UTGX6JC-----PSCR
8
7
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
Corrosion salt spray: 500 hours
Durability: 500 matings and unmatings
6
Sealing conditions: SEE TABLE
NOTA:
1- Contact to be ordered separately for version
UTGX0----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
5
C008-UTS1-A(female insulator)
C007-UTS1-A (male insulator)
3- This part shall be used at the place of the
standard seal to accomodate with different cable
4- Plug, backshell and the reducing seal are delivered as
a kit. The backshell already includes the standard seal.
A-A
COUPE
Sealing in MATED conditions with COUNTERPART:
-IP68 1 bar during 1 week: immersion under 10 m of water. (IEC 60529)
-IP69K : exposure to high pressure water of cleaning equipement
(DIN 40050)
BACKSHELL
BODY
THREAD
BACKSHELL
SEAL
BACKSHELL
NUT
INSERT
CountryJurisdiction
& Control List
FR
NOT LISTED
A MAX
SHELL
PLUG
MATING
SEAL
3
O'RING
P/N : CROSS REF TABLE
BASIC SERIES
SHELL TYPE
B min
2
MAX
A
min
STANDARD
B
REDUCING
SEAL (NOTA.3)
C
HEXAGON backshell nut
MAX
10% (g.)
D
Tightening
torque (N.m)
E1
E2
MASS
12
29.7
66.7
5 / 12
3 / 9
24
2
15.1
22.8
40
14
34.6
71.5
7 / 14
5 / 12
26
2.5
18.95
26.7
55
Torquing screw
advised : 20 N.cm
F
E
D
6
12
14
INSERT
ARRANGEMENT
See NOTA 2
10/05/19
ISS
DATE
TITLE
Scale
3/2
for example
3
SHELL SIZE
A
* P/N
Plug
JC
SCREW TERMINATION
TYPE OF
CONTACTS
P: MALE
S: FEMALE
New drawing
25253D
Latest modification - by:
LANDAIS.PE
Date:
10/05/19
CUSTOMER DRAWING
MOD N
FORMAT
C
A2
2
PLUG T6 WITH BACKSHELL JC AND SCREW CONTACT - SIZE 12 & 14
UTGX CONNECTOR
Dimensions in mm
General linear
Tolerances:
0.2
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
www.esterline-connection-technologies.com
It must not be reproduced or
communicated without permission
1
G
UTGX 6 JC 14 7 P SCR
RACCORD
Designed by:
Wire strip length = 5,8 mm
H
4
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
Cable section acceptance:
0,5 mm2 to 2,5 mm2
4
COMMON QUOTES FOR ALL VERSION
COUPLING RING
CAPACITY
C
CONDITIONS
SHELL : PA UL94 V0, UL746C F1 Black color
COUPLING RING: PA + Nickel plated brass
BACKSHELLS : PA UL94 V0 F1 Black color
BACKSHELL Seal : CR
INSERT : PA UL94 V0, UL746C F1
O'RING : NITRIL
MATING SEAL : SILICON
CONTACT SPRING: copper alloy
CONTACT BODY : brass, gold and nickel plated
SCREW : stainless steel
PERFORMANCE CHARACTERISTICS
WIRING AREA (between insert and backshell seal)
E2
5
SEALING
A-A
HEXAGON D
(See tightening torque in table)
6
UTGX6JC-----SSCR
7
DETAIL CONTACT
SHELL
SIZE
A
MATERIAL :
E1
COUPE
B
C
D
E
F
G
H
8
A.3; Validé
SIDE VIEW FOR EACH VERSION
SOURIAU DRG N°
UTGX-0006A-C
B
SHEET
1 / 2
A
1
A
B
C
D
E
F
G
H
5%
-- g
8
8
7
7
6
6
5
5
4
4
3
A.3; Validé
MASS
3
P/N :
2
A
ISS
DATE
Designed by:
TITLE
Scale
3/2
Date:
1
H
G
F
E
D
C
FORMAT
A2
2
Dimensions in mm
General linear
Tolerances:
www.souriau.com
CountryJurisdiction& Control List
FR
NOT LISTED
CUSTOMER DRAWING
MOD N
SOURIAU DRG N°
UTGX-0006A-C
B
NPRDS / PROJECT
GBB
SOURIAU
SHEET
2 / 2
A
1
很抱歉,暂时无法提供与“UTGX6JC147SSCR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+282.901131+34.28601
