BD020-06-A-J-0350-0300-L-G 数据手册
H
No. of
Contacts
B±0.38
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
A±0.25
1.27±0.05
G
Ø0.80
Recommended PCB Layout
1.27
F
2.50
D
C±0.2
J
G
E
F
E
E
Maximum Table
OL Max (mm) Dim C&D Max (mm)
Dim E
D±0.2
OL (See Table)
0.46 Sq. Pin
12.00
15.00
15.00
15.00
8.00
10.00
10.00
10.00
PCB
Dimensions
A
B
1.27
2.54
3.81
5.08
6.35
7.62
8.89
10.16
11.43
12.70
13.97
15.24
16.51
17.78
19.05
20.32
21.59
22.86
24.13
25.40
26.67
27.94
29.21
30.48
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
2.54
3.81
5.08
6.35
7.62
8.89
10.16
11.43
12.70
13.97
15.24
16.51
17.78
19.05
20.32
21.59
22.86
24.13
25.40
26.67
27.94
29.21
30.48
31.75
XX
X
X
XXXX
X
XXXX
X
No. of Contacts
02 to 50
Specifications
B
A
31.75
33.02
34.29
35.56
36.83
38.10
39.37
40.64
41.91
43.18
44.45
45.72
46.99
48.26
49.53
50.80
52.07
53.34
54.61
55.88
57.15
58.42
59.69
60.96
62.23
33.02
34.29
35.56
36.83
38.10
39.37
40.64
41.91
43.18
44.45
45.72
46.99
48.26
49.53
50.80
52.07
53.34
54.61
55.88
57.15
58.42
59.69
60.96
62.23
63.50
Ordering Grid
BD020
C
Dimensions
A
B
No. of
Contacts
Material
Insulator: LCP, UL94V-0, Black
Contact: Copper Alloy
Plating
Underplating: Nickel all over
Contact Area: See Ordering Grid
Electrical
Current Rating: 1 Amp Per Pin
Contact Resistance: 20 mΩ max.
Insulating Resistance: 1000 MΩ min.
Dielectric Withstand Voltage: 300V AC
Soldering Process:
IR Reflow: 260°C for 10 sec.
Wave: 250°C for 5-10 sec
Manual Solder: 350°C for 3-5 sec
2
Packing Options
G = Plastic Box (Standard)
B = Tape & Reel with Cap
D = Tube
E = Tube with Cap
Contact Plating
A = Gold Flash All Over (Standard)
B = Selective Gold Flash Contact Area/Tin On Tail
C = Tin All Over
G = 10µ" Gold Contact Area/Tin On Tail
I = 30µ" Gold Contact Area/Tin On Tail
Insulator Material
L = LCP
Dimension D (1/100mm) (Tail Length)
0300 = 3.00mm (Standard)
Dimension E (Insulator Height)
J = 1.40mm (Standard)
G = 1.70mm
E = 2.54mm
F = 3.0mm
or specify Custom Tail Length
eg 0250 = 2.50mm
(Minimum 0050=0.50mm)
(Maximum - See Table)
Dimension C (1/100mm) (Post Height)
0200 = 2.00mm (Standard)
0350 = 3.50mm (Standard)
Mechanical & Environmental
Operating Temperature: -40°C to +105°C
or specify Custom Post Height
eg 0250 = 2.50mm
Mates with(Subject to pin length )
BD069
BD076
Part Number
Product Description
BD020
1.27mm Pitch Pin Header
Single Row, Through-Hole, Vertical
Drawing Date
BD069 Recommended mating length 2.00mm
28th December 2007
By
Detail
1
3
Request Samples
and Quotation
4
Revision
Date
5
CC
Tolerances (Except as Noted)
BD020
F PCN
F6
13/02/20
X.° ± 5°
X. ± 0.30
X.X° ± 2°
X.X ± 0.20
X.XX ± 0.15 X.XX° ± 1°
X.XXX ± 0.10 X.XXX° ± 0.5°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
1/1
BD020-06-A-J-0350-0300-L-G 价格&库存
很抱歉,暂时无法提供与“BD020-06-A-J-0350-0300-L-G”相匹配的价格&库存,您可以联系我们找货
