Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/11/2020
page
1 of 5
SERIES: MD-SM │ DESCRIPTION: MINI DIN CONNECTOR
FEATURES
• PCB mount
• right angle
• side shielded
PART NUMBER KEY
MD - XX SM
Base Number
Pin Options
30 = 3 pins
40 = 4 pins
50 = 5 pins
60 = 6 pins
70 = 7 pins
80 = 8 pins
90 = 9 pins
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
30
rated input current
contact resistance
insulation resistance
voltage withstand
max
Vdc
1
A
30
mΩ
1000
MΩ
for 1 minute
insertion force
withdrawal force
500
Vac
45
N
7
operating temperature
N
-25
life
50
500
flammability rating
UL94V-0
RoHS
yes
units
°C
cycles
SOLDERABILITY
parameter
min
hand soldering
for 1~3 seconds
230
cuidevices.com
typ
max
units
250
°C
Product Page
3D Model
PCB Footprint
CUI Devices │ SERIES: MD-SM │ DESCRIPTION: MINI DIN CONNECTOR
date 08/11/2020 │ page 2 of 5
MECHANICAL DRAWINGS (MD-30SM, MD-40SM, MD-50SM)
units: mm
tolerance:
X.X ±0.38 mm
X.XX ±0.25 mm
X.XXX ±0.13 mm
MD-30SM
MATERIAL
8
Recommended PCB Layout
Top View
body
pins
brass
tin
shield
brass
nickel
MD-40SM
3
PLATING
PBT+30%GF
(UL94V-0)
MD-50SM
6
5
Top View
cuidevices.com
Top View
Product Page
3D Model
PCB Footprint
date 08/11/2020 │ page 3 of 5
MECHANICAL DRAWINGS (MD-60SM, MD-70SM, MD-80SM)
units: mm
tolerance:
X.X ±0.38 mm
X.XX ±0.25 mm
X.XXX ±0.13 mm
MATERIAL
MD-60SM
body
pins
brass
tin
shield
brass
nickel
MD-70SM
MD-80SM
6
8
8
5
3
2
PLATING
PBT+30%GF
(UL94V-0)
3
1
Top View
2
Top View
cuidevices.com
7
6
4
5
1
Top View
Product Page
3D Model
PCB Footprint
date 08/11/2020 │ page 4 of 5
MECHANICAL DRAWING (MD-90SM)
units: mm
tolerance:
X.X ±0.35 mm
X.XX ±0.25 mm
X.XXX ±0.15 mm
MATERIAL
9
6
8
5
4
2
3
1
6
9
9
7
2
8
5
1
6
2
8
5
PBT (UL94V-0)
cover
PBT (UL94V-0)
ground
brass
tin
pins
brass
tin
shield
brass
tin
7
4
3
1
3
4
PLATING
body
7
Top View
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/11/2020 │ page 5 of 5
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
02/22/2012
1.02
updated datasheet
08/25/2017
1.03
added hand soldering details
01/19/2018
1.04
updated housing, brand update
11/21/2019
1.05
updated PCB footprints
08/11/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“MD-50SM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 98+19.0908298+2.30893
- 500+14.05108500+1.69940
- 756+10.89989756+1.31828
- 2268+10.730082268+1.29774
