MD-60SM
MD-60SM
    CUIDEVICES
    CONN RCPT FMALE MINI DIN 6P SLDR
MD-60SM 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 08/11/2020 page 1 of 5 SERIES: MD-SM │ DESCRIPTION: MINI DIN CONNECTOR FEATURES • PCB mount • right angle • side shielded PART NUMBER KEY MD - XX SM Base Number Pin Options 30 = 3 pins 40 = 4 pins 50 = 5 pins 60 = 6 pins 70 = 7 pins 80 = 8 pins 90 = 9 pins SPECIFICATIONS parameter conditions/description min rated input voltage typ 30 rated input current contact resistance insulation resistance voltage withstand max Vdc 1 A 30 mΩ 1000 MΩ for 1 minute insertion force withdrawal force 500 Vac 45 N 7 operating temperature N -25 life 50 500 flammability rating UL94V-0 RoHS yes units °C cycles SOLDERABILITY parameter conditions/description min hand soldering for 1~3 seconds 230 cuidevices.com typ max units 250 °C Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ SERIES: MD-SM │ DESCRIPTION: MINI DIN CONNECTOR date 08/11/2020 │ page 2 of 5 MECHANICAL DRAWINGS (MD-30SM, MD-40SM, MD-50SM) units: mm tolerance: X.X ±0.38 mm X.XX ±0.25 mm X.XXX ±0.13 mm MD-30SM MATERIAL 8 Recommended PCB Layout Top View body pins brass tin shield brass nickel MD-40SM 3 PLATING PBT+30%GF (UL94V-0) MD-50SM 6 5 Recommended PCB Layout Top View cuidevices.com Recommended PCB Layout Top View Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ SERIES: MD-SM │ DESCRIPTION: MINI DIN CONNECTOR date 08/11/2020 │ page 3 of 5 MECHANICAL DRAWINGS (MD-60SM, MD-70SM, MD-80SM) units: mm tolerance: X.X ±0.38 mm X.XX ±0.25 mm X.XXX ±0.13 mm MATERIAL MD-60SM body pins brass tin shield brass nickel MD-70SM MD-80SM 6 8 8 5 3 2 PLATING PBT+30%GF (UL94V-0) 3 1 Recommended PCB Layout Top View 2 Recommended PCB Layout Top View cuidevices.com 7 6 4 5 1 Recommended PCB Layout Top View Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ SERIES: MD-SM │ DESCRIPTION: MINI DIN CONNECTOR date 08/11/2020 │ page 4 of 5 MECHANICAL DRAWING (MD-90SM) units: mm tolerance: X.X ±0.35 mm X.XX ±0.25 mm X.XXX ±0.15 mm MATERIAL 9 6 8 5 4 2 3 1 6 9 9 7 2 8 5 1 6 2 8 5 PBT (UL94V-0) cover PBT (UL94V-0) ground brass tin pins brass tin shield brass tin 7 4 3 1 3 4 PLATING body 7 Recommended PCB Layout Top View cuidevices.com Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: MD-SM │ DESCRIPTION: MINI DIN CONNECTOR | PCB Footprint date 08/11/2020 │ page 5 of 5 REVISION HISTORY rev. description date 1.0 initial release 02/23/2006 1.01 new template applied 02/22/2012 1.02 updated datasheet 08/25/2017 1.03 added hand soldering details 01/19/2018 1.04 updated housing, brand update 11/21/2019 1.05 updated PCB footprints 08/11/2020 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
MD-60SM 价格&库存
很抱歉,暂时无法提供与“MD-60SM”相匹配的价格&库存,您可以联系我们找货
