common-law duties relating to accuracy or lack of negligence, with respect to this material, any SiTime product and any product documentation. Products sold by
SiTime are not suitable or intended to be used in a life support application or component, to operate nuclear facilities, or in other mission critical applications where human life may be involved
or at stake. All sales are made conditioned upon compliance with the critical uses policy set forth below.
CRITICAL USE EXCLUSION POLICY
BUYER AGREES NOT TO USE SITIME'S PRODUCTS FOR ANY APPLICATION OR IN ANY COMPONENTS USED IN LIFE SUPPORT DEVICES OR TO OPERATE NUCLEAR
FACILITIES OR FOR USE IN OTHER MISSION-CRITICAL APPLICATIONS OR COMPONENTS WHERE HUMAN LIFE OR PROPERTY MAY BE AT STAKE.
SiTime owns all rights, title and interest to the intellectual property related to SiTime's products, including any software, firmware, copyright, patent, or trademark. The sale of SiTime products does
not convey or imply any license under patent or other rights. SiTime retains the copyright and trademark rights in all documents, catalogs and plans supplied pursuant to or ancillary to the sale
of products or services by SiTime. Unless otherwise agreed to in writing by SiTime, any reproduction, modification, translation, compilation, or representation of this material shall be strictly
prohibited.
Rev 1.01
Page 11 of 12
www.sitime.com
